Kết quả 1 tới 10 của 19
    Thành viên chính thức truckaka's Avatar
    Mặc định ae xem giùm em cái log 6300 by mx key
    cây 6300 bị mã bảo vệ.flash cho em nó mất nguồn luôn.đây là log mx key.ae xem giúp.
    MXKEY Serial: [FT SCR2000 0] - C0805A85
    Connection status: EHCI:HUB:HUB:HUB:USB 1.10 (Full-speed)
    Driver: UFS2XX, ver: 3.8.14.0 , NTMP ver: 2.8.14.0
    Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
    Processing MCU file: rm217__07.30.mcusw
    [BB5,BB5 ALGORITHM] size: 14.50 MB
    Supported Ids: 0103192101001101, 010C192101001101
    CMT Data :
    EM0 ID: 00000232
    EM1 ID: 00000353
    PUBLIC ID: 0AD00115A4F06D56503F3039A6374D4A2CA7BCDD
    ASIC MODE ID: 00
    ROM ID: 191EC665DFAAF68F
    SecondaryBoot: RAP3Gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
    eBB5ProtocolType: OLD
    Storage0: 00EC 2208 - 0000 6921 [Samsung K8F5615ETM,256 Mbits] type: FLASH,NOR, asic:CMT
    TransmissionMode: 16Bit
    TransmissionMode: DDR&TX2
    Storing certificate [NPC, VARIANT, R&D] ...OK
    Erase size: 16.37 MB
    CMT FLASH,NOR area [00000000-000006BF] erased in 0.414 s
    CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.111 s
    CMT FLASH,NOR area [00020000-0007FFFF] erased in 1.133 s
    CMT FLASH,NOR area [00080000-000DFFFF] erased in 0.161 s
    CMT FLASH,NOR area [00100000-001FFFFF] erased in 0.303 s
    CMT FLASH,NOR area [00200000-0031FFFF] erased in 3.301 s
    CMT FLASH,NOR area [00320000-0105FFFF] erased in 37.588 s
    CMT FLASH,NOR area [01060000-01067FFF] erased in 0.430 s
    CMT FLASH,NOR area [01068000-0107FFFF] erased in 0.110 s
    Prog.status for Asic CMT ...
    NOR: Success
    Flash programming ...
    CMT NOLO block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    Error chk C7012D0103CD000010000000F1
    RX2 not responding, please check BSI/cable/pinout !
    Error while programming [00] at 0x00029300, Result: 0010
    Task failed at (0800001C)!!!
    Last RX buffer: C7 01 2D 01 03 CD 00 00 10 00 00 00 F1 72
    Khi ta không lấy vợ nghĩa là ở đâu đó trên quả đất này có một người phụ nữ đang sống hạnh phúc do không được làm vợ ta
    Thành viên chính thức thanhloan182's Avatar
    Bạn kiếm cáp chuẩn không đem qua box khác
    Máy mã bảo vệ thì factory là ok sao phải flash
  3. ( thanhloan182 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    truckaka (14-11-2011)
    Thành viên tích cực gamoi.gsm's Avatar
    Jul 2011
    mã bảo vệ sao phải flash lại bạn.chay ver cao hơn xem sao hoăc chạy usb
    yah:Gamoi_gsm@yahoo.com.vn
  5. ( gamoi.gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    còn đây là log hwk.(bây giờ bật nguồn lên chỉ sáng 2 đèn bên hông)
    1ST BOOT : C0,07 [Rm-217] [2.2.0.0]
    CMT ASICID: 000000010000022600010006010C192101001101
    EM 1 ID : 00000232
    EM 2 ID : 00000353
    CMT PUBID : 0AD00115A4F06D56503F3039A6374D4A2CA7BCDD
    CMT MODE : 00
    CMT HASH : BAF3A9C3DBFA8454937DB77F2B8852B1
    CMT ROMID : 191EC665DFAAF68F
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
    CMT FLID0 : 00EC2208-00006921, Sam K8F5615ETM
