    Thành viên tích cực 99999's Avatar
    Dec 2011
    Mặc định xem giúp log 1280
    máy rớt nước , đã vệ sinh kỷ , bắm phím nguốn kim nhít nhẹ , đã flash lại nhưng not ok , nhờ ae giúp
    đây là log của em nó
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 3], SN: C0855D93
    Using device: HTI, FW ver: 00.50, SN: 0000B3E9
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21151(13-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    Device synchronized.
    CPU: XGOLD 110
    Using embedded SBL from MCU.
    Sending EBL Loader ...OK
    Sending EBL ...OK
    Getting EBL Version ...
    Boot mode: 0xCC
    EBL version major/minor: 10.19
    EBL version: Default_RAM_Bootloader
    Set baud rate to: 921.60 Kbit/s
    Flash ID: 0020 88C0 - 23280003 [ST M58MWR064FU,64 Mbits]
    CFI information:
    Flash settings: 0/1, size: 0x00800000
    2 Block regions:
    127 x 0x00010000 = 0x007F0000
    8 x 0x00002000 = 0x00010000
    EBL ready !
    Processing file: rm647_006.200
    Downloading item CODE:hw_b2_rm647_r06.200.fls, num block: 3, size: 3.99 MB
    Erasing area 0x00800000-0x00A0FFFE ...OK
    Programming completed in 50.187 s
    Erasing area 0x00C60000-0x00E4D5BE ...OK
    Programming completed in 46.734 s
    Erasing area 0x00FFC000-0x00FFC03E ...OK
    Programming completed in 0.188 s
    Error reading checksum!
    Processing file: rm647_006.20mr
    Downloading item CUST:hw_b2_rm647_006.20mr.fls, num block: 1, size: 1.10 MB
    Erasing area 0x00210000-0x003288BE ...OK
    Programming completed in 24.578 s
    Checksum mismatch: Phone calculated 0x0033, software calculated 0xB874
    Processing file: rm6470_nai06.20mr
    Downloading item CUST:hw_b2_rm6470_nai06.20mr.fls, num block: 1, size: 305.83 KB
    Erasing area 0x00EB0000-0x00EFBA3E ...OK
    Programming completed in 6.453 s
    Checksum mismatch: Phone calculated 0x00F0, software calculated 0xD819
    Total time for flashing process(boot+erase+write) was 3 min 25.562 s
    Thành viên tích cực BMmobile's Avatar
    Dec 2012
    khò ép nhẹ con Xgold xem sao nhé bạn
    Mar 2012
    nam định
    cho cái log check lên nhìn cho dễ.
    rớt nước thì vệ sinh sạch sẽ.not ok gỡ con tích hợp ra làm lại chân
    ko dk thì thay mới chứ rớt nước ít khi do pm lắm
    HÃY HẾT LÒNG VÌ KHÁCH HÀNG
    Dec 2011
    còn đây là log check
    CPU: XGOLD 110
    Sending EBL ...OK
    Boot mode: 0xCC
    CFI information:
    2 Block regions:
    EBL ready !
    Mar 2012
    nam định
    làm con tích hợp đi thớt ơi
    lắc con tích hợp cpu đi bạn
    V.I.P duykhanh_gsm's Avatar
    Aug 2011
    khu đèn đỏ
    gỡ upp làm chân lun đi , dòng này upp có vĩ làm chân rồi sợ chi
    đo lại đường màn hình,đường bsi tù up ra,thay thử các tụ gần chân pin không được thì mới đung tới upp
    Dec 2011
    đã 0k do đức mạch màng hình , thanks all
  1. máy tầu 1280 xin giúp
    By hungmobile_90 in forum Phần mềm và các mã lệnh
    Bài viết cuối: 02-01-2014, 22:34
  2. cần giúp 1280 gọi báo hết pin .rui tắt máy
    By vanthanh1984_mobile in forum DCT4 - WD2
    Trả lời: 20
    Bài viết cuối: 13-09-2013, 10:08
  3. 1280 cần anh em giúp
    By thanhphuek in forum DCT4 - WD2
    Trả lời: 15
    Bài viết cuối: 14-06-2012, 06:09
  4. 1280 ko nhân sim xin giúp
    By mjnhtuan123 in forum DCT4 - WD2
    Trả lời: 20
    Bài viết cuối: 11-10-2011, 10:25
  5. cần anh em xem giúp log 1280
    By bvl_2811 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 30-09-2011, 12:39
