    Thành viên tích cực hungmobile_90's Avatar
    Mặc định 1110i thay uem có ván dè xin gjup
    EM DANG GẠP CON 1110I CHẠM IC NGUỒN EM THAY UEM KHÁC MÁY LEN NGUỒN RÒI NHUNG KO SAO VIÉT DUỌC IMEKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0806F42
    Using device: HTI, FW ver: 00.50, SN: 00010605
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
    Processing MCU file: rh93_07.020
    [DCT4,DCT4 ALGORITHM] size: 1.89 MB
    Supported Ids: 0120, 0121, 1021, 1120, 1130, 1131, 1201, 2140, 2142, 2201, 2031, 2030, 2032, 2033
    ASIC ID: 0x2201 [UPP_2M ver: 2]
    SecondaryBoot: u_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A0
    Supported Ids: 0011, 0010, 0121, 0120, 1120, 1131, 1130, 2141, 2140, 2142, 2151, 1141, 1181, 1015, 1021, 2031, 2030, 3041, 1201, 2201, 2291, 3161, 3160, 3164
    FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Algorithm: u_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x5690
    UEM ID: 0086072F:2984DA60
    Area [01000000-0100FFFF] erased in 0.546 s
    Area [01010000-013BFFFF] erased in 31.000 s
    Area [013C0000-013EFFFF] erased in 1.704 s
    Area [017C0000-017EFFFF] erased in 0.015 s
    Area [01FC0000-01FEFFFF] erased in 0.031 s
    Flash programming ...
    Programming completed in 15.968 s
    File Processed in 56.156 s
    Processing CNT file: rh930_nai7.02md
    [DCT4,DCT4 ALGORITHM] size: 163.08 KB
    Area [01380000-013BFFFF] erased in 2.297 s
    Programming completed in 1.360 s
    Content extract fail, continue anyway ...
    File Processed in 14 min 14.250 s
    Processing PPM file: rh93_07.02md
    [DCT4,DCT4 ALGORITHM] size: 1.50 MB
    Area [011E0000-011EFFFF] erased in 0.515 s
    Area [011F0000-0137FFFF] erased in 13.110 s
    Programming completed in 12.656 s
    File Processed in 34.047 s
    Total time for flashing process(boot+erase+write) was 15 min 44.453 s
    V.I.P ThanhHai_GSM's Avatar
    mxkey nhiều khi sever lỗi khó nạp
    có hwk cho vào nạp ofline chỉ 1 nốt nhạc là xong http://saigonmobile.vn/forum/phan-me...k-rpl-hwk.html
    Feb 2011
    thanh hóa
    110i jaf củng giải quyết đc mà you niếu bạn có
    call :0976 001 628
    Thành viên chính thức truong25071990's Avatar
    Dec 2011
    có chương trình gửi file đó bạn dowload về thử xem được ko
    Power on the phone...
    FAILED... jap cũng báo lỏi thế dáy ag nan
    V.I.P nhanvnn's Avatar
    Như Xuân_Thanh Hóa
    có nhiều con UEM khi thay vào bản thân nó đã bị lổi nên nhiều khả năng như vậy mà bạn ko đổ đc IMEI, bạn dùng MX key bus check nếu thấy có dong thông báo
    UEM : empty tức là con UEM này lổi nên thay con khác ko thì có đổ log đến sang năm.
    hoặc nếu trường hợp UEM tốt thì bạn kiểm tra lại tiếp xúc pinout, cáp, BSI và che chân VPP lại , 1 trong các cách trên = 100% ok
    có hwk la done mx nhieu khi chuối cả buồng
    Thành viên mới totite's Avatar
    Jun 2007
    mấy con này tơi tả lắm rồi, gở u, uem, flash, đóng lại cho thông mạch trước đi, rồi tính tiếp...............................
  1. 1110i thay dao dộng mất nguồn
    By thanglong in forum DCT4 - WD2
    Trả lời: 16
    Bài viết cuối: 24-07-2012, 21:42
  2. 1110i thay pa mất giao động
    By tuân gsm in forum DCT4 - WD2
    Bài viết cuối: 10-07-2011, 21:02
  3. 1110i thay ic nguồn
    By cuongiphone in forum DCT4 - WD2
    Bài viết cuối: 24-08-2010, 10:25
  4. thay đèn led màn hình 1110i
    By lilkentdy in forum DCT4 - WD2
    Bài viết cuối: 03-07-2010, 09:55
  5. 1110i can gjup d0
    By v0danh_hand0j in forum DCT4 - WD2
    Bài viết cuối: 19-05-2009, 22:10
