Mình đả repair sd,super sd,sx4 mà vẩn chưa được,ae xem giùm qua trình làm có gì thiéu sót không?xin chỉ giáo
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0855593
Using device: HTI, FW ver: 00.50, SN: 000163A1
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.19815(08-01-2012), Library ver: 1.0.0.13716(10-01-2012)
Phone type: RM-237 (Nokia 3110c)
SW version: V 07.30 07-05-09 RM-237 (c) Nokia.
Using cached productData.
PUBLIC ID: 24600206050A7E56E8B973DD927526D7A7003441
PRIVATE ID: F48BACA687FF00FA2339DDEB73B8991F2E733160
Updating SUPERDONGLE_KEY ...OK
Authenticating to SUPERDONGLE ...
SUPERDONGLE authorized!
Writing RFBB data: modules\{3EBAF427-9F55-419F-8A75-385DFC651169}\def\rfbb\3110c_RM-237.txt ...
Writing RF settings to phone ...OK, finished. 12 Records found.
Writing BB settings to phone ...OK, finished. 9 Records found.
Done.
Phone authenticated to SUPERDONGLE already.
Scanning local SX4 Card ...
No SX4 Card found.
SERVER->MXKEY - BLADE X at host2, agent version 1.2 revision 0.3
Authenticating using [MX] security server ...
Connecting to server[main.mxkey.biz] ...Connection timed out
Connecting to server[main.mxkey.biz] ...Wrong response to SD verify request
Retrying ...
Authenticating using security server ...
Connecting to server[main.mxkey.biz] ...MXKEY SX4CARD - ID, hello 171.226.4.178
Bad phones ack, probably SUPERDONGLE_KEY corrupted !
Retrying ...
Done.
Writing PM from Node ...
Section: 1
Warning: failed to write 1 - 0 (114 bytes)
Warning: failed to write 1 - 2 (98 bytes)
Warning: failed to write 1 - 4 (110 bytes)
Warning: failed to write 1 - 6 (98 bytes)
Warning: failed to write 1 - 8 (110 bytes)
Warning: failed to write 1 - 13 (98 bytes)
Warning: failed to write 1 - 16 (86 bytes)
Warning: failed to write 1 - 18 (86 bytes)
Warning: failed to write 1 - 20 (86 bytes)
Warning: failed to write 1 - 25 (4 bytes)
Warning: failed to write 1 - 29 (6 bytes)
Warning: failed to write 1 - 34 (80 bytes)
Section: 2
- Key: 0, size 432 bytes written.
Section: 4
- Key: 0, size 1 byte written.
- Key: 1, size 64 bytes written.
- Key: 3, size 10 bytes written.
- Key: 4, size 8 bytes written.
- Key: 5, size 8 bytes written.
- Key: 6, size 8 bytes written.
- Key: 9, size 5 bytes written.
- Key: 18, size 80 bytes written.
- Key: 19, size 4 bytes written.
Section: 8
- Key: 0, size 12 bytes written.
- Key: 1, size 12 bytes written.
- Key: 2, size 128 bytes written.
- Key: 3, size 128 bytes written.
- Key: 6, size 4 bytes written.
- Key: 7, size 8 bytes written.
Section: 11
- Key: 0, size 4 bytes written.
- Key: 1, size 4 bytes written.
- Key: 2, size 4 bytes written.
- Key: 3, size 4 bytes written.
- Key: 4, size 1 byte written.
- Key: 5, size 6 bytes written.
- Key: 6, size 2 bytes written.
- Key: 7, size 1 byte written.
- Key: 8, size 1 byte written.
- Key: 9, size 1 byte written.
- Key: 10, size 1 byte written.
- Key: 11, size 1 byte written.
- Key: 12, size 1 byte written.
- Key: 13, size 1 byte written.
- Key: 14, size 2 bytes written.
- Key: 15, size 2 bytes written.
- Key: 16, size 2 bytes written.
- Key: 17, size 2 bytes written.
- Key: 18, size 16 bytes written.
- Key: 19, size 32 bytes written.
