mình có con máy e63 khách nói đang dùng bị đơ tháo pin lắp lại
bật nguồn thì chỉ rung một cái nên đen hình hơi sáng
đây là log của nó băng mxky khi bus
MXKEY Serial: [FT SCR2000 0] - C0818161
Connection status: UHCI:HUB:HUB:USB 1.10 (Full-speed)
Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 1FC00107A4980052A88C410119C7D84D477FC231
ASIC MODE ID: 00
ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5
ROM ID: 4B9B75103E691FF8
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 9.50.0 revision: 2.0 size: 0x3B40
Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
eBB5ProtocolType: NEW
NewProtocol is not supported for current interface (UFS_USB V2.8 (c) SarasSoft 2007.).
Please select correct loader version from 'Config' menu !
còn đây là khi chạy bằng mxkey
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.67
Processing MCU file: rm437_510.21.010_prd.c00
[BB5,XSR 1.5] size: 63.43 MB
Supported Ids: 4003192101002003, 400C192101002003, 0003192101002003, 000C192101002003, 000C192101011103, 0003192101011103, 400C192101011103, 4003192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101051103, 400C192101051103
Waiting for USB device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 30ADB340
CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 1FC00107A4980052A88C410119C7D84D477FC231
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: C70CB07324056BC66A824347F40DB2D5
CMT ROM ID: 4B9B75103E691FF8
Loading CMT secondary boot code
SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
Secondary boot loaded.
Storage2: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,NOR, asic:CMT
Storage4: 0020 0040 - 0000 0031 [ST NAND KAT00F00RA] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.5
Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
Update server code loaded.
FUR: Adding Asic CMT as client OK.
CERT backup skipped.
CMT PAPUBKEYS HASH: D9C25399C696B8549EDCDB1497A950B3A20DDFB6
Storing certificate [NPC, CCC, HWC, R&D] ...OK
Partitioning....
Partitioning complete
Erase size: 122.56 MB
CMT FLASH,MuxOneNAND area [00040000-007FFFFF]
CMT FLASH,MuxOneNAND area [00A00000-0759FFFF]
CMT FLASH,MuxOneNAND area [0F1C0000-0F8BFFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: D9C25399 [RAP Certificate 137 v.1] sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT SOS*ISASW block sent
CMT SOS*CORE block sent
CMT SOS+ROFS block sent
Programming completed in 17 min 48.953 s
Processing PPM file: rm437_510.21.010_prd.v29
[BB5,XSR 1.5] size: 22.51 MB
Erase size: 33.56 MB
CMT FLASH,MuxOneNAND area [05420000-0759FFFF]
CMT SOS+ROFX block sent
Programming completed in 6 min 37.859 s
Processing CNT file: sofie_erase_y_drive.fpsx
[BB5,XSR 1.5] size: 236 Bytes
Erase size: 1.62 MB
CMT FLASH,MuxOneNAND area [0F020000-0F1BFFFF]
Processing CNT file: rm437_510.21.010.36U
[BB5,XSR 1.5] size: 22.52 MB
Erase size: 64 KB
Programming completed in 6 min 38.188 s
Total time for flashing process(boot+erase+write) was 31 min 19.156 s
Waiting for USB device removal ...
Verifying communication to device...
ERROR: Could not verify communication !
FULL FACTORY... Failed!
Completed in 0.781 s
mình đã chạy bàng hwk cũng không được
bật chỉ dung một cái
mong anh em giúp
			 E63 mong anh em giúp với
