[MxKey Team HTI PLUS Flasher Interface 1], SN: C087A60C
Using device: HTI, FW ver: 00.50, SN: 0100D653
Driver: WinUSB, ver: 3.5.0.0
Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14205(18-07-2012)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
UEM ID: 00C60839A3BDA66
ASIC type: 11
UEM Imei: 35686902194378
Flash Imei: 35293502702286
Invalid imei checksum !
Processing MCU file: rh99_05.710
[DCT4,DCT4 ALGORITHM] size: 2.26 MB
Supported Ids: 2292
UEM ID: 00C60839:2984DA60
Area [01000000-0100FFFF] erased in 1.078 s
Area [01010000-013AFFFF] erased in 1 min 3.781 s
Area [013B0000-013EFFFF] erased in 4.422 s
Area [017C0000-017EFFFF] erased in 0.062 s
Area [01FC0000-01FEFFFF] erased in 0.078 s
Flash programming ...
Programming completed in 13.500 s
File processed in 1 min 30.031 s
Processing CNT file: rh990_nai5.71mr
[DCT4,DCT4 ALGORITHM] size: 110.62 KB
Supported Ids: 2292
ExtBUSC: 8020 1000 0000 0000 0000 0004 0000 0010
Area [01380000-013AFFFF] erased in 3.328 s
Programming completed in 0.734 s
Content extract fail, continue anyway ...
File processed in 1 min 16.938 s
Processing PPM file: rh99_05.71mr
[DCT4,DCT4 ALGORITHM] size: 1.13 MB
Supported Ids: 2292
Area [01240000-0124FFFF] erased in 1.094 s
Area [01250000-0137FFFF] erased in 20.828 s
Programming completed in 6.890 s
File processed in 35.890 s
Total time for flashing process(boot+erase+write) was 3 min 22.859 s
chay thì nó báo như thế này
A3BDA66