    CMT FLCNT : 00000000000000000000000000000000000000
    CMT MCID0 : FFFF0000-00000000
    CMT 2ND Boot OK
    CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
    CMT KSIG0 : 7F7E6491E8D30494B45630BB3A8599F4E1C674C9
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    IMAGE : rm217__07.30.mcusw
    CMT NOR Erase Area: 0x00000000-000006BF
    CMT NOR Erase Area: 0x000006C0-0001FFFF
    CMT NOR Erase Area: 0x00020000-0007FFFF
    CMT NOR Erase Area: 0x00080000-000DFFFF
    CMT NOR Erase Area: 0x00100000-001FFFFF
    CMT NOR Erase Area: 0x00200000-0031FFFF
    CMT NOR Erase Area: 0x00320000-0105FFFF
    CMT NOR Erase Area: 0x01060000-01067FFF
    CMT NOR Erase Area: 0x01068000-0107FFFF
    CMT FLASH ERASE OK, Time: 00:24
    Written: 10 Certificate(s)
    CMT FLASH WRITE OK, Time: 02:46
    Chip SECTOR_SIZE: 128k
    Warning, Must be Used 128Kb Sector_Size CNT File
    CONVERSION: Already 128K Paged Source
    IMAGE : rm217__07.30.image_v_socola_128
    CMT NOR Erase Area: 0x01600000-01FDFFFF
    CNT FLASH ERASE OK, Time: 00:03
    CNT FLASH WRITE OK, Time: 01:04
    IMAGE : rm217__07.30.ppm_v_****
    CMT NOR Erase Area: 0x01080000-015FFFFF
    PPM FLASH ERASE OK, Time: 00:01
    DATA_BLK_ERROR at: 0x01230000, 00
    ERR: PPM FLASH WRITE D_BLK 000000000000000910000000B172, LN: 0x004000, Time: 00:24
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Xem lại cáp,ko được chuyển USB,chuyển luôn Box khác chạy lại
  8. ( thuyet_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    May 2011
    Hà Nội City
    mã bảo vệ không cần chạy lại nhé
    bạn chuyển chế độ localmode hoặc test mode rùi factoryset cho dòng bb5 là done như 6300 thì ok
    còn bây giờ là lỗi plash có thể do cáp hoặc do ver
    bạn lấy ver cao nhất về rùi thay cáp khác chạy lại + factoryset xem thế nào
    chúc thành công
  10. ( ĐẶNG BẢO_GSM™ ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  11. #7
    Thành viên tích cực ngoc151na's Avatar
    Apr 2011
    sáng đèn bên hông- chắc thiếu áp vcore rồi...
    GIA HU: dechcanyeudetienuongruou151
  12. ( ngoc151na ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  13. #8
    bởi mới đầu bõ vào box hwk fatory kg đc nên chạy luôn.ai ngờ lại bị mất nguồn.bõ qua mt chạy vẫn báo lỗi
  14. #9
    file 7.30 này là chuẩn rùi.đã chạy nhiều cây ok.không biết cây này sao nửa.anh nào biết cách backup pull 6300chỉ em vói để em xóa full chạy lai thử đc kg.
    yahoo:thanhtrucmobi
  15. #10
    Thành viên chính thức tienbaodhhh's Avatar
    Dec 2007
    chạy băng cáp USB cho nhanh ô a
    học học nữa học mãi
  16. ( tienbaodhhh ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. nhờ anh em xem giùm cái log 6300?
    By NHC_2010 in forum BB5
    Bài viết cuối: 03-03-2012, 20:14
  2. anh em sem giùm cái log 6300
    By THẢO-GSM in forum BB5
    Bài viết cuối: 10-12-2011, 23:25
  3. anh xem giùm em cái log 6300
    By linhsaker in forum BB5
    Trả lời: 13
    Bài viết cuối: 03-11-2011, 17:33
  4. Trả lời: 5
    Bài viết cuối: 20-04-2011, 11:39
  5. Trả lời: 18
    Bài viết cuối: 09-07-2010, 17:03
