Kết quả 1 tới 10 của 17
    Thành viên tích cực duytoai's Avatar
    miền trung
    Mặc định 1280 flash done nhưng không lên nguồn
    tình hình là thế này.em đang gặp em 1280 rơi nước không lên nguồn.nhưng flash thì ok.mong ae cho ý kiến
    đây là log em nó
    Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
    Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
    Do not disconnect or abort this operation otherwise phone will be damaged.
    Device synchronized.
    CPU: XGOLD 110
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version : Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbps
    Flash ID: 0020 88C0 [ST M58MWR064FU,64 Mbits]
    Processing file: rm647_006.500
    Downloading item CODE:hw_b2_rm647_r06.500.fls, num block: 3, size: 4.04 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 39.031 s
    Erasing area 0x00C60000-0x00E5933E ...OK
    Programming completed in 40.766 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.156 s
    Checksum verified (0xAE17)
    Processing file: rm647_006.50mr
    Downloading item CUST:hw_b2_rm647_006.50mr.fls, num block: 1, size: 1.10 MB
    Erasing area 0x00210000-0x003288BE ...OK
    Programming completed in 20.453 s
    Checksum verified (0x52F7)
    Processing file: rm6470_nai06.50mr
    Downloading item CUST:hw_b2_rm6470_nai06.50mr.fls, num block: 1, size: 305.83 KB
    Erasing area 0x00EB0000-0x00EFBA3E ...OK
    Programming completed in 6.016 s
    Checksum verified (0x342D)
    Total time for flashing process(boot+erase+write) was 3 min 5.860 s
    Phone type: RM-647
    SW version: V 06.50 20-04-11 RM-647 (c) Nokia
    Imei plain: 35433804301770-2
    Product code: 0593094
    Cellular system: GSM
    ASIC ID: 0x2292, type: 11
    Ppm Id: MR
    Language Pack:
    English,Hindi,Bengali
    Imei net: 35433804301770
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 0000000000030002
    cộng hoà xã hội chủ nghĩa việt nam
    độc lập - tự do - hạnh phúc:D
    Feb 2008
    lâm đồng
    ngỡ bỏ trở dôi gân ic nguồn đi ban dướng bis
    Thành viên tích cực SỸ HẢI_mobile's Avatar
    coi cái màn hình đi anh găp mấi con rồi
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    kiểm tra lại Màn Hình, BSI và thạch anh dao động = ok
  5. ( nhanvnn ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    7l0ve (18-11-2012)
    Thành viên tích cực linhsaker's Avatar
    từ sơn bắc ninh
    câu chân tô đen ok
    yahoo : x4uz4j_0mh4n_ch4p_nh4n_c0d0n_vkl
    sđt 097.885.1989 ----- 0128.741.1989
  7. ( linhsaker ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    7l0ve (18-11-2012)
  8. #6
    bình phước
    kiểm tra LCD ok 100%
  9. #7
    V.I.P thanhtunggialai™'s Avatar
    Nam Định
    Làm theo cách trên not ok thì làm chân lại cặp .Đã từng gặp qua .Chúc thành công .
    Thanh Tùng Mobile
    Địa chỉ : Chợ gạo - Thành Lợi - Vụ Bản - Nam Định
    Phone : 0905022590
  10. #8
    Feb 2008
    lâm đồng
    hết thuốc cho uống thuốc lắc đi bạn
  11. #9
    Feb 2008
    lâm đồng
    kẹp dòng lắp pin đều không lên hả pạn
  12. #10
    miền trung
    thanks all.mình làm ok rồi
  1. Trả lời: 12
    Bài viết cuối: 31-08-2014, 10:57
  2. Trả lời: 1
    Bài viết cuối: 07-03-2014, 16:32
  3. Trả lời: 1
    Bài viết cuối: 12-02-2014, 21:22
  4. Trả lời: 25
    Bài viết cuối: 16-05-2013, 23:31
  5. 1280 Flash ok không lên nguồn
    By luongno in forum DCT4 - WD2
    Bài viết cuối: 17-08-2011, 11:18
