Code:AUTO SELECTED DEAD USB FLASHING... If Phone Booting does not Start in 5 Seconds, Then Perform Steps 1, 2, 3 and 4... 1. Remove USB and Battery... 2. Insert USB. 3. Insert Battery. (Some phones boot automatically) 4. Please Power on phone shortly... Infineon USB Boot: F00A1FB300020303010100FF Sending PBL... PBL Successfully Sent... Sending SBL... SBL Successfully Sent... Setting Transmission Speed Done... Flash Chip Manufacturer: Intel Electronics Corp. Flash Boot Successful... Unique Data: 02600C069A0A2824 Original Product Code: 059Q093 Reading : CCC... OK! Reading : HWC... OK! Reading : NPC... OK! RPL Backup was Successful... Plain RPL saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355499052569980\355499052569980_52601.rpl Certificate Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355499052569980\355499052569980_CERTIFICATE_F45888F0.bin PM Block Saved to: C:\AdvanceBox Turbo Flasher\Nokia\Backup\355499052569980\355499052569980_PMM_PROT_772B983F.bin Security Code: 12345 Data Sections : 04 Current File : rm862__03.19.mcusw Compile Name: rm862__03.19.mcusw_ebl_psi.fls Image Type : Main Firmware Data Size : 26217864 Bytes Sending Certificate Block FIRMWARE Certificate Block Sent Successfully... Processing Section 01 FIRMWARE Erase Block: 0x40000000~0x4001FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: B10A Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 02 FIRMWARE Erase Block: 0x40040000~0x4005FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 131072 bytes Data Checksum: 7A56 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 03 FIRMWARE Erase Block: 0x40060000~0x4015FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 1048576 bytes Data Checksum: DD7C Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 04 FIRMWARE Erase Block: 0x40280000~0x41A3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 24903680 bytes Data Checksum: C132 Uploading Data Blocks to phone... Block Write Successful... FIRMWARE Data Blocks uploaded to phone... Processing Section 05 FIRMWARE Erase Block: 0x43E20000~0x43E5FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm862__03.19.ppm_v Compile Name: package_v.ppm_ebl_psi.fls Image Type : PPM Image Data Size : 5609328 Bytes Sending Certificate Block PPM Certificate Block Sent Successfully... Processing Section 01 PPM Erase Block: 0x41A40000~0x4207FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 5605984 bytes Data Checksum: 6D3E Uploading Data Blocks to phone... Block Write Successful... PPM Data Blocks uploaded to phone... Data Verification Successful... Data Sections : 01 Current File : rm862__03.19.image_v_059Q094 Compile Name: package_v_059Q094.image.fls Image Type : CONTENT Package Data Size : 15994128 Bytes Sending Certificate Block CONTENT Certificate Block Sent Successfully... Processing Section 01 CONTENT Erase Block: 0x42080000~0x43E1FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 15990784 bytes Data Checksum: C78C Uploading Data Blocks to phone... Block Write Successful... CONTENT Data Blocks uploaded to phone... Processing Section 02 CONTENT Erase Block: 0x43E60000~0x43F3FFFE Start Erasing... Erasing Please Wait... Block Erase Done... Data Verification Successful... Data Sections : 01 Current File : rm862__03.19_sd_empty_2048.fpsimage Compile Name: rm862__03.19_sd_empty_2048.fpsimage.fls Image Type : MASS Memory SD Card Size : Use 2 GB Cards Only Always use the CORRECT SD Card Size!!! Data Size : 228484 Bytes Sending Certificate Block MASS MEMORY Certificate Block Sent Successfully... Processing Section 01 MASS MEMORY Erase Block: 0x30000000~0xAFFFFFFE Start Erasing... Erasing Please Wait... Block Erase Done... Preparing Data Blocks... Data Size: 323584 bytes Data Checksum: 3E6F Uploading Data Blocks to phone... Block Write Successful... MASS MEMORY Data Blocks uploaded to phone... Data Verification Successful... Total Flashing Time (Erase + Flashing) : 00:07:02 (Booting time is NOT Included) Waiting for Phone to Start-Up..(Max 150 seconds) Scanning USB Ports... ================================================ Basic Phone Information ================================================ MCU Version: V 03.19 25-12-12 RM-862 (c) Nokia IMEI Plain : 355499052569980 IMEI Spare : A355499052569980 IMEI SV : 33554990525699806F IMEI (2nd) : 355499052569998 IMEI Spare : A355499052569990 IMEI SV : 33554990525699906F Phone Model: J 205 Category : Phone Phone Type : RM-862 ================================================ Extended Phone Information ================================================ Product Serial Number: ECF7753AH Product Code : 059Q093 Module Code : 0205222 Basic Production Code: 059N267 Long Production SN : 0 PPM SW Version : V 03.19 25-12-12 RM-862 (c) Nokia V BT MCM Version : 19b5-22012 MCU SW Version : V 03.19 25-12-12 RM-862 (c) Nokia HW Version : 1000 RFIC Version : 68 LCD Version : TPO Content Pack Version : Content: v_059Q094 V 03.19 25-12-12 RM-862 (c) Nokia Bluetooth ID : 54:79:75:CB:9A:1B CS Type : GSM900, GSM1800 ********** SIMLOCK INFO ********** CONFIG_DATA : 0010100000000000 PROFILE_BITS : 800000000004000B ASIC : 11 PROVIDER : Default Test Operator LOCK COUNTERS: KEYPRESS 0/3, FBUS 0/10 Block [1] 1:Open 2:Open 3:Open 4:Open 5:Open Block [2] 1:Open 2:Open 3:Open 4:Open 5:Open Block [3] 1:Open 2:Open 3:Open 4:Open 5:Open Block [4] 1:Open 2:Open 3:Open 4:Open 5:Open Block [5] 1:Open 2:Open 3:Open 4:Open 5:Open Block [6] 1:Open 2:Open 3:Open 4:Open 5:Open Block [7] 1:Open 2:Open 3:Open 4:Open 5:Open SIMLOCK_TYPE : PA_SIMLOC30 (20-digit NCK) SIMLOCK_TEST : PASSED SECURITY_TEST : PASSED SECURITY_CODE : 12345 PHONE_MODE : TEST ================================================ Dynamic Camera Configuration ================================================ DCC ID : NI00CS00000401022F03 DCC Ver: 010009 Status : OK ====================================================== Selected VPL File: RM862_059Q094_03.19_023.vpl ====================================================== Variant Details : RM-862 APAC_V_CYAND_CHI_KH Software Version : 03.19 Product Type : RM-862 Product Code : 059Q094 Variant Version : 023 FACTORY SET TO : Full Factory Set OK FACTORY SET TO : User Data OK FACTORY SET TO : Leave Factory OK FACTORY SET TO : Service Center OK FACTORY SET TO : Software Upgrade OK FACTORY SET TO : Production Tune OK
