    Thành viên tích cực bvl_2811's Avatar
    Apr 2011
    Nam Định
    Mặc định nokia x6 phone startup failed contact retailer
    đã fomat bằng tay mà không hết
    đây là log của em nó
    mong ace nhiệt tình chỉ giúp
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 2], SN: C0846C4D
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 00010686
    Connection status: EHCI:HUB::USB 2.00 (High-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.20251(25-02-2012), Library ver: 1.0.0.14016(30-03-2012)
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000010000022600010006400C192101051103 [RAPIDO3G ver: 1.15]
    CMT EM0 ID: 00000296
    CMT EM1 ID: 00000B22
    CMT PUBLIC ID: 0C60010BE59E0052307970F2F9DADC99B3BCEE89
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371
    CMT ROM ID: 4B9B75103E691FF8
    Loading CMT secondary boot code
    SecondaryBoot: RAPIDOv11_2nd.fg [BB5] version: 11.14.0 revision: 2.0 size: 0x3B80
    Supported Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105, 4003192101051103, 400C192101051103, 400C192101051105, 4003192101051105
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0400 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0050 - 0000 0031 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPIDOv11_XSR15_alg.fg [XSR 1.5] version: 11.14.0 revision: 2.0 size: 0x8798F
    Update server code loaded.
    FUR: Adding Asic CMT as client OK.
    Reading CMT NPC (0xFF bytes).
    Reading CMT CCC (0xFF bytes).
    Reading CMT HWC (0xFF bytes).
    Reading CMT R&D (0xFF bytes).
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdc\Nokia X6-00 USB Phonet, PORT_ID: 1E02EEFE
    Verifying communication to device OK.
    Phone type: RM-559 (Nokia X6-00)
    SW version: V ICPR72_11w16.1 28-07-11 RM-559 (c) Nokia
    ApeCoreSw: V 40.0.002
    Imei plain: 35342204927701-4
    Product code: 059B881
    Battery voltage: 3666 mV, current: 285 mA
    Language Pack:
    - not available.
    SIMLOCK seems to be valid
    CMLA_KEY seems to be valid
    WMDRM_PD seems to be valid
    SIMLOCK_TEST passed
    SECURITY_TEST passed
    Imei net: 353422049277014
    Version: SIMLOCK SERVER
    Counter: 0/3, 0/10
    CONFIG_DATA: 2440700000000000
    Moderator VanTuan-ST's Avatar
    Sóc Trăng
    Full Factory cái nếu vẫn không hết load ver Này về flash lại xem.
    Apr 2011
    Nam Định
    Trích Được post bởi VanTuan-ST Xem bài viết
    full factory rổi mà không hết
    em chạy lên 40.0.002 rồi chạy file 32.0.002 liệu có ổn không mod
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Nhìn thấy dòng đấy ko bạn?
    ko đc hạ ver
    Thành viên tích cực Tu0977717405's Avatar
    Dec 2009
    thanh hoa
    còn chuyện hạ ver thi vẫn được nhưng phải tích vào ô downrgade . khuyên bạn không nên hạ ver vì có thể mất nguồn
    Dec 2009
    thanh hoa
    theo ý kiến của e. thì con flash bị lỗi rồi. thường thì thay mới hết bệnh. đây chỉ là kinh nghiệm riêng e, a thấy áp dụng được thì làm.
    Thành viên tích cực ThùyThương_GSM's Avatar
    May 2011
    trời sl3 mà anh bảo hạ ver cũng được là xao.khó hiểu quá
  1. Trả lời: 2
    Bài viết cuối: 21-07-2012, 18:19
  2. Trả lời: 6
    Bài viết cuối: 31-03-2012, 14:58
  3. Trả lời: 18
    Bài viết cuối: 22-07-2011, 12:11
  4. Trả lời: 27
    Bài viết cuối: 15-03-2009, 13:04
