Using device: USB ROM and HTI, FW ver: 00.50, SN: 01004029
Connection status: UHCI:HUB::USB 2.00 (Full-speed)
Driver: NMWCD, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
Processing MCU file: rm561__09.98.mcusw
[BB5,BB5 ALGORITHM] size: 19.41 MB
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.0]
CMT EM0 ID: 00000296
CMT EM1 ID: 00000B22
CMT PUBLIC ID: 117001116BB102566E743B68F92D0D195CA89A8C
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
CMT ROM ID: 273F6D55DFAAF68F
Flashing CMT Update Server Data, ULO: 0x3900 bytes
Update Server code succesfully sent to phone.
Flashing CMT Update Server Data, UPDAPP: 0x4B340 bytes
Flashing CMT Update Server Data, PASUBTOC: 0x59980 bytes
Waiting for USB device removal ...
Device connected: nmwcdnsuc\Nokia BB5 ADL Loader USB Generic, PORT_ID: 28D3B054
Verifying communication to device OK.
Erase size: 21 MB
CMT FLASH,NOR area [00000000-000006BF] erased in 0.672 s
CMT FLASH,NOR area [000006C0-0001FFFF] erased in 0.656 s
CMT FLASH,NOR area [00040000-000BFFFF] erased in 2.875 s
CMT FLASH,NOR area [000C0000-0013FFFF] erased in 2.719 s
CMT FLASH,NOR area [00140000-0137FFFF] erased in 1 min 42.312 s
CMT FLASH,NOR area [01380000-0151FFFF] erased in 9.281 s
Flash programming ...
CMT NOLO block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT PASUBTOC block sent
Selecting first CMT PAPUB block with matching RootKey.
CMT PAPUBKEYS: 3EA22A1D [RAP Certificate 202 v.1] sent
CMT UPDAPP block sent
CMT DSP0 block sent
CMT MCUSW block sent
Programming completed in 1 min 8.344 s
Processing PPM file: rm561__09.98.ppm_v
[BB5,BB5 ALGORITHM] size: 6.90 MB
Erase size: 8.62 MB
CMT FLASH,NOR area [01520000-01DBFFFF] erased in 47.281 s
Programming completed in 24.531 s
Processing CNT file: rm561__09.98.image_v_blac
[BB5,BB5 ALGORITHM] page size: 128 K size: 13.64 MB
Erase size: 34 MB
CMT FLASH,NOR area [01DC0000-0215FFFF] erased in 23.546 s
CMT FLASH,NOR area [02160000-03FBFFFF] erased in 3 min 3.125 s
Programming completed in 47.625 s
Total time for flashing process(boot+erase+write) was 9 min 11.906 s
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdc\Nokia 2700 classic USB Phonet, PORT_ID: FFF1B3B
Phone type: RM-561 (Nokia 2700 classic)
SW version: V 09.98 06-09-10 RM-561 (c) Nokia
Imei plain: 35484904298677-0
Product code: 0592505
Battery voltage: 3798 mV, current: 142 mA
Language Pack:
- not available.
Camera config: NIMMIIIIRRFF00000000, ver: XXX.XXX
warning: DCC corrupted !
SIMLOCK invalid!
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
Market items is empty, please select the correct products path !
