Kết quả 1 tới 10 của 10
    Thành viên mới DONGXOAI_GSM's Avatar
    Nov 2011
    Mặc định 1200 mở mã bảo vệ không được, chạy lại báo lỗi
    1st Boot: Ok, DCT4, UPP: 2292 [Rh-99] [2.2.0.2]
    2nd Boot: u3_2nd.fia, Ver: 4.79.0
    Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18
    Algorithm: u3_intel.fia, Ver: 4.80.0
    Algorithm Ok, MSID: 84F14E00D50FB74E3A7FE1F45C
    Decoded MSID: 3E4EBAE9-0007F62F-AA000000
    Encoded FAID: 9128EE48-236AEE50-7D43ACA9
    IMAGE: rh99_06.000
    Area1: 0x01000000-0x0100FFFF Erased, Time: 00:00
    Area2: 0x01010000-0x013AFFFF Erased, Time: 00:36
    Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:03
    Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
    Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
    MCU Flashing Completed, Time: 00:20
    IMAGE: rh990_nai6.00mr
    Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01
    CNT Flashing Completed, Time: 00:01
    Init Local Mode Failed
    Thành viên tích cực thuy1986's Avatar
    bạn thử kiểm tra lại con trỏ kép BSI sem còn không ? kiểm tra cap ? không được lấy eazy 3in1 bẻ khóa là ok
  3. ( thuy1986 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    DONGXOAI_GSM (14-11-2011)
    Mặc định anh em sem hộ cái log flash 5130 với
    ATF Software Version v7.70
    ATF Lightning FBUS Flash Started...
    Number of Image Files: 3
    Processing Image File :
    C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.mcusw
    CMT Type : BB5
    CMT Algorithm : BB5 ALGORITHM
    Secondary Sending Speed : 3250000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 1178
    Entry Point: 0x5057
    Page Format : -1
    MAX PAGE : 0x00004000
    Changing MODE : FLASH
    AdvanceBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    TIME STARTS HERE
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01033000
    2 ROM_ID 15
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 ROM_ID 15
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 26B00012
    ID DWORD 1 : 23497F56
    ID DWORD 2 : 7DD07762
    ID DWORD 3 : CB0130B6
    ID DWORD 4 : 266F1C1F
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    Checksum D4
    SearchForBootstrap_DCT5..
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_2nd.fg
    Boot File - Version 010.042.00
    Boot File - Revision 0x0000 (0)
    eBB5ProtocolType == Original
    Secondary Loader Sent...
    MessageID : 03
    SubBlocks : 03
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : NOR 00
    Device Index : 00
    Manufacturer Code : 0089 ->
    Device ID : 8982 -> NU48F512
    Extended/Fixed ID : 0000
    Revision ID : 8A31
    2 Sub Block ID : 11 STORAGE_DEVICE_CONTENTS_BB5
    Block Length : 13
    Device Index : 00
    Device Contents : 00000000000000000000
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Checksum : 51
    FLS1SendAlgoCodeEx..
    SendAlgoCode_DCT5..
    SearchForAlgorithm_DCT5..
    Looking for ALL Devices...
    Searching Algorithm Files NOR (00) ManID :0089 DevID :8982 ExtID :0000 RevID :8A31
    Flash Descriptor
    Device ID : 8982
    Revision ID : 0000
    Size : 04000000 (64 MB)
    VPP Info : 0009
    Erase10s : 28
    Block1s : 64
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    VPPInfo : VPP_INFO_3V_MASK VPP_INFO_9V_MASK
    C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\RAP3Gv3_algo.fg
    Algorithm File - Version 010.040.00
    Algorithm File - Revision 0x0000 (0)
    SearchForAlgorithm_DCT5 : No Error - 0 (0x00)
    TransmissionTypeRequest_DCT5...
