    Thành viên mới qs_87_mobile's Avatar
    Jan 2013
    thaibinh
    Mặc định mấy anh xem hộ em cai log 1200 voi bus dc nhưng ko ìno dc
    MXKEY [MxKey Team HTI PLUS Flasher Interface 2], SN: C087C2B6
    Using device: HTI, FW ver: 00.50, SN: 0100DAFA
    Connection status: EHCI:HUB:HUB:USB 2.00 (Full-speed)
    Driver: WinUSB, ver: 3.5.1.0
    Module ver: 1.0.0.21313(12-12-2012), Library ver: 1.0.0.14337(12-12-2012)
    ASIC ID: 0x2292 [UPPCosto ver: 1.3]
    SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
    FlashID0: 0089 8872 [Intel 28F320W18,32 Mbits] page size: 64 K type: NOR area: 01000000-013FFFFF
    ExtBUSC: DEAD DEAD DEAD DEAD DEAD DEAD DEAD DEAD
    Algorithm: u3_intel.fia [DCT4 ALGORITHM] version: 4.76.0 revision: 0.7 size: 0x56A0
    UEM ID: 00173C85A3BDA66
    ASIC type: 11
    UEM Imei: 35293102072813
    Flash Imei: 35293102072813
    RPL saved to "C:\mobileEx\3.5\data\backup\RPL\35293102072813_BA CK.rpl"
    Processing MCU file: rh99_06.000
    [DCT4,DCT4 ALGORITHM] size: 2.26 MB
    Supported Ids: 2292
    UEM ID: 00173C85:2984DA60
    Area [01000000-0100FFFF] erased in 0.562 s
    Area [01010000-013AFFFF] erased in 34.391 s
    Area [013B0000-013EFFFF] erased in 2.422 s
    Area [017C0000-017EFFFF] erased in 0.015 s
    Area [01FC0000-01FEFFFF] erased in 0.016 s
    Flash programming ...
    Programming completed in 18.640 s
    File processed in 1 min 3.078 s
    Processing CNT file: rh990_nai6.00mr
    [DCT4,DCT4 ALGORITHM] size: 110.55 KB
    Supported Ids: 2292
    ExtBUSC: 010A A618 09B4 0982 7900 2AE0 D326 0110
    Area [01380000-013AFFFF] erased in 1.844 s
    Programming completed in 0.891 s
    Content extract fail, continue anyway ...
    File processed in 49.141 s
    Processing PPM file: rh99_06.00mr
    [DCT4,DCT4 ALGORITHM] size: 1.13 MB
    Supported Ids: 2292
    Area [01240000-0124FFFF] erased in 0.563 s
    Area [01250000-0137FFFF] erased in 11.094 s
    Programming completed in 9.218 s
    File processed in 27.906 s
    Total time for flashing process(boot+erase+write) was 2 min 20.125 s
    Aborting operation ...
    Operation aborted by user reques
    Jan 2013
    thaibinh
    ASIC type: 11
    Flash Imei: 5F6B93C2D163D9
    MasterCode: 7A1907CDBB
    Invalid imei checksum !
    Thành viên tích cực tientrung199x's Avatar
    hình như bị ic flash rồi sao ý... thay flash hoặc làm chân đóng lại xem
  4. ( tientrung199x ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    qs_87_mobile (24-01-2013)
    Thành viên tích cực BMmobile's Avatar
    Dec 2012
    chuyen sang box khác đi bạn mxbox check dct4 chuối lắm
    Trích Được post bởi BMmobile Xem bài viết
    bạn cho mình xin lỗi vì ngày hôm qua ăn nói thô lỗ quá.....
    Tại mình không biết bạn là Nữ giới
    Jan 2013
    thaibinh
    thank mọi người nhé.đã thay flas ok
  1. Trả lời: 3
    Bài viết cuối: 29-11-2012, 12:30
  2. 1200 liệt phím
    By thaimobile_81 in forum DCT4 - WD2
    Bài viết cuối: 26-12-2010, 12:08
  3. 1200
    By nguyentruong_tho44 in forum DCT4 - WD2
    Bài viết cuối: 08-06-2009, 21:58
  4. ghi rpl 1200
    By hieuchetlien in forum DCT4 - WD2
    Bài viết cuối: 12-12-2008, 09:30
