Mình flash cây 6230i , nó chạy hết file MCU xong báo lỗi như thế này,mình là lính mới nên chưa có nhiều kinh nghiệm mong ace chỉ dậy em xin chân thành cảm ơn !
đây là log lỗi của MXbox
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0855B3F
Using device: HTI, FW ver: 00.50, SN: 0000DFF2
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.20769(01-04-2012), Library ver: 1.0.0.14022(01-04-2012)
ASIC ID: 0x1052 [TikuEdge ver: 1.1]
SecondaryBoot: te_2nd.fia [TIKU BT2] version: 4.76.0 revision: 0.7 size: 0x2398
Supported Ids: 1051, 1052, 2051
FlashID0: 00EC 22E8 [Samsung K8S2815ETB,128 Mbits] page size: 64 K type: NOR area: 00000000-00FFFFFF
FlashID1: 00EC 0010 [Samsung KFM5616Q2M MuxOneNAND,256 Mbits] type: NAND hw: ONEMUX(M)
FlashID2: 0000 0001 [unused/removed]
FlashID3: 0000 0001 [unused/removed]
ExtBUSC: FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
Algorithm: te_amd.fia [TIKU ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x84D8
UEM ID: 009C3CEF:3B8ADA60
ASIC type: 6
UEM Imei: 35796400100631
Flash Imei: 35796400100631
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\3579640010063 1_BA CK.rpl"
Processing MCU file: rm72_73_11003.880
[TIKU BT2,TIKU ALGORITHM] size: 10.14 MB
Supported Ids: 1052, 2051
UEM ID: 009C3CEF:8615DA60
Area [00000000-0000FFFF] erased in 0.500 s
Area [00010000-009FFFFF] erased in 1 min 19.625 s
Area [00A00000-00B3FFFF] erased in 10.094 s
Area [00B60000-00FAFFFF] erased in 32.922 s
Flash programming ...
Programming completed in 1 min 17.343 s
File processed in 3 min 32.062 s
Processing CNT file: rm72_73_110M_03.88.ucp_v
[TIKU BT2,TIKU MON CSM] size: 3.92 MB
ExtBUSC: 0000 0000 18F0 9FE5 18F0 9FE5 18F0 9FE5
Algorithm: te_oncsm.fia [TIKU MON CSM] version: 4.76.0 revision: 0.7 size: 0x5660
Mass Memory Storage Device detected.
Configuring MM bus ...
Formating partition ...OK
Opening MM device ...
Erasing disks ...OK
The semaphore timeout period has expired
Error while programming [2E] at 0x01000020, Result: 0000
flashing terminated !
Mong anh em giúp đỡ là nó lỗi gì nhé. xin chân thành cảm ơn.
