Kết quả 1 tới 10 của 18
    Thành viên mới syna's Avatar
    Mặc định C7-00 flash xong mất nguồn
    em vừa nhận con C7-00 khách đem đến chạy lại pm. em dùng mxbox flash xong giờ em nó ngủ luôn. đã dùng mxbox, HWK, besttool flash file đụng nóc mà em nó vẫn không lên.flash done nhưng máy không boot được . đã backup rpl+ pm full. anh em nào làm qua em này giúp em với....
    log của em nó đây.anh em xem giúp
    MXKEY [MxKey Team HTI Flasher Interface (WinUSB) 0], SN: C0850457
    Using device: USB Phonet and HTI, FW ver: 00.50, SN: 00007A9F
    Connection status: IUSB3XHC:IUSB3HUB::USB 2.00 (High-speed)
    Driver: nmwcdnsuc, ver: 7.1.32.75
    Module ver: 1.0.0.21200(18-07-2012), Library ver: 1.0.0.14214(25-10-2012)
    Processing MCU file: RM-675_111.040.1511_79u_prd.core.fpsx
    [BB5,XSR 1.6] size: 123.25 MB
    Supported Ids: 4003192102001104, 400C192102001104, 6003192102001104, 600C192102001104, 6003192102011104, 600C192102011104, 6003192102021104, 600C192102021104, 6003192102031104, 600C192102031104
    Waiting for USB ROM device ...
    CMT SYSTEM ASIC ID: 000000030000022600010007600C192102031104 [RAPUYAMA ver: 1.1]
    CMT EM0 ID: 00001040
    CMT EM1 ID: 00001030
    CMT PUBLIC ID: 05E00003C8D703447739813CFC75AAEC6BC39883
    CMT ASIC MODE ID: 00
    CMT ROOT KEY HASH: 916F75217F32081248B15C38DFC8E81B
    CMT ROM ID: E693EF0DAC22615B
    Loading CMT secondary boot code
    SecondaryBoot: RAPUv11_2nd.fg [BB5] version: 11.14.0 revision: 3.0 size: 0x3B40
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0068 - 0000 0131 [Samsung LH28F160BG] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: RAPUv11_XSR17_alg.fg [XSR 1.6] version: 11.14.0 revision: 3.0 size: 0xC66D5
    Update server code loaded.
    Waiting for USB device removal ...OK
    Waiting for USB device arrival ...OK
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 81897FA
    FUR: Adding Asic CMT as client OK.
    Reading CMT NPC (0x190 bytes).
    Reading CMT CCC (0x178 bytes).
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    Rpl(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35739504122940_CE RT.rpl).
    CMT PAPUBKEYS HASH: 95A68E9FA27B2BFA89EA204FC846EB73DEF1D93F
    Storing certificate [NPC, CCC, HWC, R&D, PARTNERC] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 489.06 MB
    CMT FLASH,MuxOneNAND area [00040000-0007FFFF]
    CMT FLASH,MuxOneNAND area [000C0000-008BFFFF]
    CMT FLASH,MuxOneNAND area [00DC0000-0E97FFFF]
    CMT FLASH,MuxOneNAND area [2E100000-3E5FFFFF]
    Formating partition ...
    Flash programming ...
    CMT ADA block sent
    CMT KEYS block sent
    CMT PRIMAPP block sent
    CMT RAP3NAND block sent
    CMT SOS+PMML block sent
    CMT SOS+DECOMP block sent
    CMT PASUBTOC block sent
    CMT PAPUBKEYS: 95A68E9F [RAP Certificate v1 263] sent
    CMT GENIO_INIT block sent
    CMT SOS+IVE3A block sent
    CMT SOS*UPDAPP block sent
    CMT SOS*DSP0 block sent
    CMT LDSP block sent
    CMT SOS*ISASW block sent
    CMT SOS+CORE block sent
    CMT SOS+ROFS1 block sent
    Programming completed in 17.343 s
    Processing PPM file: RM-675_111.040.1511_19.01_Vietnam_79u_prd.rofs2.fpsx
    [BB5,XSR 1.6] size: 36.52 MB
    Erase size: 59.25 MB
    CMT FLASH,MuxOneNAND area [09F40000-0DA7FFFF]
    CMT SOS+ROFS2 block sent
    Programming completed in 5.212 s
    Processing PPM file: RM-675_111.040.1511_C02.01_SEAP_79u_prd.rofs3.fpsx
    [BB5,XSR 1.6] size: 30.49 KB
    Erase size: 15.16 MB
    CMT FLASH,MuxOneNAND area [01378000-0139FFFF]
    CMT FLASH,MuxOneNAND area [0DA80000-0E97FFFF]
    CMT SOS+ROFS3 block sent
    CMT SOS+IVE3B block sent
    Programming completed in 0.070 s
    Processing CNT file: rm675_ENO_v_0.0514_APEONLY.fpsx
    [BB5,XSR 1.6] size: 4.73 MB
    Erase size: 5 MB
    CMT FLASH,MuxOneNAND area [008C0000-00DBFFFF]
    CMT SOS*ENO block sent
    Programming completed in 0.700 s
    Processing CNT file: RM-675_111.040.1511_U03.01_79u.uda.fpsx
    [BB5,XSR 1.6] size: 217.71 MB
    Erase size: 503.50 MB
    CMT FLASH,MuxOneNAND area [0E980000-2E0FFFFF]
    Programming completed in 33.336 s
    Total time for flashing process(boot+erase+write) was 1 min 11.358 s
    Phone not found, retrying ...
