    Thành viên chính thức thanhchien_mobi179's Avatar
    Dec 2009
    Mặc định 6070 gọi mấy báo hết pin cần giúp
    mấy em pị vô nước.đã làm có nguồn nhưng khi kẹp nguồn gọi thi máy báo hết pin rùi tắt nguồn.em đã chạy Getting MCU ID
    MCU ID: 0x2142
    FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 04.23
    26-10-07
    RM-166
    (c) Nokia.
    HW version: 4051
    PCI version:
    UEM version: 416
    UPP version: 8514
    RFIC version: 0205
    DSP version: P05w06.v40
    LCD version: SUEZ
    PPM version: V 04.23
    26-10-07
    RM-166
    (c) Nokia.
    V
    Production serial number: DGN366197
    Product code: 0534571
    Module code: 0202972
    Basic production code: 0531001
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO: h????????????????????????????????????????????????
    Default SN type: h????????????????????????????????????????????????
    IMEI plain: 351868012888108
    IMEI spare to net: 3A 15 68 08 21 88 18 00
    IMEI SV to net: 33 15 68 08 21 88 18 00 F9
    Master Code: 6727437774
    Phone type: RM-166, Software version: 04.23, Language Pack: V
    User code: 12345
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-166.ini
    Setting local mode...
    Reading product code...
    Product Code: 0534571
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-166\
    Checking path: \Products\RM-166\
    No ini files found...
    Done!
    Setting test mode...
    Setting FULL FACTORY...
    Done!
    Resetting USER DATA...
    Done!
    Resetting LEAVE FACTORY...
    Done!
    Resetting SERVICE CENTER...
    Done!
    Resetting UPGRADE SOFTWARE...
    Done!
    Resetting PRODUCTION TUNE...
    Done!lại va máy báo nhung thế này .mong moi người giúp.thanks
    Jan 2010
    Quan Họ - Bắc Ninh
    Máy khi cấp nguồn có hao nguồn chờ +nguồn tĩnh gì không boy ?
    Dec 2009
    ko có hao anh ơi
    Jan 2010
    Quan Họ - Bắc Ninh
    Trích Được post bởi thanhchien_mobi179 Xem bài viết
    ko có hao anh ơi
    gọi là hết pin luôn à..... bạn chek lại PA nhé,,,,,
    ĐÔ LƯƠNG _ NGHỆ AN
    bạn cấp nguồn cao lên gọi xem có mất nữa không ? kiếm con PA good thay vào xem sao bạn
    Thành viên tích cực MLONG_GSM's Avatar
    Apr 2008
    cách ly pa .lấy sợi dây đồng câu dài ra thay thế pa .rồi gọi coi tắt k .nếu k tắt múc pa thôi .
    hotline : 0933221333 yh minhlong0379@yahoo.com
    aribank 5902205130651 chi nhánh xuân lộc - đồng nai chủ tk : Trịnh minh long
    Dec 2009
    thay pa chuẩn ko cần chỉnh.em làm ok rui.thanks
  1. 6070 cần giúp
    By taimobile1 in forum DCT4 - WD2
    Bài viết cuối: 25-06-2012, 16:39
  2. 6070 pan lạ cần giúp!!!
    By nguyenviethuy in forum DCT4 - WD2
    Bài viết cuối: 08-10-2010, 13:44
  3. 6070 xin giúp
    By lamvu395 in forum Tool - Soft và phần mềm free!
    Trả lời: 18
    Bài viết cuối: 23-08-2009, 16:02
  4. giúp em cai log 6070
    By trungthanh1022 in forum BB5
    Bài viết cuối: 26-02-2009, 15:05
