*# 06 # Seriennummer/IMEI indicates (actually also a GSM is code - see further below)
*# 0000 # SW version announcements (e.g. V3.42.1, 16-10-03, Nhl-10)
*# 2820 # Bluetooth (BT) device address indicate
xx # Directory quick access (xx = storage location and afterwards lozenge e.g. 24 #)
[hide]A/from key Short pressing for menu for switching between profiles
Menu key Long pressing for "task manager" - switching between active programs (with "C" key programs can be terminated.)
Menu quick access Over in the menu e.g. to point 3.1 arrive simply 31 enter (if the third symbol a file is opened is for these and then in it started the first Programm/Icon).
Autostart go around When switching on of the Handys on to the pin inquiry the key "ABC" (pin) comes the whole time keeps pressed - this is to ignore (allegedly) the autoinitialization programs.
# Do not switch between different lines (AS)... goes e.g. with Austrian ONE Handys (see nose cunning). I could not try out however also, since I did not have 2 lines on the SIM map.
12345 ... is according to standard set the Nokia nokia-Sicherheitscode.
0000 ... is according to standard those (with Vodafone windshield frame section) set 2te pin and that standard net code/password
With D1 the standard net code is the last 4 numbers of the card number without HLR e.g. 99999234-5/55 - > 2345
0 - for a long time press If one the "0" in the main menue for a long time presses those homepage of the standard WAP connection is called.
Caution - starting from here the codes are "dangerous"
*#7370925538#
* # of res wallet # ... is to be deleted the code around the "wallet"! Input like normal telephone number (not in wallet code inquiry windows).
NOTE! Afterwards the "wallet" is empty, can again be put on however with new code.
*# 7780 # The "original attitudes" and telephone re-establishes is again started (an appropriate inquiry and it follow before must the sicherheitscode be entered).
NOTE! Afterwards various "attitudes" are away - among other things these:
·1 Points of entrance (Provider dependent points of entrance and attitudes)
·2 Bluetooth attitudes
·3 Favorite
·4 Allocation of the two keys (beside Navi keys) in the main menue
·5 Profiles are "neglected" (as with distribution) - still there however new bell tones, etc. are...
·6 SMS/MMS/E Mail attitudes
·7 Logos and spielstaende (allegedly) also deleted...
Programs, calendars and contacts, etc. not changed...
Also the sicherheitscode remains.
This putting back goes also via menu under "attitudes - general - original telephone once.".
*# 7370 # Soft format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a software RESET. (however still another inquiry comes before.)
NOTE! If the Akku to 75% are loaded at least, Akku do not only accomplish during the procedure under any circumstances remove! The procedure takes some minutes (approx. 3-4), is absolutely waiting!
This is "only" a soft format... Hard format with "green, 3, *"... see below.
Green, * 3 Hard format: If the Handy (only telephone memory) formats, puts back the attitudes (see * to # 7780 #) and implements a RESET.
Proceeding: Equipment switch off, which keep "green key" (take off) at the same time pressed, "*" and to "3" key and switch the equipment on (the keys thereby keep further pressed)... to "Formatting" on the display appears...
If that does not function, then equipment for 1 hour switch off, Akku so for a long time rausnehmen and again try.
"only" virtual the memory is generally cleared - genuine formatting can take place only in a Nokia service center, if the Fash is deleted there and/or new L.G. is installed.
Mixed * # 92702689 #, then switch - system menu off (goes with me not)
The following code do not fold (with me also):
* EFR0 # (* 3370 #) EFR activate (EFR = Enhanced Full rate Coding - language optimization)
# EFR0 # (# 3370 #) EFR switch off
* HRC # (* 4720 #) HRC switch on (HRC = helped rate Coding - language compression)
# HRC0 # (# 4720 #) HRC switch off
SIM LOCK Simlock status query: (use "*" the key over "p,w" and "+" indications to enter)
# pw+ 1234567890 +1 # Provider LOCK status
# pw+ 1234567890 +2 # network LOCK status
# pw+ 1234567890 +3 # Country LOCK status
# pw+ 1234567890 +4 # Sim Card LOCK status
The code 1234567890 must be computed with a program e.g. SmartDCT4Calc and/or DCT 4 code Calculator from IMEI, etc....
Info. to Simlock: SIM LOCK makes it for the offerer/network carriers possible, subsidized (verguenstigte) Handys to offer. Thus one makes oneself if necessary punishable if one SIM LOCK deactivated - in addition the warranty can purged. I take over for it no adhesion or responsibility!
GSM code ... should function at each Handy - however Netz(betreiber)abhaengig are... and "harmless"...
Generally applies: First enter code, "send" afterwards (< send green key > press) and one moment wait...
SMS Tipps To Tipps & cheat about SMS (with appropriate codes) are immediately in the FAQ list .
For example for the topic: SMS "retard" and/or deferred send, acknowledgment of receipt, reports...
Mark more simply To Tipps & cheat to the topic "mark" e.g. with SMS entrance.
Over simply to mark simply the "pin" (ABC key) hold some e.g. SMS and move then Jostick downward.
Call number transmission * 31 # - { CLIR - Calling LINE identification Restriction switches on for the general call number transmission }
# 31 # - switch off the general call number transmission
# 31 # [ telephone number ] - with the next call suppress the own call number (thus temporary)
* 31 # [ telephone number ] - with the next call transfer own call number (thus temporary)
* # 31 # - status query (of call number transmission)
# 31 * [ telephone number ] - own call number show, although receiving station switched call number suppression on. (is not usually de-energised of the Netz(betreiber).)
* 30 # - switch { TIE-clip - Calling LINE identification presentation for the announcement on of the call number of the caller }
# 30 # - switch off
* # 30 # - status query
