Kết quả 1 tới 4 của 4
    Thành viên kỳ cựu madao's Avatar
    Mặc định 6230i xin giúp
    mình vừa mới nhận con 6230i mất nguồn.mình cho vào mx nạp lại phầm mềm thì nó báo thế này:
    Using device: HTI, FW ver: 00.50, SN: 00009704
    Driver: WinUSB, ver: 3.5.0.0
    Module ver: 1.0.0.19663(13-12-2011), Library ver: 1.0.0.13672(13-12-2011)
    Processing MCU file: rm72_73_11003.880
    [TIKU BT2,TIKU ALGORITHM] size: 10.14 MB
    Supported Ids: 1052, 2051
    ASIC ID: 0x2051 [TikuEdge ver: 2.0]
    SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
    Supported Ids: 1051, 1052, 2051
    FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
    FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M)
    FlashID2: 0000 0001 [unused/removed]
    FlashID3: 0000 0001 [unused/removed]
    ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
    Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
    UEM ID: 00A41F20:8615DA60
    Area [00000000-0000FFFF] erased in 0.375 s
    Area [00010000-009FFFFF] erased in 1 min 3.859 s
    Area [00A00000-00B3FFFF] erased in 7.953 s
    Area [00B60000-00FAFFFF] erased in 27.609 s
    Flash programming ...
    Programming completed in 1 min 18.032 s
    File Processed in 3 min 8.032 s
    Processing CNT file: rm72_73_110M_03.88.ucp_V
    [TIKU BT2,TIKU MON CSM] size: 3.92 MB
    Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660
    Mass Memory Storage Device detected.
    Configuring MM bus ...
    Formating partition ...OK
    Opening MM device ...
    Erasing disks ...OK
    The semaphore timeout period has expired
    Error while programming [2E] at 0x01000020, Result: 0000
    flashing terminated !
    rất mong anh chị em giúp giùm một tay
    còn đây la lock mình chạy bàng jaf:
    Getting MCU ID
    MCU ID: 0x2051
    FLASH ID0: 22E800EC <=> SAMSUNG (SEC) -> K5G2829ATC Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 001000EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
    FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-72\
    Scanning for ini files...
    INI file .ini is missing. Continue searching for second ini type...
    Changing flashing settings...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.880
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88A
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88.ucp_A
    Languages in ppm: English,Finnish,Swedish,Danish,Norwegian,German,Ic elandic
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_11003.880
    Booting phone...
    MCU ID: 0x2051
    BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
    Loader version: 04.4C.00 -> Revision: 0007
    Boot size is 0x2398
    Boot is ready...
    Flash ID is 0x22E800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
    Loader size is 0x84D8; Loader chk: 28
    Loader is ready...
    MSID: 84DB0566919FB69DFFAB35B08F
    MSID decoded: 91DFBAE900A41F20A8000000
    FAID: C43C7B56570D53F90250717F
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 009FFFFF...
    Erasing area: 00A00000 - 00B3FFFF...
    Erasing area: 00B60000 - 00FAFFFF...
    Operation took 1 minutes 39 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 1 minutes 0 seconds...
    Restarting MCU...
    NAND Format OK!
    CNT: C:\Program Files\Nokia\Phoenix\Products\RM-72\rm72_73_110E_03.88.ucp_A
    Booting phone...
    MCU ID: 0x2051
    Boot size is 0x2398
    Boot is ready...
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_essr.fia
    Loader size is 0x9868; Loader chk: 4d
    Loader is ready...
    Erasing Content Pack...
    Mass Memory Device Detected...
    MM Bus Configured...
    Formating MM...Format failed!
    Thành viên mới 1quachuoi9's Avatar
    Nov 2011
    Ninh Thuận
    Bạn thử nạp 1 file CNT tc thôi nếu EXtract đc thì nạp thêm 2 file nữa mấy dòng này hay lỗi khi Extract lắm.nếu có CYCLONE thì nạp thẳng lun ok còn k0 thì làm thủ công như thế hơi lâu tý co ÚIiittttiinngg fail cũng lên nguồn bỏ pin vào máy mở lên rồi wa HWK ìno UL fats nữa Done thôi. mình đã test 2 3 cây rồi. Good Luck !
    thanks ban để mình lam phát thư coi
  1. xin giúp 6230i mất mic
    By trimobile09 in forum DCT4 - WD2
    Bài viết cuối: 14-11-2010, 14:33
  2. 6230i cần giúp!!!
    By cuocsongmoi in forum DCT4 - WD2
    Bài viết cuối: 08-05-2010, 13:39
  3. 6230i cần giúp!
    By huynhthanhviet_mobile in forum DCT4 - WD2
    Bài viết cuối: 05-02-2010, 23:56
  4. 6230i cần giúp.
    By minh van in forum DCT4 - WD2
    Bài viết cuối: 17-06-2009, 10:09
  5. giúp 6230i !
    By danhtin2006 in forum DCT4 - WD2
    Bài viết cuối: 31-08-2007, 17:28
