    Thành viên mới dothienninh's Avatar
    Oct 2012
    Mặc định Cứu giúp em con 2700 flash giờ không lên
    Em có con 2700 cứ bật lên là nháy trắng màn rồi tắt. Em vừa Flash = ATF box tự nhiên giờ màn đen thui. Bây giờ chạy ver nào nó cũng báo thế này:
    Processing Image File :
    rm561__09.98.mcusw
    CMT Type : BB5
    CMT Algorithm : BB5 ALGORITHM
    Secondary Sending Speed : 3250000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 1256
    Entry Point: 0x5047
    Page Format : -1
    MAX PAGE : 0x00004000
    rm561__09.98.ppm_x
    CMT Type : BB5
    Number of Blocks : 442
    Entry Point: 0x00B6
    Page Format : -1
    rm561__09.98_008.image_x_ctv_id_v2_96897
    CMT Type : BB5
    Number of Blocks : 912
    Entry Point: 0x00C8
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 96 (0x60) bytes returned
    Number of Sub Blocks 7 (0x07)
    1 SYSTEM_ASIC_ID 01
    Block Length : 21 (15)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000001
    ID DWORD 1 : 00000226
    ID DWORD 2 : 00010006
    ID DWORD 3 : 030C1921
    ID DWORD 4 : 01033000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00000296
    3 EM_ASIC_ID 02
    ID DWORD 0 : 00000B22
    4 PUBLIC_ID 12
    ID DWORD 0 : 23200216
    ID DWORD 1 : 0ACA8B56
    ID DWORD 2 : 6FA3A6E1
    ID DWORD 3 : E43F0BA5
    ID DWORD 4 : 37AF7EA1
    5 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    6 ROOT_KEY_HASH 14
    Block Length : 17 (11)
    Hash : 9D DB FC FE 6E 73 CE D7 D8 C6 26 8C 8E B8 57 23
    7 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : 273F6D55
    CRC 1 : DFAAF68F
    ADL_SERVER: PROCESSING rm561__09.98.mcusw
    ADL_SERVER: ROOT_KEY_HASH MATCH FOUND
    ADL_SERVER: CMT CERTIFICATE BLOCK FOUND
    ADL_SERVER: CMT DATA BLOCKS FOUND
    ADL_SERVER: CONSOLIDATING CMT BLOCKS
    ADL_SERVER: PASUBTOC BLOCK FOUND
    BB5 ADL Loader Start Up... (Please Wait...)
    ERROR: ADL Loader was not accepted
    PAPUB Key HASH is EMPTY or BLANK.
    Try "Skip ADL Check" Option or use FBUS Flashing
    Booting/Flashing Failed...
    Please Try Again...
    Cao thủ nào giúp em với.Thanks
    Thành viên chính thức minhmobile2's Avatar
    Aug 2012
    dòng này chạy lại ít con dc lắm chỉ có thay cặp thôi
    đưa qua box khác thư lại cái coi sao
    Thành viên tích cực thuyet_mobile's Avatar
    Apr 2008
    Nó bảo sử dụng cáp Fbus kìa !!!
    Jun 2012
    nếu vẩn not ok pm chử kí còn 1 men fukk nhé
    chạy = usb xem sao bạn ko dc đổi bõ kak xem sao phải mỏ hết lock dẹp thì may ra cuurws dc bạn ah ko dc thay cặp thôi
    yh chanyenmobile_led1202
    ctk hà Văn Yên face hachanyen
    sdt zalo..0972444489
    BỘ ngoại giao trùm các 4r
    Oct 2012
    có lẽ phải thay cặp thôi. Mình chạy = cả Phoenix và Best mà không ăn thua. Dùng USB cũng k được dùng cáp đa năng BB5- A C mà k đc lun
    Thành viên chính thức duytoi_1987's Avatar
    Apr 2010
    đưa qua box khác chạy xem sao đả chưa gì đả thay cặp rồi
    Moderator nguyen's Avatar
    Oct 2006
    BẠC LIÊU
    Khỏi chạy nữa, thay cặp hoặc thay main.
    HẠNH NGUYÊN MOBILE.
  1. 2700 không lên nguồn cần giúp
    By sonfa139 in forum BB5
    Bài viết cuối: 16-09-2013, 19:23
  2. Trả lời: 11
    Bài viết cuối: 10-09-2013, 15:19
  3. Trả lời: 5
    Bài viết cuối: 05-06-2012, 10:57
  4. Trả lời: 12
    Bài viết cuối: 22-05-2012, 15:17
  5. Trả lời: 18
    Bài viết cuối: 26-11-2011, 23:46
