em đóng lại upp và thay plash . chạy lên em nạp imei rùi nhưng nó báo :Failed to read SP data . anh em xem rùi giúp em với . đây là log của em nó
MXKEY Serial: [FT SCR2000 0] - C0845DFF
Connection status: UHCI:HUB:USB 1.10 (Full-speed)
Driver: UFS2XX, ver: 2.0.0.0 , NTMP ver: 2.0.0.1
Module ver: 1.0.0.18624(06-08-2011), Library ver: 1.0.0.12274(06-08-2011)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00033910A3BDA66
ASIC type: 11
UEM Imei: 35685802770635
Flash Imei: 35685802770635
MasterCode: 4524242146
RPL saved to "C:\mobileEx\3.5\data\backup\35685802770635_BACK.r pl"
Phone type: RH-99
SW version: V 5.91 27-03-09 RH-99 (c) NMP
Imei plain: 35685802770635-8
Product code: 0546971
Cellular system: GSM
ASIC ID: 0x2292, type: 0
Ppm Id: MR
Language Pack:
- not available.
A3BDA66
