    Thành viên mới ductaimobileee's Avatar
    Mar 2012
    Mặc định xin giúp x2-00 mất nguồn, long mxbox em no dây
    xin giúp x2-00 mất nguồn.vao menu được rồi tăt nguồndda3 chay ok atf,hwk,phoneni
    long mxbox baothee1 này
    eBB5ProtocolType: NEW
    Secondary boot loaded.
    Storage2: 0000 0000 - 0000 0000 [unused/removed] type: FLASH,NOR, asic:CMT
    Storage4: 00EC 0030 - 0000 0431 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: FLASH,MuxOneNAND, asic:CMT
    Suggested algorithm: XSR 1.6
    Algorithm: BCM21351_XSR16_usbalg.fg [XSR 1.6] version: 11.14.0 revision: 2.1 size: 0x8FC7D
    Supported Ids: 22000209200C0000, 2200020920030000, 22000509200C0000, 2200050920030000
    Update server code loaded.
    Waiting for USB device removal ...
    Device connected: nmwcdnsuc\Nokia USB Flashing Generic, PORT_ID: 880E3B3
    FUR: Adding Asic CMT as client OK.
    Reading CMT HWC (0xD4 bytes).
    Reading CMT R&D (0x0 bytes).
    RPL(CERT) backup already exist (C:\mobileEx\3.5\data\backup\BB5_35827404201798_CE RT.rpl).
    CMT PAPUBKEYS HASH: E9700989029D9E899915F781B1582048E042A738
    Storing certificate [NPC, CCC, HWC, R&D] ...OK
    Partitioning....
    Partitioning complete
    Erase size: 32.88 MB
    CMT FLASH,MuxOneNAND area [00000000-0001FFFF]
    CMT FLASH,MuxOneNAND area [00020000-000203FF]
    CMT FLASH,MuxOneNAND area [00060000-011BFFFF]
    CMT FLASH,MuxOneNAND area [011C0000-01CFFFFF]
    CMT FLASH,MuxOneNAND area [02500000-028FFFFF]
    Formating partition ...
    Flash programming ...
    CMT KEYS block sent
    CMT PAPUBKEYS: E9700989 [RAP Certificate v1 237] sent
    CMT PRIMAPP block sent
    CMT PASUBTOC block sent
    CMT ADA block sent
    CMT RAP3NAND block sent
    CMT ISA+DYNSW block sent
    CMT MCUSW block sent
    CMT MCUSW1 block sent
    CMT GENIO_INIT block sent
    CMT UPDAPP block sent
    Programming completed in 8.406 s
    Processing PPM file: rm618__08.35.ppm_v
    [BB5,XSR 1.6] size: 6.98 MB
    Supported Ids: 2200050920030000, 22000509200C0000
    Erase size: 8 MB
    CMT FLASH,MuxOneNAND area [01D00000-024FFFFF]
    Programming completed in 2.359 s
    Processing CNT file: rm618__08.35.image_v_059B618
    [BB5,XSR 1.6] size: 20.99 MB
    Erase size: 76.31 MB
    CMT FLASH,MuxOneNAND area [02900000-0753FFFF]
    Programming completed in 7.094 s
    Total time for flashing process(boot+erase+write) was 27.563 s
    Open device failed: FFFFFFFF (4) The system cannot open the file
    Warning: Phone did not reboot to normal mode.
    [RebootFromFlashMode] Please press "OK" or "Accept" on your phone (if SIM Card is not inserted to the phone) !
    Market items is empty, please select the correct products path !
    long atf
    Processing Image File :
    rm618__08.35.mcusw
    CMT Type : BB5
    CMT Algorithm : XSR 1.6
    Secondary Sending Speed : 650000Hz
    Algorithm Sending Speed : 6500000Hz
    Program Sending Speed : 6500000Hz
    Message Reading Speed : 98000Hz
    Number of Blocks : 511
    Entry Point: 0x01E5
    Page Format : -1
    MAX PAGE : 0x0000E000
    rm618__08.35.ppm_v
    CMT Type : BB5
    Number of Blocks : 128
    Entry Point: 0x0100
    Page Format : -1
    CMT Type : BB5
    Number of Blocks : 384
    Entry Point: 0x0134
    Page Format : -1
    AUTO SELECTED DEAD USB FLASHING...