- Key: 20, size 32 bytes written.
- Key: 21, size 2 bytes written.
- Key: 22, size 2 bytes written.
- Key: 23, size 2 bytes written.
- Key: 24, size 2 bytes written.
- Key: 25, size 2 bytes written.
- Key: 26, size 2 bytes written.
- Key: 27, size 2 bytes written.
- Key: 28, size 2 bytes written.
- Key: 29, size 2 bytes written.
- Key: 30, size 2 bytes written.
- Key: 31, size 2 bytes written.
- Key: 32, size 2 bytes written.
- Key: 33, size 2 bytes written.
- Key: 34, size 2 bytes written.
- Key: 35, size 2 bytes written.
- Key: 36, size 2 bytes written.
- Key: 37, size 2 bytes written.
- Key: 38, size 2 bytes written.
- Key: 39, size 2 bytes written.
- Key: 40, size 2 bytes written.
- Key: 41, size 2 bytes written.
- Key: 42, size 2 bytes written.
- Key: 43, size 2 bytes written.
- Key: 44, size 2 bytes written.
- Key: 45, size 2 bytes written.
- Key: 46, size 2 bytes written.
- Key: 47, size 2 bytes written.
- Key: 48, size 2 bytes written.
- Key: 49, size 2 bytes written.
- Key: 50, size 2 bytes written.
- Key: 51, size 2 bytes written.
- Key: 52, size 2 bytes written.
- Key: 53, size 2 bytes written.
- Key: 54, size 2 bytes written.
- Key: 55, size 2 bytes written.
- Key: 56, size 2 bytes written.
- Key: 57, size 2 bytes written.
- Key: 58, size 2 bytes written.
- Key: 59, size 2 bytes written.
- Key: 60, size 2 bytes written.
- Key: 61, size 2 bytes written.
- Key: 62, size 2 bytes written.
- Key: 63, size 4 bytes written.
- Key: 64, size 1 byte written.
- Key: 65, size 4 bytes written.
- Key: 66, size 4 bytes written.
- Key: 67, size 4 bytes written.
- Key: 68, size 4 bytes written.
- Key: 69, size 16 bytes written.
- Key: 70, size 4 bytes written.
- Key: 71, size 2 bytes written.
- Key: 72, size 13 bytes written.
Section: 12
- Key: 0, size 102 bytes written.
Section: 13
- Key: 1, size 2 bytes written.
- Key: 2, size 1 byte written.
- Key: 3, size 2 bytes written.
- Key: 5, size 1 byte written.
- Key: 6, size 1 byte written.
- Key: 8, size 2 bytes written.
- Key: 11, size 48 bytes written.
- Key: 12, size 4 bytes written.
- Key: 14, size 1 byte written.
- Key: 15, size 886 bytes written.
- Key: 17, size 1 byte written.
- Key: 18, size 1 byte written.
- Key: 19, size 8 bytes written.
- Key: 20, size 1 byte written.
- Key: 21, size 1 byte written.
- Key: 22, size 1 byte written.
- Key: 23, size 1 byte written.
- Key: 24, size 1 byte written.
- Key: 26, size 1 byte written.
- Key: 27, size 1 byte written.
- Key: 28, size 1 byte written.
- Key: 29, size 1 byte written.
- Key: 30, size 1 byte written.
- Key: 31, size 1 byte written.
- Key: 32, size 1 byte written.
- Key: 33, size 1 byte written.
- Key: 34, size 1 byte written.
- Key: 35, size 1 byte written.
- Key: 36, size 1 byte written.
- Key: 37, size 4 bytes written.
- Key: 38, size 1 byte written.
- Key: 39, size 1 byte written.
- Key: 40, size 1 byte written.
- Key: 41, size 1 byte written.
- Key: 42, size 4 bytes written.
- Key: 43, size 4 bytes written.
- Key: 44, size 1 byte written.
- Key: 45, size 4 bytes written.
- Key: 46, size 4 bytes written.
- Key: 47, size 1 byte written.
- Key: 48, size 4 bytes written.