    SuggestedType : 01 16BIT
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 01 DC
    ReturnedType : 01 16BIT
    TransmissionTypeRequest_DCT5 : No Error - 0 (0x00)
    Uploading ALGO File...
    OLD Protocol Detected... Using Turbo Mode...
    Pabub KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    0C917F11196FDB7378C18EF7260698CA4489DCA0
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    Certificate 5
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 05 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 56 41 52 49 41 4E 54 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 85
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    VPP Enabled by Software
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x36 (54)
    ERASE Blocks : 0x01 (1)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x33 (51)
    BB ASIC Index : 0x00 CMT
    Device Type : 0x00 NOR
    Device Index : 0x00
    0 : 00000000-000006BF
    1 : 000006C0-0001FFFF
    2 : 00040000-000BFFFF
    3 : 000C0000-0013FFFF
    4 : 00140000-0137FFFF
    5 : 01380000-0151FFFF
    Erase_SendEraseBlock_BB5_NOR
    Task in Progress... Please Wait...
    Status_BB5 STATUS_REQUEST_BB5..
    1 Sub Block ID : 14 STATUS_NOR_OK_BB5
    Block Length : 01
    BB ASIC Index : 00
    Successfully erased..
    Time Taken to Erase : 00:01:27
    TRANSMISSION_TYPE_REQUEST_BB5 : 59 01 20 01 04 D9
    ReturnedType : 04 DDR & 2TX
    Flashing Speed: 5.00 Mhz
    Processing : rm495__07.97.mcusw
    Total blocks to write : 1178
    FBUS Cable RX2 PIN Diagnostics
    Block Length : 01
    BB ASIC Index : 00
    INFO: RX2 PIN is OK
    >> CMT Rootkey Hash CERT : NOLO
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : PAPUBKEYS
    >> CMT Rootkey Hash CERT : UPDAPP
    >> CMT Rootkey Hash CERT : DSP0
    >> CMT Rootkey Hash CERT : MCUSW
    ContinueFlash_DCT5 Complete
    Block Length : 01
    BB ASIC Index : 00
    Continue Flash Complete : : No Error - 0 (0x00)
    Time Taken to Flash : 00:00:57
    C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.ppm_v
    CMT Type : BB5
    Number of Blocks : 494
    Entry Point: 0x00BE
    Page Format : -1
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01520000-01DBFFFF
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Erase : 00:00:36
    Processing : rm495__07.97.ppm_v
    Total blocks to write : 494
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Flash : 00:00:21
    C:\Program Files\Nokia\Phoenix\Products\RM-495\rm495__07.97.image_v_red
    CMT Type : BB5
    Number of Blocks : 824
    Entry Point: 0x00D0
    Page Format : -1
    Using Internal VPP
    StartErase_DCT5...
    BlockLength : 0x16 (22)
    Block Length : 0x13 (19)
    Device Index : 0x00
    0 : 01DC0000-0215FFFF
    1 : 02160000-03FBFFFF
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Erase : 00:02:20
    Processing : rm495__07.97.image_v_red
    Total blocks to write : 824
    Block Length : 01
    BB ASIC Index : 00
    Time Taken to Flash : 00:00:36
    Total Flash Write Time (Flashing Only) : 00:01:54
    Total Flashing Time (Booting + Erase + Flashing) : 00:06:19
    FlashInfo.RestartMode : 2
    Waiting for Phone to Go Online...
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    MCU Version: V 07.97 13-09-10 RM-495 (c) Nokia
    IMEI Plain : 355232033730086
    IMEI Spare : A355232033730080
    IMEI SV : 33552320337300858F
    Phone Model: Nokia 5130c-2
    Product Serial Number: IBX011802
    Product Code : 0578115
    Module Code : 0204024
    Basic Production Code: 0567772
    Default SN Type : 0
    MCU SW Version : V 07.97 13-09-10 RM-495 (c) Nokia V
    BT MCM Version : 2222-302
    PPM Version : V 07.97 13-09-10 RM-495 (c) Nokia
    HW Version : 2000
    RFIC Version : 06540601
    DSP Version : ICPR72_10w01
    LCD Version : SEIKO
    Content Pack Version : Content: v_red V 07.97 13-09-10 RM-495 (c) Nokia
    AHNE Version : 30
    Retu Version : 16
    Tahvo Version : 22
    ******** Reading SimLock ********
    Unable to read SP Data..
