Kết quả 1 tới 10 của 12
    Thành viên mới vutien192's Avatar
    Mar 2012
    Mặc định 1200 cần giúp
    em có con 1200 lỗi phần mềm em chạy thì dc như vậy có pro nào giúp em với em mới vào nghề không pít phải làm thế nào nữa MXKEY [MxKey Team HTI PLUS Flasher Interface 1], SN: C087A71E
    Using device: HTI, FW ver: 00.50, SN: 01009616
    Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14195(13-07-2012)
    ASIC ID: 0x2292 [UPPCosto ver: 1.3]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 0020 8828 [ST 58WR032FU,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: 8D50 9618 11AA 02A0 6D50 21C0 83C8 0414
    Algorithm: u3_st_i.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x4C30
    UEM ID: 0000FD7EA3BDA66
    ASIC type: 11
    UEM Imei: 35353202550530
    Flash Imei: F1A076E0E2CEC2
    Invalid imei checksum !
    Processing MCU file: rh99_05.910
    [DCT4,DCT4 ALGORITHM] size: 2.27 MB
    Supported Ids: 2292
    UEM ID: 0000FD7E:2984DA60
    Area [01000000-0100FFFF] erased in 0.984 s
    Area [01010000-013AFFFF] erased in 56.657 s
    Area [013B0000-013EFFFF] erased in 3.750 s
    Area [017C0000-017EFFFF] erased in 0.015 s
    Area [01FC0000-01FEFFFF] erased in 0.000 s
    Flash programming ...
    Programming completed in 13.578 s
    File processed in 1 min 21.828 s
    Processing CNT file: rh990_nai5.91mr
    [DCT4,DCT4 ALGORITHM] size: 110.59 KB
    Supported Ids: 2292
    ExtBUSC: AD7E B61A 1BBE 0BE2 7D58 6BE4 DBEE 6514
    Area [01380000-013AFFFF] erased in 2.875 s
    Programming completed in 0.656 s
    Extracting Content Pack, File Server fake reply for CUI phone.
    Content Pack extracted successfully in 0.031 s
    File processed in 15.969 s
    Processing PPM file: rh99_05.91mr
    [DCT4,DCT4 ALGORITHM] size: 1.13 MB
    Supported Ids: 2292
    Area [01240000-0124FFFF] erased in 1.016 s
    Area [01250000-0137FFFF] erased in 18.593 s
    Programming completed in 6.891 s
    File processed in 33.422 s
    Total time for flashing process(boot+erase+write) was 2 min 11.235 s
    Phone type: RH-99
    SW version: V 5.91 27-03-09 RH-99 (c) NMP
    Imei plain: ??????????????-?
    Product code: 0546885
    Cellular system: GSM
    ASIC ID: 0x2292, type: 0
    Ppm Id: MR
    Language Pack:
    - not available.
    Imei plain is invalid !!!
    SIMLOCK_DATA corrupted!
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    wire rpl vào rồi unlock phát
  3. ( duykhanh_gsm ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    vutien192 (12-12-2012)
    Imei plain: ??????????????-? bank imei rồi nếu backup full thì dùng hwk sửa lỗi cho em nó không thì kiếm log khac unluck cho nó cai
  5. ( Trường_Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    Thành viên mới VIETTEL-3G's Avatar
    Oct 2012
    Côn Đảo
    có MX thì múc cho em nó một phát rồi unlock
    0988.167.168
    Thành viên tích cực quang_hhbg's Avatar
    Mar 2011
    bắc giang
    unlock cho e nó 1 cái đi anh?
    quang_hhbg
    01686381111
  8. ( quang_hhbg ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  9. #6
    Mar 2012
    có ai không cứu em với em không pít chạy như vậy em chỉ pít chạy bình thường thui
  10. #7
    chỉ cách cho rồi còn cứu cái gì là use thì đem ra tiệm người ta làm cho
  11. ( Trường_Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #8
    mang qua mxbox umlock cho em nó là lươm lúa lien chứ gì
  13. ( mobingoc ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  14. #9
    Mar 2012
    vâng thế em cảm ơn các pro nhé có gj em post sau
  15. #10
    Mar 2012
    nam định
    bẹnh này có gì đâu chứ
    có mx box rồi thì lấy log online đi chứ còn đợi chờ gì nữa
    lấy dk imel rồi thì updata simlock nữa là có lúa
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
  16. ( A & T Mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  1. Trả lời: 3
    Bài viết cuối: 29-11-2012, 12:30
  2. 1200 đèn mờ xin giúp
    By huu_vinh in forum DCT4 - WD2
    Bài viết cuối: 14-09-2011, 09:25
  3. 1200 mất đèn cần giúp đỡ!
    By minhducs2 in forum DCT4 - WD2
    Bài viết cuối: 31-07-2010, 20:45
  4. 1200 cần giúp log
    By TrucLy1988 in forum DCT4 - WD2
    Bài viết cuối: 19-11-2009, 19:54
  5. nạp 1200 cần giúp đỡ
    By traitimbietmeu in forum DCT4 - WD2
    Bài viết cuối: 18-01-2009, 09:27
