    Thành viên mới xunghe_anhhung's Avatar
    Mar 2012
    Mặc định N202 flash ok..
    ae gặp cứ múc nhá/....
    MXKEY [MxKey Team HTI PLUS Flasher Interface 3], SN: C087246F
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 01008C27
    Connection status: UHCI:HUB::USB 1.10 (Full-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.20814(05-05-2012), Library ver: 1.0.0.14060(05-05-2012)
    Waiting for USB ROM device ...
    Device synchronized.
    CPU: XGOLD 213
    Using embedded SBL from MCU.
    Sending EBL Loader...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.47
    EBL version: Quantum_Bootloader_10.47_M1S1
    Protocol version suggested by phone: 3
    Set baud rate to: 6.50 Mbit/s
    Flash ID: 00EC 3012 - 23280002 [Samsung ]
    CFI information:
    Flash settings: 0/1024, size: 0x04000000
    1 Block regions:
    512 x 0x00020000 = 0x04000000
    EBL ready !
    Original IMEI: 35166805455272
    IMEI_DATA saved OK
    CCC_DATA saved OK
    HWC_DATA saved OK
    RPL saved to "C:\mobileEx\3.5\data\backup\XGOLD_35166805455272_ back.RPL"
    Processing file: rm834__20.37.mcusw
    Downloading item CODE:rm834__20.37.mcusw_ebl_psi.fls, num block: 4, size: 28 MB
    Erasing area 0x40000000-0x4001FFFE ...OK
    Programming completed in 0.359 s
    Erasing area 0x40040000-0x4005FFFE ...OK
    Programming completed in 0.375 s
    Erasing area 0x40060000-0x4015FFFE ...OK
    Programming completed in 1.547 s
    Erasing area 0x40280000-0x41D3FFFE ...OK
    Programming completed in 36.781 s
    Checksum verified (0x0119)
    Processing file: rm834__20.37.ppm_v
    Downloading item CUSTackage_v.ppm_ebl_psi.fls, num block: 1, size: 5.81 MB
    Erasing area 0x41DC0000-0x4238D646 ...OK
    Programming completed in 8.203 s
    Checksum verified (0xECEB)
    Processing file: rm834__20.37.image_v_059P2P4
    Downloading item CUSTackage_v_059P2P4.image.fls, num block: 1, size: 12.75 MB
    Erasing area 0x424C0000-0x43E1FFFE ...OK
    Programming completed in 17.640 s
    Checksum verified (0x8854)
    Total time for flashing process(boot+erase+write) was 4 min 23.953 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...
    Device connected: nmwcdc\Nokia USB Phonet, PORT_ID: 111BA6BA
    Verifying communication to device OK.
    Phone type: RM-834 (202)
    SW version: V 20.37 31-05-12 RM-834 (c) Nokia
    Imei plain: 35166805455272-3
    Product code: 059M6F5
    Language Pack:
    - not available.
    Imei net: 35166805455272
    Version: SIMLOCK SERVER
    Provider: GSM Test Operator
    Counter: 0/3, 0/10
    CONFIG_DATA: 0010100000000000
    PROFILE_BITS: 800000000003000B
  2. ( xunghe_anhhung ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    LongBiênMobile (04-07-2012), lyhung1310 (03-07-2012)
    Moderator CNB_DRT's Avatar
    Mar 2012
    DakLak
    mxkey thì đời mới ok hết mà
    VCB: 9247477777 CTK: Châu Ngọc Bảo
    Thành viên tích cực 99999's Avatar
    Dec 2011
    là sao ta ????????????????????
    aitun : Do1234567 - do_gsm@yahoo.com.vn ; phattaigsm@yahoo.com - Do1234567
    sicado80@gmail.com.vn - pass: oooooooo
    Thành viên tích cực chicong2008's Avatar
    Nov 2011
    bên nghean cung thấy đó nha hoạt động nhìu nghê ta
    Thành viên chính thức LongBiênMobile's Avatar
    Cái này có gì đâu ! mxbox xanh & cam chiến những em này = usb ngọt như mía ấy mà. Dù sao cũng Thanks
    Tel: 0982 980 688 Y/M : long_gsm
    Thành viên tích cực cuongmobile4078's Avatar
    Jun 2012
    ha nội
    dù sao cũng cảm ơn bạd9a334 chia sẻ
    luôn luôn lắng nghe.luôn luôn chia sẻ
    yh:cuongmobile4078 DT:0433646344 DD:0974201988
  1. Nokia n202 cần giúp
    By chuyenphamobile in forum BB5
    Trả lời: 14
    Bài viết cuối: 16-11-2013, 19:54
  2. n202 xin giúp
    By phamtrung in forum BB5
    Trả lời: 15
    Bài viết cuối: 05-09-2013, 22:18
  3. N202 xin giúp!
    By Trần Gia_Store in forum BB5
    Bài viết cuối: 29-08-2013, 10:56
  4. Trả lời: 6
    Bài viết cuối: 09-01-2013, 11:47
  5. n202 cần giúp
    By nguyengiap_84 in forum BB5
    Bài viết cuối: 03-08-2012, 08:02
