    Thành viên tích cực hoangphiz3's Avatar
    Nov 2011
    Mặc định 1680c-2 không nhận đăng ký sim
    mới nhận cây 1680c-2 không nhận đăng ký thẻ sim . mình đả fash lại
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C085CF97
    Using device: HTI, FW ver: 00.50, SN: 00015E67
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13682(17-12-2011)
    Rpl backup already exist (C:\mobileEx\3.5\data\backup\35678202899590_BACK.r pl).
    Processing MCU file: rm394__07.60.mcusw
    [DCT4,DCT4 ALGORITHM] size: 10.19 MB
    Supported Ids: 3160, 3161, 3162, 3164, 3166
    ASIC ID: 0x3162 [UPP_8M ver: 6.2]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 0001 317E [AMD S29NS256P,256 Mbits] page size: 128 K type: NOR area: 01000000-02FFFFFF - COMBO FLASH
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u3_amd.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x78C0
    UEM ID: 00811AB6:3B8ADA60
    Area [01000000-0101FFFF] erased in 0.485 s
    Area [01020000-01C3FFFF] erased in 53.938 s
    Flash programming ...
    Programming completed in 3 min 23.109 s
    File Processed in 4 min 25.297 s
    Processing CNT file: rm394__07.60.image_v
    [DCT4,DCT4 ALGORITHM] page size: 128 K size: 4.63 MB
    ExtBUSC: AD7E B61B 00FF 1040 0000 0000 0000 0000
    UEM ID: 00811AB6:C5A4DA78
    Area [02000000-02DBFFFF] erased in 1 min 9.031 s
    Area [02DC0000-02F9FFFF] erased in 9.156 s
    Converting UCP blocks to 128 K.
    Programming completed in 1 min 32.734 s
    Extracting Content Pack, (c) Nokia File Server
    Content Pack extracted successfully in 0.156 s
    File Processed in 3 min 14.235 s
    Processing PPM file: rm394__07.60.ppm_v
    [DCT4,DCT4 ALGORITHM] size: 3.10 MB
    UEM ID: 00811AB6:2984DA60
    Area [01C40000-01FFFFFF] erased in 17.125 s
    Programming completed in 1 min 3.281 s
    File Processed in 1 min 28.156 s
    Total time for flashing process(boot+erase+write) was 9 min 7.703 s
    Phone type: RM-394 (Nokia 1680c-2)
    SW version: V 07.60 10-04-09 RM-394 (c) Nokia
    Imei plain: 35678202899590-3
    Imei OTP: 35678202899590
    Product code: 0560372
    Cellular system: GSM
    ASIC ID: 0x3162, type: 11
    Ppm Id: V
    Language Pack:
    - not available.
    Master code: 5130031773
    Imei net: 35678202899590
    Version: SIMLOCK SERVER
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 800000000001000B
    FULL FACTORY... OK
    USER DATA... OK
    LEAVE FACTORY... OK
    SERVICE CENTER... OK
    SOFTWARE UPGRADE... OK
    PRODUCTION TUNING... OK
    Reset User Code (to default:12345) ... OK
    Completed in 1.031 s
    mình mới vào nghề nhờ ae xem giúp thanks ae .....!
    Moderator TÚ CÒI's Avatar
    hà nội
    Phần mêm ko liên quan gì cả
    Coi lại khay sim trước đi bạn(lỏng á)
    -->ic sim
    Thành viên mới Nam_kho_mobile's Avatar
    Feb 2012
    coi lại điều khiển sim đi mình cũng gặp pan này rồi... chạy đi chạy lại cuối cùng thay em khiển sim = done
    Thành viên kỳ cựu phamdienmobile's Avatar
    biên hòa - đồng nai
    dòng này câu tắt được mà bạn !? 3 cọng dây đồng thôi mà câu y hệt như những dòng máy DCT4 thôi
    Moderator VanTuan-ST's Avatar
    Sóc Trăng
    Coi lại khay sim, ic sim , tiếp xúc sim ko được tháo ic sim ra câu 3 cọng dây đồng là ok.
    Nov 2011
    ok để mình làm rồi sẽ báo cáo lại cho ae...
  1. Trả lời: 3
    Bài viết cuối: 29-05-2013, 10:38
  2. 1680c ko nhân đăng ký thẻ sim
    By ngocthu2208 in forum DCT4 - WD2
    Bài viết cuối: 28-12-2011, 12:46
  3. Trả lời: 5
    Bài viết cuối: 26-11-2011, 17:49
  4. Trả lời: 4
    Bài viết cuối: 25-11-2011, 12:33
  5. Trả lời: 3
    Bài viết cuối: 02-02-2010, 11:40
