em nhận máy nokia n8 bật nguồn lên nokia treo máy.em chạy lại phần mêm bằng mx box usb thì không lên nguồn.đây là log chạy bằng usb mx box
MXKEY [MxKey Team HTI PLUS Flasher Interface 0], SN: C0871536
Using device: USB Phonet and HTI, FW ver: 00.50, SN: 0100B255
Connection status: EHCI:HUB::USB 2.00 (High-speed)
Driver: nmwcdnsuc, ver: 7.1.32.75
Module ver: 1.0.0.21151(13-07-2012), Library ver:
Processing MCU file: RM-596_025.008_79.92_prd.core.fpsx
[BB5,XSR 1.6] size: 122.51 MB
Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
Waiting for USB ROM device ...
CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
CMT EM0 ID: 00001040
CMT EM1 ID: 00001060
CMT PUBLIC ID: 13A00206CDDC034445207BF80D8C7FB9BEC8CFAD
CMT ASIC MODE ID: 00
CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
CMT ROM ID: E693EF0DAC22615B
Loading CMT secondary boot code
SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
eBB5ProtocolType: NEW
Secondary boot loaded.
Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
Storage4: 00EC 0050 - 0000 0232 [Samsung ] type: FLASH,MuxOneNAND, asic:CMT
Suggested algorithm: XSR 1.6
Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
Update server code loaded.
Waiting for USB device removal ...OK
Waiting for USB device arrival ...OK
Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 1D81320B
FUR: Adding Asic CMT as client OK.
Reading CMT NPC (0x190 bytes).
Reading CMT CCC (0x1D8 bytes).
Reading CMT HWC (0xD4 bytes).
Reading CMT R&D (0x0 bytes).
Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35905404839290_CE RT.rpl).
CMT PAPUBKEYS HASH: D172C32473AE199B213465ABB3853246F9631231
Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
Partitioning....
Partitioning complete
Erase size: 228.06 MB
CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF]
Formating partition ...
Flash programming ...
CMT ADA block sent
CMT KEYS block sent
CMT PRIMAPP block sent
CMT RAP3NAND block sent
CMT SOS+PMML block sent
CMT PASUBTOC block sent
CMT PAPUBKEYS: D172C324 [RAP Certificate 103 v1] sent
CMT GENIO_INIT block sent
CMT SOS*UPDAPP block sent
CMT SOS*DSP0 block sent
CMT LDSP block sent
CMT SOS*ISASW block sent
CMT SOS+CORE block sent
CMT SOS+ROFS1 block sent
11.34.000.2\BCM21351_usb2nd.fg: OKProgramming completed in 24.109 s
Processing PPM file: RM-596_025.008_31.01_NAM_79.92_prd.rofs2.fpsx
[BB5,XSR 1.6] size: 49.83 MB
Erase size: 59.25 MB
CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF]
CMT SOS+ROFS2 block sent
Programming completed in 9.517 s
Processing PPM file: RM-596_025.008_269.05_default_79.92.2011.37_01_prd.ro fs3.fpsx
[BB5,XSR 1.6] size: 50.30 KB
Erase size: 15 MB
CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF]
CMT SOS+ROFS3 block sent
Programming completed in 0.076 s
Processing CNT file: RM596_APE_ONLY_ENO_11w15_v0.148.fpsx
[BB5,XSR 1.6] size: 4.05 MB
Erase size: 5 MB
CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF]
CMT SOS*ENO block sent
Programming completed in 0.800 s
Processing CNT file: RM-596_025.008_269.05_default_79.92.2011.37_01.uda.fp sx
[BB5,XSR 1.6] size: 91.31 MB
Erase size: 262 MB
CMT FLASH,MuxOneNAND area [0EA00000-1EFFFFFF]
Programming completed in 18.495 s
Total time for flashing process(boot+erase+write) was 1 min 5.234 s
11.34.000.2\HERA_usbalg.fg: OKPhone not found, retrying ...
11.34.000.2\BCM21351_XSR16_usbalg.fg: OKWarning: Phone did not reboot to normal mode.
em chạy ver cao nhất 25.8 nhờ anh em xem giúp.