- Key: 49, size 1 byte written.
- Key: 50, size 1 byte written.
- Key: 51, size 1 byte written.
- Key: 53, size 4 bytes written.
- Key: 54, size 4 bytes written.
- Key: 55, size 1 byte written.
- Key: 56, size 1 byte written.
- Key: 57, size 1 byte written.
- Key: 59, size 1 byte written.
- Key: 60, size 4 bytes written.
- Key: 61, size 4 bytes written.
- Key: 62, size 1 byte written.
- Key: 64, size 4 bytes written.
- Key: 65, size 1 byte written.
- Key: 68, size 1 byte written.
- Key: 69, size 1 byte written.
- Key: 70, size 1 byte written.
- Key: 71, size 4 bytes written.
- Key: 72, size 4 bytes written.
- Key: 73, size 1 byte written.
- Key: 74, size 4 bytes written.
- Key: 75, size 2 bytes written.
- Key: 76, size 2 bytes written.
- Key: 77, size 2 bytes written.
- Key: 78, size 1 byte written.
- Key: 79, size 1 byte written.
- Key: 80, size 1 byte written.
- Key: 81, size 1 byte written.
- Key: 82, size 1 byte written.
- Key: 83, size 2 bytes written.
- Key: 84, size 1 byte written.
- Key: 85, size 4 bytes written.
- Key: 86, size 4 bytes written.
- Key: 87, size 2 bytes written.
- Key: 88, size 1 byte written.
- Key: 89, size 4 bytes written.
- Key: 90, size 4 bytes written.
- Key: 91, size 2 bytes written.
- Key: 92, size 1 byte written.
- Key: 93, size 4 bytes written.
- Key: 94, size 4 bytes written.
- Key: 95, size 2 bytes written.
- Key: 96, size 1 byte written.
- Key: 97, size 4 bytes written.
- Key: 98, size 4 bytes written.
- Key: 99, size 2 bytes written.
- Key: 100, size 4 bytes written.
- Key: 101, size 2 bytes written.
- Key: 102, size 1 byte written.
- Key: 103, size 4 bytes written.
- Key: 104, size 4 bytes written.
- Key: 105, size 4 bytes written.
- Key: 106, size 4 bytes written.
- Key: 107, size 4 bytes written.
- Key: 108, size 2 bytes written.
- Key: 109, size 4 bytes written.
- Key: 110, size 4 bytes written.
- Key: 111, size 4 bytes written.
- Key: 112, size 2 bytes written.
- Key: 113, size 4 bytes written.
- Key: 114, size 4 bytes written.
- Key: 115, size 1 byte written.
- Key: 116, size 1 byte written.
- Key: 117, size 1 byte written.
- Key: 118, size 4 bytes written.
- Key: 119, size 4 bytes written.
- Key: 120, size 1 byte written.
- Key: 121, size 1 byte written.
- Key: 122, size 1 byte written.
- Key: 123, size 8 bytes written.
- Key: 124, size 1 byte written.
- Key: 125, size 1 byte written.
- Key: 126, size 1 byte written.
- Key: 127, size 1 byte written.
- Key: 128, size 1 byte written.
- Key: 129, size 4 bytes written.
- Key: 130, size 4 bytes written.
- Key: 131, size 1 byte written.
- Key: 132, size 1 byte written.
- Key: 133, size 2 bytes written.
- Key: 134, size 1 byte written.
- Key: 135, size 2 bytes written.
- Key: 136, size 1 byte written.
- Key: 137, size 1 byte written.
- Key: 138, size 4 bytes written.
- Key: 139, size 4 bytes written.
- Key: 140, size 1 byte written.
- Key: 141, size 1 byte written.
- Key: 142, size 1 byte written.
- Key: 143, size 1 byte written.
- Key: 144, size 4 bytes written.
- Key: 145, size 8 bytes written.
- Key: 146, size 4 bytes written.
- Key: 147, size 4 bytes written.
- Key: 148, size 1 byte written.
- Key: 149, size 1 byte written.