    If Phone Booting does not Start in 5 Seconds,
    Then Perform Steps 1, 2, 3 and 4...
    1. Remove USB and Battery...
    2. Insert USB.
    3. Insert Battery. (Some phones boot automatically)
    4. Please Power on phone shortly...
    AdvanceFBox SendBootCodeEx
    InitialiseBootstrap_DCT5 DIR
    BootFlashMode_DCT5
    READING BOOTROM
    SYSTEM_ID_RESPONSE_BB5 (0xC0) - 86 (0x56) bytes returned
    Number of Sub Blocks 6 (0x06)
    1 SYSTEM_ASIC_ID 01
    Block Length : 17 (11)
    BB ASIC Index : 0 (00) CMT
    ID DWORD 0 : 00000000
    ID DWORD 1 : 00000000
    ID DWORD 2 : 22000509
    ID DWORD 3 : 200C0000
    2 EM_ASIC_ID 02
    Block Length : 5 (05)
    ID DWORD 0 : 00005361
    3 PUBLIC_ID 12
    Block Length : 21 (15)
    ID DWORD 1 : 009C8585
    ID DWORD 2 : 7BB1DC2C
    ID DWORD 3 : FD4BE67E
    ID DWORD 4 : 77B5C4DC
    4 ASIC_MODE_ID 13
    Block Length : 2 (02)
    Mode Id : 00
    5 ROOT_KEY_HASH 14
    Hash : 1B 0D 74 C5 32 CA 1C 61 33 94 0C 74 0E 8C 78 6E
    6 ROM_ID 15
    Block Length : 9 (09)
    CRC 0 : DE56D582
    CRC 1 : BDDE7A3A
    CMT Secondary Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_usb2nd.fg
    Secondary Loader Sent....
    MessageID : C1
    SubBlocks : 06
    Block Length : 0B
    BB ASIC Index : CMT 00
    Device Type : RAM 05
    Device Index : 00
    Manufacturer Code : 0000 -> Flash
    Device ID : 0000 -> Type not in database
    Extended/Fixed ID : 0000
    Revision ID : 0000
    2 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MMC 04
    Device Index : 00
    Revision ID : 0000
    Block Length : 0B
    Device Type : NOR 00
    Device Index : 00
    Revision ID : 0000
    4 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Index : 01
    Manufacturer Code : 0000 -> SPANSION
    Device ID : 0001 -> Type not in database
    Revision ID : 0000
    5 Sub Block ID : 10 STORAGE_DEVICE_ID_BB5
    Block Length : 0B
    Device Type : MuxOneNAND 03
    Device Index : 00
    Manufacturer Code : 00EC ->
    Device ID : 0030 -> Type not in database
    Revision ID : 0431
    6 Sub Block ID : 35 NAND_DRIVER_VERSION_BB5
    Block Length : 09
    Data : XSR 1.6
    Flash Descriptor
    Device ID : 0030
    Revision ID : 0000
    Size : 08000000 (128 MB)
    VPP Info : 0000
    Erase10s : 1E
    Block1s : 32
    BErase1s : 02
    Reserved0 : 00
    Reserved1 : 00
    Reserved2 : 00
    CMT Algorithm Loader: C:\AdvanceBox Turbo Flasher\Nokia\BB5_Loader\New\BCM21351_XSR16_usbalg .fg
    Algorithm Loader Sent...
    FUR_Control_AddClient_BB5() ASIC_INDEX_CMT (Ready)
    FUR control Ok
    START READING RPL DATA
    IMEI: 358274042017987
    Reading : NPC... OK!
    Reading : CCC... OK!
    Reading : HWC... OK!
    Reading : R&D... OK!
    NPC CERTIFICATE INFORMATION (CMT):
    IMEI : 358274042017987
    PRODUCT CODE : 059C4G1
    BLUETOOTH ID : AC:81:F3:A0:87:C0
    PUBLIC_ID : 00000000009C85857BB1DC2CFD4BE67E77B5C4DC
    PAPUB_KEYS_HASH: E9700989029D9E899915F781B1582048E042A738
    CCC CERTIFICATE INFORMATION (CMT):
    HWC CERTIFICATE INFORMATION (CMT):
    RPL Backup was Successful...