    Elapsed Time: 1s
    Elapsed Time: 2s
    Elapsed Time: 3s
    Elapsed Time: 4s
    Elapsed Time: 5s
    Elapsed Time: 6s
    Elapsed Time: 7s
    Elapsed Time: 8s
    Elapsed Time: 9s
    Elapsed Time: 10s
    Default SN Type : 0
    HW Version : 2000
    LCD Version : SEIKO
    AHNE Version : 30
    Retu Version : 16
    Tahvo Version : 22
    SECURITY_TEST : PASSED
    SECURITY_CODE : 12345
    PHONE_MODE : TEST MODE
    Dynamic Camera Configuration
    DCC ID : NIMMIIIIRRFF094B2F01
    DCC Ver: 002009
    Status : OK
    FACTORY SET TO : Full Factory Set
    OK
    FACTORY SET TO : User Data
    OK
    FACTORY SET TO : Leave Factory
    OK
    FACTORY SET TO : Service Center
    OK
    FACTORY SET TO : Software Upgrade
    OK
    FACTORY SET TO : Production Tune
    OK
    RESET LIFE TIMER TO : 0000:00
    OK
    mở nguồn contaservice sin anh em cho y kiến với
    lập thraed mới không spam bài khác
    Thành viên tích cực v&tmobile's Avatar
    Ctythegioididong
    che chân Vbb lại đi bro .
  6. ( v&tmobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    May 2010
    ĐIỆN BIÊN
    che chân vpp đi flash lại nhé.hoặc đánh dấu vào mục cnt auto và chạy lại >>>done
    TRUNG HIẾU MOBILE
  8. ( QUANGTRUNG_GSM ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    V.I.P viethuy_mobi's Avatar
    Dec 2009
    lỗi ko đồng bộ dc
    che chân vpp này lại
    rùi xóa flash +flash lại +writer file pm + unlook đo bạn
    yahoo: viethuy_mobi
  10. ( viethuy_mobi ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #7
    Nov 2011
    che chân VPP chạy lại ok. thanks all
  12. #8
    Feb 2011
    thanh hóa
    trước tiên bạn kiểm tra 4 chân < ok đả > xong lắc nhẹ uem xong bỏ vào chek => chek ok mà info ko ok thì bạn xóa hết nạp lại |+ wer pm + unlok =. ok 100%
    chúc bạn thành công
    call :0976 001 628
  13. #9
    Thành viên mới gsm-tg's Avatar
    Oct 2011
    Trích Được post bởi viethuy_mobi Xem bài viết
    lỗi ko đồng bộ dc
    cái nầy là chính xác ,mình đã gặp và đã thành công khi che chân vpp rồi chại lại.
  14. #10
    V.I.P ThanhHai_GSM's Avatar
    đã ok Close
  1. 1200 chạy lổi
    By ANH_MOBILE in forum DCT4 - WD2
    Bài viết cuối: 17-02-2012, 11:38
  2. Trả lời: 14
    Bài viết cuối: 15-08-2011, 20:58
  3. 1200 chạy fần mềm ko được
    By hoanghoatham in forum DCT4 - WD2
    Bài viết cuối: 05-06-2009, 14:38
  4. 1200 chạy chậm,có sóng mà ko gọi dc
    By IC.NGUON in forum DCT3-DCTL
    Bài viết cuối: 07-05-2009, 18:11
  5. Trả lời: 2
    Bài viết cuối: 21-04-2009, 09:25
