Kết quả 1 tới 4 của 4
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    Mặc định lock n200 nhờ ae xem giúp
    máy lên trắng treo ,flash = phonix thế này , rồi khởi động không cần sim treo
    đây là lock ae xem giúp
    Flashing started
    Creating product data items list
    Product data items list created
    Backup not required
    Flashing phone
    Initializing
    Download files list initiated
    Waiting for USB device...
    Booting...
    Sending EBL loader...
    Sending EBL...
    Boot successful
    Downloading file: rm761__11.56.mcusw
    Erasing 131070 bytes...
    Total progress: 6%
    Sending data...
    Total progress: 13%
    Total progress: 20%
    Sending data...
    Total progress: 26%
    Erasing 1048574 bytes...
    Total progress: 29%
    Total progress: 31%
    Sending data...
    Total progress: 40%
    Erasing 25165822 bytes...
    Total progress: 42%
    Total progress: 44%
    Total progress: 46%
    Sending data...
    Total progress: 48%
    Total progress: 50%
    Total progress: 52%
    Erasing 262142 bytes...
    Total progress: 60%
    Downloading file: rm761__11.56.ppm_v
    Erasing 6437614 bytes...
    Total progress: 62%
    Total progress: 64%
    Total progress: 66%
    Total progress: 68%
    Sending data...
    Total progress: 71%
    Total progress: 74%
    Total progress: 78%
    Downloading file: rm761__11.56.image_v_059K957_003
    Erasing 15335422 bytes...
    Total progress: 80%
    Total progress: 82%
    Total progress: 84%
    Total progress: 86%
    Sending data...
    Total progress: 88%
    Total progress: 90%
    Total progress: 93%
    Erasing 917502 bytes...
    Total progress: 95%
    Total progress: 98%
    Total progress: 100%
    Resetting device
    Mobile device flashing completed.
    Waiting for phone to boot up
    Bootup successful
    Verifying communication to product (before flash finalizing)
    Communication verified
    Doing factorysets
    Doing factorysets
    Doing factorysets
    Doing factorysets
    All operations completed
    Firmware updating failed.
    Sửa Bài Viết Trả lời Trả Lời Với Trích Dẫn
    Mar 2012
    nam định
    load ver cao nhất vè chạy bằng usb by mx box rồi quằng cái log lên xem sao
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
    Aug 2011
    khu đèn đỏ
    thanks bác , e đang flsh = mx báo lại sau ạ
    Aug 2011
    khu đèn đỏ
    đây là lock flash =mx ae xem giúp , máy vẫn lên rồi treo
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C084A96B
    Using device: USB ROM and HTI, FW ver: 00.50, SN: 000160C3
    Connection status: UHCI:HUB::USB 1.10 (Full-speed)
    Driver: NMWCD, ver: 7.1.32.75
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
    Waiting for USB ROM device ...
    Device synchronized.
    CPU: XGOLD 213
    Using embedded SBL from MCU.
    Sending EBL Loader...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.46
    EBL version: Quantum_Bootloader_10.46_M1S1
    Protocol version suggested by phone: 3
    Set baud rate to: 6.50 Mbit/s
    Flash ID: 0089 8982 - 23280001 [Intel NU48F512,512 Mbits]
    CFI information:
    Flash settings: 0/1024, size: 0x04000000
    1 Block regions:
    512 x 0x00020000 = 0x04000000
    EBL ready !
    Original IMEI: 35825904821314
    RPL backup already exist (C:\mobileEx\3.5\data\backup\XGOLD_35825904821314_ back.RPL)
    Processing file: rm761__11.81.mcusw
    Downloading item CODE:rm761__11.81.mcusw_ebl_psi.fls, num block: 4, size: 25.25 MB
    Erasing area 0x40000000-0x4001FFFE ...OK
    Programming completed in 0.375 s
    Erasing area 0x40040000-0x4005FFFE ...OK
    Programming completed in 0.359 s
    Erasing area 0x40060000-0x4015FFFE ...OK
    Programming completed in 1.890 s
    Erasing area 0x40280000-0x41A7FFFE ...OK
    Programming completed in 37.407 s
    Checksum verified (0xBACD)
    Processing file: rm761__11.81.ppm_v
    Downloading item CUSTackage_v.ppm_ebl_psi.fls, num block: 1, size: 6.35 MB
    Erasing area 0x41A80000-0x420D8E5E ...OK
    Programming completed in 8.656 s
    Checksum verified (0x1EBF)
    Processing file: rm761__11.81.image_v_059J5N5
    Downloading item CUSTackage_v_059J5N5.image.fls, num block: 1, size: 15.63 MB
    Erasing area 0x421C0000-0x43E1FFFE ...OK
    Programming completed in 21.140 s
    Checksum verified (0x7C42)
    Total time for flashing process(boot+erase+write) was 7 min 50.516 s
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...
    Phone not found, retrying ...
    Warning: Phone did not reboot to normal mode.
    FULL FACTORY... Failed! (0003)
    Completed in 0.016 s
  1. cần giúp sạc n200
    By baboer in forum BB5
    Bài viết cuối: 21-08-2013, 10:20
  2. n200 mất đèn cần schemsic n200
    By thichphamobi in forum BB5
    Bài viết cuối: 07-02-2013, 20:30
  3. N200 cần mọi người giúp ...
    By tuantu_gsm in forum DCT4 - WD2
    Bài viết cuối: 20-01-2013, 16:41
  4. cần giúp e N200 bệnh lạ
    By chilly87_mb in forum BB5
    Bài viết cuối: 26-10-2012, 12:45
  5. n200 không nhận sim cần giúp đỡ
    By manhlanh in forum BB5
    Bài viết cuối: 15-06-2012, 18:54