    Plain RPL saved to:
    C:\AdvanceBox Turbo Flasher\Nokia\Backup\358274042017987\3582740420179 87_90114.rpl
    PA PUBLIC KEY Request
    PHONE_INFO_RESPONSE_BB5
    PAPUB_KEYS_HASH_RESP_BB5 2A
    BB Asic Index : 00
    CMT PAPUBKEYS HASH:
    ImagePath: C:\Program Files\Nokia\Phoenix\Products\RM-618\
    ImageFilename: rm618__08.35.mcusw
    Read Type : FIASCO_BB5_DO_NOT_READ_CERTIFICATE (01)
    Sending STORE_CERTIFICATE_REQUEST_BB5 (CMT 00 only)
    Certificate 1
    ASIC Index : CMT 0
    Certificate 2
    ASIC Index : CMT 0
    Certificate 3
    ASIC Index : CMT 0
    Certificate 4
    ASIC Index : CMT 0
    STORE_CERTIFICATE_REQUEST_BB5 : 61 04 2B 0D 4E 50 43 00 00 00 00 00 00 00 00 00 00 2B 0D 43 43 43 00 00 00 00 00 00 00 00 00 00 2B 0D 48 57 43 00 00 00 00 00 00 00 00 00 00 2B 0D 52 26 44 00 00 00 00 00 00 00 00 00 00 D3
    STORE_CERTIFICATE_REQUEST_BB5 : No Error - 0 (0x00)
    ProcessPartitionInfo_DCT5...
    Partition Info
    Partition Blocks : 1
    1 PARTITION_INFO_BB5
    BB ASIC Index : 0x00 CMT
    Device Type : 0x03 MuxOneNAND
    Device Index : 0x00
    Partition Version : 00010000
    Spare : FFFFFFFF
    Num Partitions : 00000004
    Partition 1
    Attribute : 00000002 RO
    Start Address : 00020000
    Partition 2
    ID : 00000008 FILESYSTEM
    Attribute : 00000001 RW
    Start Address : 02900000
    Partition 3
    Start Address : 07540000
    Partition 4
    Start Address : 07B40000
    PARTITION_INFO_REQUEST_BB5 : 64012F4F00030000010000FFFFFFFF00000004000000030000 000200020000024E000000000008000000010290000004C400 000000000A0000000107540000006000000000000B00000001 07B40000001800001D
    PARTITION_INFO_REQUEST_BB5 : No Error - 0 (0x00)
    StartErase_DCT5...
    BlockLength : 0x90 (144)
    ERASE Blocks : 0x03 (3)
    0 ERASE_AREA_BB5 0x12
    Block Length : 0x2B (43)
    Device Index : 0x00
    0 : 00000000-0001FFFF
    1 : 00020000-000203FF
    2 : 00060000-011BFFFF
    3 : 011C0000-01CFFFFF
    4 : 02500000-028FFFFF
    1 FORMAT_PARTITION_BB5 0x19
    Block Length : 0x2F (47)
    Device Index : 0x00
    Format Info ID : 0x02000000
    Format Info : 000000000000000A0000000100000002000000640000000200 000002000000010000000000000000
    2 FORMAT_PARTITION_BB5 0x19
    Device Index : 0x00
    Format Info : 000000000000000B0000000000000002000000640000000200 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5005120B000300000000000001FFFF120B0003000002000000 0203FF120B00030000060000011BFFFF120B000300011C0000 01CFFFFF120B00030002500000028FFFFF69
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000A000000010000 00020000006400000002000000020000000100000000000000 003B
    FORMAT_REQUEST_BB5 : 5001192F00030000000002000000000000000B000000000000 00020000006400000002000000020000000100000000000000 003B
    Successfully Erased...
    Total blocks to write : 511
    >> CMT Rootkey Hash CERT : KEYS
    >> CMT Rootkey Hash CERT : PAPUBKEYS [E9700989029D9E899915F781B1582048E042A738]
    >> CMT Rootkey Hash CERT : PRIMAPP
    >> CMT Rootkey Hash CERT : PASUBTOC
    >> CMT Rootkey Hash CERT : ADA
    >> CMT Rootkey Hash CERT : RAP3NAND
    >> CMT Rootkey Hash CERT : ISA+DYNSW
    >> CMT Rootkey Hash CERT : MCUSW
    >> CMT Rootkey Hash CERT : MCUSW1
    >> CMT Rootkey Hash CERT : GENIO_INIT
    >> CMT Rootkey Hash CERT : UPDAPP
    ImageFilename: rm618__08.35.ppm_v
    StartErase_DCT5...