    Warning: Phone did not reboot to normal mode.
    máy không đồng bộ được bác vệ xinh tiếp xúc lại xem sao,
  3. ( mobingoc ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    syna (24-12-2012)
    Thành viên tích cực thaitg85's Avatar
    Mar 2011
    Củ Chi
    load Navifirm ver cao nhất về múc bằng phoenix xem thế nào ,mà chủ thớt cung cấp thông tin ban đầu thế nào mà chạy lại vậy ?
    ĐTDĐ QUỐC THÁI kp7 thị trấn Củ Chi TPHCM :0985282520
  5. ( thaitg85 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    syna (24-12-2012)
    chuyển qua Box khác flash lại thử => nếu cần kiếm File để flash => thì có thể vào đây Dow nha anh !
  7. ( Lính Khang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    syna (24-12-2012)
  8. #5
    Trích Được post bởi thaitg85 Xem bài viết
    em da down file cao nhất từ navifim nhưng vẫn vậy. máy ban đầu khách báo vào các ứng dụng rất chậm, nên mới đem flash ai dè...hic..
  9. #6
    Trích Được post bởi syna Xem bài viết
    Anh có cái Box đời cao nào không => như ATF hay MT-Box gì đấy đấy => thì mới chiến với em nó nỗi => chứ có mổi mình cái mx duy nhất => thì củng không giải quyết được vấn đề gì đâu => MX thì chỉ dùng để ( Fix Software ) thôi => chứ chạy mấy cây BB5 đời cao sau này thì có ngày đi như chơi => nếu anh không có mấy cái box mà em đả nêu như ở trên => thì đi kiếm anh nào cao tay ấn hơn rồi nhảy kèo cho nhanh => chứ anh tính ôm em nó đến khi phát nỗ àh !
    BR,
    NKMobile™
  10. ( Lính Khang ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    syna (24-12-2012)
  11. #7
    có lẽ nghiên cứu thêm chút nữa không được thì cũng đành chia tay em nó thôi, chắc phải làm thêm em ATF về chiến quá.
  12. #8
    Mar 2011
    Củ Chi
    bạn nên nhờ ae kỹ thuật nào cứng phần mềm giúp giùm,vì mxbox yếu lắm chạy thường bị chết lắm ,chúc may mắn !!
  13. ( thaitg85 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    syna (24-12-2012)
  14. #9
    em này lấy phonix chiến đc bạn dow ver khác trên nafavim về nhé nhiều con chạy mấy file moaays đc chúc bạn thành công
  15. ( duchanh0885 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    syna (24-12-2012)
  16. #10
    Thành viên tích cực BMmobile's Avatar
    Dec 2012
    Trích Được post bởi NKMobile™ Xem bài viết
    Vệ sinh tiếp xúc cáp lại đi anh => hoặc chuyển qua Box khác flash lại thử => nếu cần kiếm File để flash => thì có thể vào đây Dow nha anh !
    log này đang flash qua USB nhé vệ sinh tiếp súc gì trời đâu phải cáp Fbus đâu mà vệ sinh
Hiện có 3 người đang xem bài này . Bao gồm : 0 thành viên và 3 khách
  1. nokia N70 nạp Flash xong máy báo ok nhưng mở nguồn lên chữ Nokia xong tắt luôn
    By huuphucmobile2012 in forum Phần mềm và các mã lệnh cho Nokia
    Bài viết cuối: 09-04-2013, 18:47
  2. Trả lời: 13
  3. Trả lời: 8
    Bài viết cuối: 26-10-2010, 14:24
  4. Trả lời: 3
    Bài viết cuối: 16-07-2010, 15:34
  5. flash xong 1209 nhưng ko lên nguồn !!!
    By phambaubi in forum J.A.F
    Bài viết cuối: 25-02-2010, 12:44