- Key: 150, size 1 byte written.
- Key: 151, size 1 byte written.
- Key: 152, size 1 byte written.
- Key: 153, size 1 byte written.
- Key: 154, size 1 byte written.
- Key: 155, size 1 byte written.
- Key: 156, size 1 byte written.
- Key: 157, size 1 byte written.
- Key: 158, size 1 byte written.
- Key: 159, size 2 bytes written.
- Key: 160, size 2 bytes written.
- Key: 161, size 1 byte written.
- Key: 162, size 1 byte written.
- Key: 163, size 1 byte written.
- Key: 164, size 1 byte written.
- Key: 165, size 1 byte written.
- Key: 166, size 1 byte written.
- Key: 167, size 8 bytes written.
- Key: 168, size 4 bytes written.
- Key: 169, size 1 byte written.
- Key: 170, size 1 byte written.
- Key: 171, size 1 byte written.
- Key: 172, size 1 byte written.
- Key: 173, size 1 byte written.
- Key: 174, size 1 byte written.
- Key: 175, size 1 byte written.
Section: 31
- Key: 4, size 12 bytes written.
Section: 42
- Key: 0, size 2 bytes written.
- Key: 2, size 36 bytes written.
- Key: 3, size 36 bytes written.
- Key: 4, size 36 bytes written.
- Key: 5, size 36 bytes written.
- Key: 6, size 36 bytes written.
- Key: 7, size 36 bytes written.
- Key: 8, size 36 bytes written.
- Key: 9, size 36 bytes written.
- Key: 10, size 36 bytes written.
- Key: 11, size 36 bytes written.
- Key: 12, size 36 bytes written.
- Key: 13, size 40 bytes written.
- Key: 14, size 40 bytes written.
- Key: 15, size 40 bytes written.
- Key: 16, size 40 bytes written.
- Key: 17, size 40 bytes written.
- Key: 18, size 40 bytes written.
- Key: 19, size 40 bytes written.
- Key: 20, size 40 bytes written.
Section: 50
Section: 54
Section: 55
- Key: 0, size 80 bytes written.
Section: 56
Section: 65
- Key: 0, size 11 bytes written.
- Key: 1, size 11 bytes written.
- Key: 2, size 11 bytes written.
- Key: 3, size 11 bytes written.
- Key: 4, size 11 bytes written.
Section: 66
- Key: 0, size 160 bytes written.
- Key: 1, size 160 bytes written.
- Key: 3, size 1 byte written.
- Key: 4, size 160 bytes written.
- Key: 5, size 4 bytes written.
- Key: 7, size 4 bytes written.
- Key: 8, size 4 bytes written.
- Key: 9, size 160 bytes written.
- Key: 10, size 240 bytes written.
- Key: 14, size 4 bytes written.
- Key: 16, size 4 bytes written.
- Key: 20, size 4 bytes written.
- Key: 22, size 4 bytes written.
- Key: 24, size 4 bytes written.
- Key: 26, size 4 bytes written.
- Key: 28, size 4 bytes written.
- Key: 30, size 4 bytes written.
- Key: 32, size 4 bytes written.
- Key: 34, size 4 bytes written.
- Key: 36, size 4 bytes written.
- Key: 38, size 4 bytes written.
- Key: 40, size 4 bytes written.
- Key: 53, size 1 byte written.
- Key: 64, size 8 bytes written.
- Key: 65, size 8 bytes written.
- Key: 66, size 8 bytes written.
- Key: 67, size 8 bytes written.
- Key: 68, size 8 bytes written.
- Key: 82, size 8 bytes written.
- Key: 83, size 8 bytes written.
- Key: 84, size 8 bytes written.
- Key: 87, size 6144 bytes written.
- Key: 88, size 300 bytes written.
- Key: 89, size 40 bytes written.
- Key: 112, size 4 bytes written.
- Key: 115, size 4 bytes written.
- Key: 116, size 4 bytes written.
- Key: 120, size 4 bytes written.
Section: 67
- Key: 0, size 2756 bytes written.