    BlockLength : 0x0E (14)
    ERASE Blocks : 0x01 (1)
    Block Length : 0x0B (11)
    Device Index : 0x00
    0 : 01D00000-024FFFFF
    ERASE_REQUEST_BB5 : 5001120B00030001D00000024FFFFFBE
    Total blocks to write : 128
    ImageFilename: rm618__08.35.image_v_059B618
    StartErase_DCT5...
    BlockLength : 0x3F (63)
    ERASE Blocks : 0x02 (2)
    Device Index : 0x00
    0 : 02900000-0753FFFF
    Device Index : 0x00
    Format Info : 00000000000000080000000000000002000000640000000200 000002000000010000000000000000
    ERASE_REQUEST_BB5 : 5001120B000300029000000753FFFFF4
    FORMAT_REQUEST_BB5 : 5001192F000300000000020000000000000008000000000000 00020000006400000002000000020000000100000000000000 003E
    Total blocks to write : 384
    ContinueFlash_DCT5 Complete
    Continue Flash Complete : : No Error - 0 (0x00)
    STATUS_REQUEST_BB5...
    1 Sub Block ID : 15 STATUS_NAND_OK_BB5
    Block Length : 0F
    BB ASIC Index : 00
    Device Type : 03
    Device Type : 00
    Num Bad Blocks : 00000000
    Additional Bad : 00000000
    Correctable ECC : 00000000
    FlashInfo.RestartMode : 2
    Flashing Done...
    Total Flashing Time (Erase + Flashing) : 00:00:09
    (Booting time is NOT Included)
    Waiting for Phone to Start-Up..(Max 150 seconds)
    SW: V 08.35 09-01-12 RM-618 (c) Nokia
    CONFIG KEY : 0000000000000000
    PROVIDER KEY : 2440700000000000
    NETWORK NAME : Nokia Default;Finland
    LOCK COUNTERS : KEYPRESS 0/3, FBUS 0/10
    SIMLOCK TABLE :
    Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open
    Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open
    SIMLOCK STATE : Not Locked
    SIMLOCK_TEST : PASSED
    SECURITY_TEST : PASSED
    SUPER_DONGLE_TEST : PASSED
    SECURITY_CODE : 12345
    SL3 Phone detected
    * Firmware Version Downgrade will KILL PHONE !!!
    * Manual Full Erase WILL KILL PHONE!!!
    * Simlocks are in PM 120 Only...
    * PM 308 is Write Protected...
    thay con như hình nhé
    [/IMG]
    gmail: Doanhtruong_090
    Agribank STK:3503205057189
    Mar 2012
    Trích Được post bởi DoanhTruong_090 Xem bài viết
    [/IMG]
    sao không xem hình được vậy ta
    linh lỗi không upanh được bác thay con 47k gần đầu cục rung thử xem sao đã gặp
    Mar 2012
    [QUOTE=DoanhTruong_090;956029]linh lỗi không upanh được bác thay con 47k gần đầu cục rung thử xem sao đã gặp[/QUOTEdde63
    mình xem thử,con trở dó mất rồi
    kiếm con khác ráp vào không đem ra tiện ae mobile làm cho
    Mar 2012
    làm theo anh dược rồi cám ơn thật nhiều nhé .giờ mới biết pan này
    Thành viên mới kimthoaduy's Avatar
    tiền giang-long an-hcm
    ai giúp em với hjz
    em flaash x2-00 bằng usb mxbox nó ra thế này
    ERROR: Failed to start boot !
  1. xem giúp em long con 2730 voi
    By quangminh.mobile in forum BB5
    Trả lời: 16
    Bài viết cuối: 08-08-2013, 23:33
  2. Trả lời: 4
    Bài viết cuối: 05-07-2013, 17:35
  3. Trả lời: 4
    Bài viết cuối: 25-10-2012, 18:17
  4. anh em xem ho cai long
    By langngo in forum BB5
    Bài viết cuối: 20-11-2009, 10:32
