tinh hinh la em có cây 1202 thay cpu rùi nhung e không biết cách đồng bộ.xon các anh nào biết giúp giùm em.thanks các anh trước
em chạy bằng mxbox nó như này
MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 1], SN: C086CF06
Using device: HTI, FW ver: 00.50, SN: 00016ECA
Driver: WinUSB, ver: 3.5.1.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
ASIC ID: 0x2293 [UPPCosto ver: 2.0]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 2310 0340 C605 E401 20A2 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00304FB5A3BDA66
ASIC type: 11
UEM Imei: Empty
Flash Imei: 35934703031603
RPL saved to "C:\mobileEx\3.5\data\backup\RPL\_BACK.rpl"
Processing MCU file: rh112_004.030
[DCT4,DCT4 ALGORITHM] size: 2.29 MB
Supported Ids: 2293
UEM ID: 00304FB5:2984DA60
Area [01000000-0100FFFF] erased in 1.187 s
Area [01010000-013AFFFF] erased in 1 min 5.953 s
Area [013B0000-013EFFFF] erased in 4.735 s
Area [017C0000-017EFFFF] erased in 0.032 s
Area [01FC0000-01FEFFFF] erased in 0.063 s
Flash programming ...
Programming completed in 20.719 s
File processed in 1 min 41.984 s
Processing CNT file: rh1120_nai04.03mr
[DCT4,DCT4 ALGORITHM] size: 110.54 KB
Supported Ids: 2293
Area [01380000-013AFFFF] erased in 3.532 s
Programming completed in 1.047 s
Content extract fail, continue anyway ...
File processed in 57.203 s
Processing PPM file: rh112_004.03mr
[DCT4,DCT4 ALGORITHM] size: 1.15 MB
Supported Ids: 2293
Area [01240000-0124FFFF] erased in 1.141 s
Area [01250000-0137FFFF] erased in 21.438 s
Programming completed in 9.297 s
File processed in 40.109 s
Total time for flashing process(boot+erase+write) was 3 min 19.328 s
để ý khu vực post bài cho đúng đã move
A3BDA66
