Trang 1 của 3 1 2 3 CuốiCuối
Kết quả 1 tới 10 của 26
    Thành viên chính thức ngocthu2208's Avatar
    Mặc định 2700 flash mât nguồn
    giúp em nó báo
    JAF version 1.98.62
    Detected PKEY: 90009699
    Card life counter: 99.99%
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 7.1.29.0
    Changing mode...Done!
    Searching for phone...Detected P-KEY: 90009699
    Init usb communication...
    Found
    Error reading full info...
    Found
    Init usb flashing...
    Error init usb flashing...
    Found
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_x
    Phone Type:
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98_008.image_x_ctv_id_v2_96897
    PRESS POWER ON NOW!
    Searching for phone...Found
    Sending RAW loader...
    Using 06.02.002
    Elf2flash 09.07.000
    CMT RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step3...
    Sending RAW Loader...
    ...................Loader Sent!
    Stage 2 starting.......................................... .....................................Loader Sent!
    Stage 3 starting..................Phone prepared OK!
    Waiting for the phone to boot...
    Status byte: 8000
    Selecting CMT flash...
    Result: 0000
    Phone is in flash mode...
    CMT blocks: 2610, APE blocks: 0
    Erasing cmt...
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.mcusw...
    Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000
    Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000
    Erasing cmt zone 00040000 - 000BFFFF ... Erase result: 0000
    Erasing cmt zone 000C0000 - 0013FFFF ... Erase result: 0000
    Erasing cmt zone 00140000 - 0137FFFF ... Erase result: 0000
    Erasing cmt zone 01380000 - 0151FFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98.ppm_x...
    Erasing cmt zone 01520000 - 01DBFFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-561\rm561__09.98_008.image_x_ctv_id_v2_96897...
    Erasing cmt zone 01DC0000 - 0215FFFF ... Erase result: 0000
    Erasing cmt zone 02160000 - 03FBFFFF ... Erase result: 0000
    Send CMT CFG...
    Writing cmt...
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    cmt->PAPUB keys already sent...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Error sending cmd data...
    Error writing cmt...
    em cám ơn nha
    cứu cứu cứu
    V.I.P phungtien's Avatar
    cà mau
    máy lúc đầu bị gì bạn,có nước nôi gì không?
    SÓNG GIÓ CUỘC ĐỜI NUÔI TA LỚN,BÃO TÁP CUỘC ĐỜI DẠY TA KHÔN
    vào menu trắng màn
    nó vao menu khởi động
    V.I.P tlpmobile_tk's Avatar
    Krông Nô - Đăk Nông
    lấy cáp usb chạy lại coi bạn đổi box khác coi thử
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    usb không được thì dùng cáp fbus hoặc đa năng mà flash lại cho nó thôi anh
    Thành viên chính thức baoduc_ayunpa's Avatar
    Mar 2011
    mang qua Mx múc cho tỉnh dậy anh.cái này lổi cặp rồi anh ơi.e gặp 2 trường hợp vậy rồi xóa full chạy lại ko hết.giải pháp là thay cặp.ok 100%
    V.I.P ThanhHai_GSM's Avatar
    chuyển box khác flash lại hoặc chuyển usb đi bạn
    Thành viên chính thức ducchinh_20017's Avatar
    Oct 2010
    bạn cho vào cáp đa năng flas lại cho em nó lại thử coi
  1. Trả lời: 23
    Bài viết cuối: 18-07-2013, 11:24
  2. Trả lời: 7
    Bài viết cuối: 02-05-2013, 21:56
  3. thay flash 2700
    By trunghaumobile912 in forum BB5
    Bài viết cuối: 24-10-2012, 17:49
  4. 2700 flash báo lỗi
    By vanchien89 in forum BB5
    Trả lời: 20
    Bài viết cuối: 16-03-2012, 17:19
  5. 2700 flash mất nguồn
    By nguyendong_mobi in forum BB5
    Trả lời: 13
    Bài viết cuối: 06-12-2011, 16:37
