đây là log của em nó xin mấy hynh chỉ giúp em với!!!!
MXKEY [FT SCR2000 0], SN: C0855454
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0000648A
Connection status: UHCI:HUB:USB 1.10 (Full-speed)
Driver: nmwcdnsuc, ver: 7.1.32.72
Module ver: 1.0.0.19798(05-01-2012), Library ver: 1.0.0.13703(05-01-2012)
Do not disconnect or abort this operation otherwise phone will be damaged.
Waiting for USB ROM device ...
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 9EF9DDC
Device synchronized.
CPU: XGOLD 213
Using embedded SBL from MCU.
Sending EBL Loader...OK
Sending EBL ...OK
Getting EBL Version ...
Boot mode: 0xCC
EBL version major/minor: 10.46
EBL version : Quantum_Bootloader_10.46_M1S1
Protocol version suggested by phone: 3
Set baud rate to: 6.50 Mbit/s
Flash ID: 0089 8982 [Intel NU48F512,512 Mbits]
Processing file: rm694__10.91.mcusw
Downloading item CODE:rm694__10.91.mcusw_ebl_psi.fls, num block: 4, size: 26.25 MB
Erasing area 0x40000000-0x4001FFFE ...OK
Programming completed in 0.344 s
Erasing area 0x40040000-0x4005FFFE ...OK
Erasing area 0x40060000-0x4015FFFE ...OK
Programming completed in 1.344 s
Erasing area 0x40280000-0x41B7FFFE ...OK
Programming completed in 29.078 s
Checksum verified (0x27E3)
Processing file: rm694__10.91.ppm_v
Downloading item CUSTackage_v.ppm_ebl_psi.fls, num block: 1, size: 5.51 MB
Erasing area 0x41C00000-0x42181C72 ...OK
Programming completed in 6.531 s
Checksum verified (0x76E8)
Processing file: rm694__10.91.image_v_059D1W0
Downloading item CUSTackage_v_059D1W0.image.fls, num block: 1, size: 14.25 MB
Erasing area 0x42300000-0x43E1FFFE ...OK
Programming completed in 17.281 s
Checksum verified (0x2887)
Total time for flashing process(boot+erase+write) was 7 min 3.718 s
Phone type: RM-694 (Nokia X2-00)
SW version: V 10.91 08-02-12 RM-694 (c) Nokia
Imei plain: 35196005051734-1
Cellular system: GSM
ASIC ID: 0x0000, type: 11
Ppm Id: V
Language Pack:
- not available.
Master code: 4671226653
SIMLOCK_DATA corrupted!
Market items is empty, please select the correct products path !