Section: 76
- Key: 0, size 534 bytes written.
Section: 84
- Key: 0, size 3 bytes written.
Section: 88
- Key: 0, size 36 bytes written.
Section: 96
- Key: 0, size 24 bytes written.
Section: 107
- Key: 0, size 21 bytes written.
- Key: 1, size 89 bytes written.
- Key: 2, size 69 bytes written.
- Key: 3, size 70 bytes written.
- Key: 25, size 132 bytes written.
Section: 111
- Key: 0, size 200 bytes written.
- Key: 1, size 20 bytes written.
- Key: 2, size 20 bytes written.
- Key: 126, size 20 bytes written.
- Key: 127, size 20 bytes written.
- Key: 150, size 8 bytes written.
- Key: 151, size 4 bytes written.
- Key: 152, size 40 bytes written.
Section: 116
- Key: 21, size 40 bytes written.
- Key: 22, size 40 bytes written.
Section: 153
- Key: 0, size 68 bytes written.
- Key: 1, size 68 bytes written.
- Key: 2, size 68 bytes written.
- Key: 3, size 68 bytes written.
- Key: 4, size 68 bytes written.
- Key: 5, size 68 bytes written.
Section: 181
- Key: 0, size 8 bytes written.
- Key: 1, size 10 bytes written.
Section: 182
- Key: 1, size 1 byte written.
- Key: 3, size 8 bytes written.
- Key: 13, size 8 bytes written.
- Key: 18, size 8 bytes written.
- Key: 22, size 8 bytes written.
- Key: 25, size 1 byte written.
Section: 183
Section: 184
Section: 185
Section: 186
Section: 187
Section: 188
Section: 190
- Key: 0, size 355 bytes written.
Section: 191
- Key: 0, size 5 bytes written.
Section: 193
- Key: 2, size 8 bytes written.
- Key: 3, size 32 bytes written.
- Key: 4, size 32 bytes written.
- Key: 9, size 64 bytes written.
Section: 200
Section: 202
- Key: 4, size 42 bytes written.
Section: 213
- Key: 0, size 20 bytes written.
Section: 217
- Key: 0, size 32 bytes written.
Section: 218
Section: 225
- Key: 1, size 6 bytes written.
- Key: 2, size 6 bytes written.
Section: 232
- Key: 9, size 4 bytes written.
Section: 238
Section: 250
- Key: 1, size 1092 bytes written.
- Key: 3, size 390 bytes written.
Section: 301
Section: 309
Warning: failed to write 309 - 0 (4 bytes)
Warning: failed to write 309 - 1 (2 bytes)
Warning: failed to write 309 - 2 (12 bytes)
Warning: failed to write 309 - 4 (12 bytes)
Warning: failed to write 309 - 5 (12 bytes)
Warning: failed to write 309 - 7 (12 bytes)
Warning: failed to write 309 - 8 (12 bytes)
Warning: failed to write 309 - 17 (12 bytes)
Warning: failed to write 309 - 22 (12 bytes)
Section: 320
- Key: 0, size 148 bytes written.
- Key: 1, size 148 bytes written.
- Key: 2, size 148 bytes written.
- Key: 3, size 148 bytes written.
- Key: 4, size 148 bytes written.
- Key: 5, size 148 bytes written.
- Key: 6, size 148 bytes written.
- Key: 7, size 148 bytes written.
- Key: 8, size 148 bytes written.
- Key: 9, size 148 bytes written.
- Key: 10, size 148 bytes written.
- Key: 11, size 148 bytes written.
- Key: 12, size 148 bytes written.
- Key: 13, size 148 bytes written.
- Key: 14, size 148 bytes written.
- Key: 15, size 148 bytes written.
- Key: 16, size 148 bytes written.
- Key: 17, size 148 bytes written.
- Key: 18, size 148 bytes written.
Section: 321
Section: 322
Section: 334
Section: 339
- Key: 0, size 511 bytes written.
- Key: 1, size 511 bytes written.
Section: 341
- Key: 4, size 4902 bytes written.
Completed in 59.016 s
