1200 của e, e đã flash lại rồi ok hết, nhưng kẹp nguồn bấm lên 1 tý rồi đứng yên, e đã đo nguồn vcore 1,3, vflash 2,8, vio 1,7, vana 1,7 ai có hướng chỉ e với, a là gà mới
bạn vào full factory cho nó,mà bạn chạy bằng hộp gì vậy
bạn chạy sao?đưa log lên chiêm ngưỡng tí côi.
làm cả đời !! hết một giờ
Xem lại cọng cáp chân conec tren main
kiể tra lại mh + cáp +socket coi bạn
log info của e nè
MCU SW : V 4.51 13-12-07 RH-99 (c) NMP
PPM SW : V 4.51 13-12-07 RH-99 (c) NMP MR
Prd.Code: 0546885
Bpr.Code: 0544418
Prod.Sn : IOB023328
HW Vers : 2502
UEM : 1328
UPP : 8850 [2292]
RFIC Ver: 0700
DSP Vers: P06w45.v41
LCD Type: UNKWN: IDs: 00:ff:00
IMEI : 354167-02-235822-9
SL Conf : 001-01-00000000000
SL Prof : 000000000001000-2
SL Var : 00003541670223582200
SL Aux : 000B0000
HW Sig : 1F3632E1507A4531
Box Id : FFFFFFFFFFFFFFFF
BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
Provider: GSM Test Equipment
đây là e flash nè
Detected: V 4.51 13-12-07 RH-99 (c) NMP
1st Boot: Ok, DCT4, UPP: 2292 [Rh-99] [2.2.0.3]
2nd Boot: u3_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032
Algorithm: u3_st_i.fia, Ver: 4.79.0
Algorithm Ok, MSID: 8482E1018B84BE38A29E69B607
Decoded MSID: 3E4EBAE9-005A8F27-A8000000
Encoded FAID: EC9FA9DC-715AC33E-D1D0C70C
IMAGE: rh99_04.510
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:01
Area2: 0x01010000-0x013AFFFF Erased, Time: 01:04
Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:05
Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:13
IMAGE: rh990_nai4.51mr
Area1: 0x01380000-0x013AFFFF Erased, Time: 00:03
CNT Flashing Completed, Time: 00:00
Running: Server fake reply for CUI phone.
Contents Package Extracting Ok, Time: 00:06
IMAGE: rh99_04.51mr
Area1: 0x01240000-0x0124FFFF Erased, Time: 00:01
Area2: 0x01250000-0x0137FFFF Erased, Time: 00:21
PPM Flashing Completed, Time: 00:06
Flashing Completed, Rebooting Mobile
All Done, Time: 02:33
mong các a xem dùm e, e chân thành cảm ơn
thử file 5.91 xem sao bạn xong factory cho em nó phát,dòng này lát thoải mái mà bác nếu là jap thì chạy xong vào unlock xong bác vào factory la ok đả làm ok
nguyennhan8789 (07-12-2012)
cám on a nhiều để e thử coi
sao rùi chủ thớt
Yahoo:baclieutieusai
