    Technical hungphongmobile™'s Avatar
    Mar 2007
    www.hungphongmobile.vn
    Mặc định VIDEO UNLOCK Cid 53 Free k800
    www.hungphongmobile.com
    www.giaimadienthoai.com
    <marquee ><font size=3 color=cyan><b> HungPhongMobile™ Service Center</b></font></marquee>
    <a href="ymsgr:sendIM?phongnhabr" target="_blank" rel="nofollow"><img src="http://opi.yahoo.com/online?u=phongnhabr&m=g&t=2&l=us border=0" border="0" /></a>
    <a href="ymsgr:sendIM?hp_unlockonline" target="_blank" rel="nofollow"><img src="http://opi.yahoo.com/online?u=hp_unlockonline&m=g&t=2&l=us border=0" border="0" /></a>
  2. ( hungphongmobile™ ) đã được 7 thành viên cám ơn vì bài viết hữu ích!
    chienmobile (07-06-2008), dhk (07-07-2008), haithong (11-11-2008), Magicalboy (05-12-2008), tahontrung (18-11-2008), tanden (16-03-2009), tinh_thien2008 (07-01-2009)
    Thành viên chính thức GSM Hai Phong's Avatar
    Nov 2005
    Anh kiểm tra lại dùm không hiểu theo cái video đó thì đi unlock cái K800 nào
    Mar 2007
    Mặc định unlock thành công con k800 cid53 log
    .914033/UNI
    CARD SERIAL: 00000000
    Loaded 51 flash descriptors
    SIGNED MODE (USING SERVER).
    ChipID:9900,EMP protocol:0301
    PHONE IS RED RETAIL PRODUCT
    FLASH CID detected:53
    Speed:921600
    Flash ID check:2019
    Flash props sent ok
    OTP LOCKED:1 CID:51 PAF:1 IMEI:35975701650164 CERT:RED
    FLASH CID:53 COLOR:RED
    Model:K800i
    Brand:Vodafone
    MAPP CXC article: R8BF003 prgCXC1250211_VODAFONE_WI
    MAPP CXC version: R8BF003
    Language Package:VFE_LIVE_2
    CDA article: CDA102511/130
    CDA version: R4A
    Default article: cxc1250490
    Default version: R8BF003
    PROVIDER: 234-15
    Network LOCKED
    RESTORATION FILE NOT PRESENT
    "R8BF003_CXC1250211_VODAFONE_WI"
    YOU MUST PERFORM FULL FLASHING
    WHEN "ALTERNATIVE SECURITY BYPASS" ENABLED
    BYPASS PACKAGE PRESENT FOR DETECTED FIRMWARE
    SECURITY UNITS BACKUP CREATED.
    Elapsed: 49 secs.
    Speed:921600
    Flash ID check:2019
    Flash props sent ok
    Model:K800i
    Brand:Vodafone
    CDA version: R4A
    PROVIDER: 234-15
    Network LOCKED
    SEARCH:Z:\Flashes\Setool\SonyEricsson\K800i\CID53\ R8BF003\R8BF003_1250211_VODAFONE_WI.ssw
    "R8BF003_CXC1250211_VODAFONE_WI" CREATED
    Elapsed: 69 secs.
    Speed:921600
    Flash ID check:2019
    Flash props sent ok
    Model:K800i
    Brand:Vodafone
    CDA version: R4A
    PROVIDER: 234-15
    Network LOCKED
    RESTORATION FILE PRESENT FOR DETECTED FIRMWARE
    Elapsed: 14 secs.
    ALTERNATIVE SECURITY BYPASS ENABLED.
    Speed:921600
    PATCH:071120 1355 HANCXC9876543210_DB2020_MEM_PATCHER_R2A012 0
    LDR:080108 1810 ESGCXC1329129_DB2020_FLASHLOADER_R2A015
    Flash ID check:2019
    Flash props sent ok
    LDR:070904 1245 AN2CXC1250562_DB2020_CSLOADER_R3A013
    loader startup: executed
    loader GDFS startup: executed
    loader filesystem startup: executed
    loader unlock: executed
    DISCONNECT PHONE NOW
    INSERT SIM CARD, FULLY TURN PHONE ON AND ATTACH AGAIN
    BE SURE THAT YOU SET PHONE IN "PHONE MODE"
    IF ASKED, INSTALL PHONE DRIVERS
    SEARCHING FOR PHONE, "STOP" TO ABORT
    PHONE FOUND AT COM6
    PHONE READY TO PROCEED
    EXECUTOR STARTED
    REMOVE CABLE FROM PHONE
    REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
    THEN PRESS "READY"
    Speed:921600
    Trying to launch embedded bootloader...
    INT LDRB2020_PRELOADER_FOR_SETOOL2
    Flash ID check:2019
    Flash props sent ok
    FOUND: R8BF003_CXC1250211_VODAFONE_WI
    Restore from:R8BF003_CXC1250211_VODAFONE_WI
    full sig complete.
    USERCODE RESET TO "0000"
    Searching...
    Firmware SIMLOCK check determined.
    Unlock DONE
    Elapsed: 228 secs.
    Vi phạm nội quy vietbinhbet's Avatar
    Jan 2007
    sao em không tải được anh ơi
    Thành viên mới NNBau's Avatar
    Aug 2008
    Link bị die rồi bác oi!Hix
    V.I.P htv1810's Avatar
    Aug 2006
    đây link mới đây rùi -->http://www.4shared.com/get/53076429/...53_UNLOCK.html
    p/s:link khi nào rồi mà không die.
    Nhận unlock,sữa chữa DTDĐ và đào tạo học viên.
    AzSoft Mobile Service
    6F' Nguyễn Thị Tần P2.Q8.TPHCM
    Phone08.6124225
    Mobile-Phone0909.510312
  8. ( htv1810 ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    smvt (14-11-2008), trankimthuy (31-07-2009)
  9. #7
    Mar 2007
    Fix lại link rồi
  1. Free unlock IMEI -- LoginPlus [FREE For TEST] Online Unlock
    By hungthinhmobi in forum Các thiết bị khác
    Bài viết cuối: 17-02-2014, 15:55
  2. Trả lời: 0
    Bài viết cuối: 08-07-2010, 22:25
  3. Video hướng dẫn Unlock free A2!!!!
    By phongboyvn in forum SETOOL
    Bài viết cuối: 29-11-2008, 21:01
  4. K800 user unlock
    By duytungstar1 in forum SETOOL
    Bài viết cuối: 09-11-2008, 17:22
  5. K800 CustomizeFS tool for free!!!
    By taihv™ in forum Phần mềm Sony-Ericsson
    Bài viết cuối: 02-03-2007, 17:02
