các bác xem hộ em cái em chạy 1208 nhầm sang 1200 giờ ko lên nguôn nữa mx key va jaf cũng báo lỗi.may khách mang tới bị mỗi mã bảo vệ máy ko bẻ mã đươc em chạy nhầm thì ko lên.chạy lại 1208 cũng vậy luôn
MCU ID: 0x2292
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
Setting local mode...
Failed! Aborting!
Failed to backup imei...
Flashing Done!
Operation took 0 minutes 25 seconds...
After flash processing...
Waiting for phone to boot...
Failed! Aborting!
Powering the phone...
Failed! Aborting!
Failed! Aborting!
Flashing Done!
Operation took 0 minutes 26 seconds...
Failed! Aborting!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-105\
Checking path: \Products\RH-105\
No ini files found...
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_04.110
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_04.11mr
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai4.11mr
Checking path: C:\Program Files\Nokia\Phoenix\Products\\
Checking path: \Products\\
Phone Type:
Phone Type:
Phone Type:
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_04.110
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x72888900
Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_intel.fia
Loader size is 0x5548; Loader chk: d9
Loader is ready...
MSID: 84577B2EF00144054C168FDC45
MSID decoded: 3E4EBAE9005082DAA9000000
FAID: 8AD23DAB0FFC5667141328D7
Operation took 0 minutes 9 seconds...
Erasing...
Found 5 interval(s) to erase
Operation took 0 minutes 41 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 19 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh105_04.11mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84A30E7D83AB7C916DC579B404
MSID decoded: 3E4EBAE9005082DAAA000000
FAID: C6C615866FD960C75107742C
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 13 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-105\rh1050_nai4.11mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing Content Pack...
Found 1 interval(s) to erase
Operation took 0 minutes 2 seconds...
Writing...
Restarting MCU...
Flashing Done!
Operation took 1 minutes 50 seconds...
Failed! Aborting!
