Yes your not dreaming, we did not add 10 or 20 new models.. but 70+ new phones suppored
for unlock by SRS Server including models not supported by any other tool..
Lets see what we have done...
SRS Samsung Module:
[+] Add support for I9001 with Value Pack (April 2012)
[+] Add A847M Read Codes
[+] Add I5510L Direct Unlock + Read Codes + Imei Repair
[+] Add I5510T Direct Unlock + Read Codes + Imei Repair
[+] Add I8150B Direct Unlock + Read Codes + Imei Repair
[+] Add I9020 Direct Unlock + Read Codes
[+] Add I9023 Direct Unlock + Read Codes
[+] Add I9100G Direct Unlock + Read Codes
[+] Add I9100P Direct Unlock + Read Codes
[+] Add I9188 Direct Unlock
[+] Add I9220 Direct Unlock
[+] Add I717 Direct Unlock (All versions)
[+] Add I717D Direct Unlock (All versions)
[+] Add I717M Direct Unlock (All versions)
[+] Add I717R Direct Unlock (All versions)
[+] Add I727 Direct Unlock (All versions)
[+] Add I727R Direct Unlock (All versions)
[+] Add I927 Direct Unlock
[+] Add I987 Direct Unlock
[+] Add I997 Direct Unlock + Read Codes
[+] Add P1010 Direct Unlock + Read Codes
[+] Add P1013 Direct Unlock + Read Codes
[+] Add P6201 Direct Unlock
[+] Add P6210 Direct Unlock
[+] Add P6211 Direct Unlock
[+] Add P6800 Direct Unlock
[+] Add P6810 Direct Unlock
[+] Add P7100 Direct Unlock
[+] Add P7300 Direct Unlock
[+] Add P7310 Direct Unlock
[+] Add P7320 Direct Unlock *for test*
[+] Add P7500R Direct Unlock
[+] Add P7501 Direct Unlock
[+] Add P7511 Direct Unlock
[+] Add S5230W Direct Unlock + Read codes + Imei Repair(via uart)
[+] Add S5233T Direct Unlock + Read codes + Imei Repair(via uart)
[+] Add S5360B Direct Unlock + Imei Repair
[+] Add S5360L Direct Unlock + Imei Repair
[+] Add S5360T Direct Unlock + Imei Repair
[+] Add S5367 Direct Unlock + Imei Repair
[+] Add S5511 Direct Unlock + Read Codes
[+] Add S6500 Direct Unlock + Imei Repair
[+] Add S6500D Direct Unlock + Imei Repair
[+] Add S7230E Direct Unlock + Read Codes
[+] Add T499V Direct Unlock + Read Codes + Imei Repair
[+] Add T499Y Direct Unlock + Read Codes + Imei Repair
[+] Add T679M Direct Unlock + Read Codes + Imei Repair
[+] Add T759 Direct Unlock + Read Codes
[+] Add T839 Direct Unlock + Read Codes
[+] Add T859 Direct Unlock + Read Codes
[+] Add T869 Direct Unlock
[+] Add T959U Direct Unlock + Read Codes
[+] Add T959V Direct Unlock + Read Codes
[+] Add T969V Direct Unlock + Read Codes
[+] Add T989 Direct Unlock (All versions)
[+] Add T989D Direct Unlock (All versions)
[+] Fixed S5690 Direct Unlock (All versions)
[+] Add S5690L Direct Unlock (All versions)
[+] Updated Server images.
[+] Fixed small issue with file locations on spanish windows
[+] Updated Rootkits in support area for I9100 4.0.3 flash with odin
- Remember, android versions higher that 2.3.6 you -
-= need to Root manually except the BCM Series =-
SRS IMEI Module:
[+] Add code calculation Huawei G6210
[+] Add code calculation Huawei G6609
[+] Add code calculation Huawei G6622
[+] Add code calculation Huawei G3501
[+] Add code calculation Huawei G7600
[+] Add code calculation Huawei G7002
[+] Add code calculation Orange Amsterdam
[+] Add code calculation Orange Tactile Messenger
[+] Add code calculation KPN Smart 200
[+] Add code calculation TMN Easy 10
[+] Add code calculation Movistar 731
[+] Add code calculation Movistar Smile
[+] Add code calculation Movistar Urban
[+] Add code calculation Dell XCD28
[+] Add code calculation ZTE G-S511
[+] Add code calculation ZTE G-S512
[+] Blackberry PRD updated with 631 new PRD's
[+] Add Blackberry Engineer screen calculator
SRS IMEI Android App:
[+] Add Huawei G6210, G6609, and G6622
[+] Add Huawei G3501, G7600, and G7002
[+] Fixed motorola MTK provider-ID not displayed
SRS Calculator API:
[+] Upgraded to Api Release 1.2
[+] Synced to match all models from Imei Module
Make sure you download latest SRS client from
Unlock Samsung Online - Remote Unlock Server
All older versions stop working...
