    Thành viên kỳ cựu newnice's Avatar
    Mar 2012
    hải dương
    Mặc định 1280 chết nguồn cần giúp thanks all
    em có con 1280 bị chết nguồn chạy phần mềm nó ko đồng bộ được
    em đã đóng lại cặp và thay thạch anh nhưng vẫn ko được
    bác nào gặp qua giúp em vơi em cảm ơn
    đây là log của nó các bác giúp em với
    VBATT Powering Down <<<<
    VBATT Powering Up >>>>
    SET VCCIO Level Done
    SET BSI Load Done
    Booting Phone...
    CPU ID Response: A200341100
    CPU Type: XG110 2.1B
    Phone Booted at after First attempt...
    TIME STARTS HERE
    Sending PBL 19456 bytes...
    PBL Successfully Sent...
    Sending SBL 65024 bytes...
    SBL Successfully Sent...
    Flash Chip Manufacturer: STMicroelectronics
    Flash Chip Type: M58WR064 64 Mbit (4Mb x 16) NOR
    Extended Information: Multiple Bank / Burst / 1.8v
    Processing Image File: C:\Program Files\Nokia\Phoenix\Products\rm-647\rm647_006.510
    FIRMWARE Image Found...
    Number of Sections: 03
    FIRMWARE Certificate Block Sent Successfully...
    Processing Section 01 of 03
    FIRMWARE Erase Block: 0x00800000~0x00A0FFFE
    Start Erasing...
    Erasing Please Wait...
    Block Erase Done...
    Preparing Data Blocks...
    Data Size: 2162688 bytes
    Data Checksum: 5EF5
    Uploading Data Blocks to phone...
    FIRMWARE Data Blocks uploaded to phone...
    Processing Section 02 of 03
    FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 2069312 bytes
    Data Checksum: F587
    Processing Section 03 of 03
    FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE
    Start Erasing...
    Block Erase Done...
    Data Size: 64 bytes
    Data Checksum: 0000
    Start Data Verification... (Please wait)
    Data Verification Successful...
    Processing Image File: C:\Program Files\Nokia\Phoenix\Products\rm-647\rm647_006.51mr
    PPM Image Found...
    Number of Sections: 01
    PPM Certificate Block Sent Successfully...
    Processing Section 01 of 01
    PPM Erase Block: 0x00210000~0x003288BE
    Start Erasing...
    Block Erase Done...
    Data Size: 1149120 bytes
    Data Checksum: 0715
    PPM Data Blocks uploaded to phone...
    Processing Image File: C:\Program Files\Nokia\Phoenix\Products\rm-647\rm6470_nai06.51mr
    CONTENT Image Found...
    CONTENT Certificate Block Sent Successfully...
    CONTENT Erase Block: 0x00EB0000~0x00EFBA3E
    Start Erasing...
    Block Erase Done...
    Data Size: 309824 bytes
    Data Checksum: D0A1
    CONTENT Data Blocks uploaded to phone...
    Exit Flash Mode Done...
    Time Elapse : 00:02:28
    You must Factory Reset the phone to enable the
    ringtones and other customized settings to work
    Waiting For Phone to go Online...
    5, 4, 3, 2, 1...
    ERROR : PHONE READ INFO FAILED
    Đời___Là__Bể___Khổ
    Thành viên chính thức thanhmobi089's Avatar
    May 2013
    qua minh thay cặp cho ok
  3. ( thanhmobi089 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    newnice (17-05-2013)
    Thành viên tích cực haomobilest's Avatar
    Nov 2012
    không dao động u chắc ngủm rồi cần thay cặp khác rồi...
    'haomobilest@yahoo.com':o
  5. ( haomobilest ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    May 2012
    Trích Được post bởi haomobilest Xem bài viết
    dòng này chíp rất trâu, muốn nó chết cũng khó mà chết.. mình đóng đổ cả chục lần mà ko die. vì nó lỗi nên ko có sóng tức quá đục ra đóng vô nhiều lần mà nó vẫn trơ trơ
  7. ( LÊ_TRUNG ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    newnice (18-05-2013)
  8. #5
    V.I.P LOC_PHAT_ĐAT's Avatar
    Jan 2010
    nếu có cập tes thử xem..thì ra bệnh lần sau có kinh nghiệm liền mà.
  9. ( LOC_PHAT_ĐAT ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  10. #6
    Thành viên tích cực Chiến_mobile's Avatar
    Oct 2012
    Trích Được post bởi LOC_PHAT_ĐAT Xem bài viết
    cách này đẻ láy kinh nghiệm lần sau
    nghệ an quê choa >>> 0967 398 678 ....cuche_pro@yahoo.com
  11. ( Chiến_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
  12. #7
    Mar 2012
    hải dương
    em cũng ngĩ là tại cặp vì lần trước em lắc thì nó lên
    song ùi 2 hôm sau quay lại thì nó ngủ luôn
    Đời___Là__Bể___Khổ
  1. 1280 rớt chạm nguồn
    By truongmobile147 in forum DCT4 - WD2
    Bài viết cuối: 25-09-2013, 19:15
  2. 1280 chập nguồn
    By utnam7787 in forum DCT4 - WD2
    Bài viết cuối: 15-09-2013, 14:07
  3. cân` anhem giúp gấp 1280 chạm nguôn`
    By lequocthang25 in forum BB5
    Trả lời: 14
    Bài viết cuối: 23-05-2013, 13:24
  4. 1280 chập phím mở nguồn
    By sondlat in forum DCT4 - WD2
    Bài viết cuối: 13-03-2013, 11:25
  5. 1280 chập phím nguồn
    By yenmobile88 in forum DCT4 - WD2
    Bài viết cuối: 21-06-2012, 22:00
