    Thành viên chính thức phutuyen's Avatar
    Mar 2007
    Mặc định 6230 làm chân cpu lại chạy no báo lỗi
    em tháo cpu ra đóng lại rồi chạy chuơng trình nó báo như vậy nè xin giúp dùm máy lúc đầu có nguồn mà bị chạm bên cpu nên làm chân lại
    FILES SET FOR FLASHING:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\products\rh-12\rh12_28_11005.500
    PPM Flash file: C:\Program Files\Nokia\Phoenix\products\rh-12\rh12_28_11005.50t
    CNT Flash file: C:\Program Files\Nokia\Phoenix\products\rh-12\rh12_28_11005.50.ucp_w
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Languages in ppm: English,Vietnamese,Tagalog,Chinese S,Chinese T
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\products\rh-12\rh12_28_11005.500
    Booting phone...
    MCU ID: 0x1052
    BOOT file: C:\Program Files\ODEON\JAF\Flash\te_2nd.fia
    Boot size is 0x2398
    Boot is ready...
    FLASH ID0: 22F800EC <=> SAMSUNG (SEC) -> Type not in database Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: 003900EC <=> SAMSUNG (SEC) -> Type not in database Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 9
    FLASH ID2: 00010000 <=> Flash -> not used Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 0
    FLASH ID3: 00010000 <=> Flash -> not used Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0x22F800EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\te_amd.fia
    Loader size is 0x84A0; Loader chk: 38
    Loader is ready...
    P-key nokia module version 01.01
    MSID: 848F9D56C7599F76607F59BFFC
    MSID decoded: B03FBAE9005D6647A9000000
    FAID: 8DE3BD50EA67C79EAFE3FFAB
    Operation took 0 minutes 21 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 007FFFFF...
    Erasing area: 00800000 - 0093FFFF...
    Erasing area: 00B60000 - 00FEFFFF...
    Operation took 2 minutes 38 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 0 minutes 51 seconds...
    Restarting MCU...
    NAND Format FAILED!!!
    CNT: C:\Program Files\Nokia\Phoenix\products\rh-12\rh12_28_11005.50.ucp_w
    Booting phone...
    MCU ID: 0x1052
    Boot size is 0x2398
    Boot is ready...
    First 16 bytes: 00 00 00 00 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5
    Loader is ready...
    MSID: 84A8CCFDBA49B71F771E0CA996
    MSID decoded: 3E4EBAE9005D6647A9000000
    FAID: F4AE4B4285B098C46E417D1D
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Erasing area: 00940000 - 00B3FFFF...
    Operation took 0 minutes 25 seconds...
    Writing...
    Restarting MCU...
    Extracting Content Pack...
    Error setting local mode...
    CP Extract Failed!
    PPM: C:\Program Files\Nokia\Phoenix\products\rh-12\rh12_28_11005.50t
    Booting phone...
    MCU ID: 0x1052
    Boot size is 0x2398
    Boot is ready...
    Loader is ready...
    MSID: 84DC53758A5E6947668D072F67
    MSID decoded: 3E4EBAE9005D6647AA000000
    FAID: 23E3A34B9B9DE47A3474D2BF
    Erasing PPM...
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 7 minutes 10 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    0919949456 @ 0949070919
    V.I.P anhdaomobile's Avatar
    làm chan U chuẩn chưa bạn ah`
    Thành viên chính thức Cuong_NT's Avatar
    bạn chạy ver khác chưa?
    Thành viên tích cực loibb5's Avatar
    1 là ver thấp 2 là lổi TIKU 3 flash meil thay TIKU đi
    kiểm tra lai version nha ...phong độ là nhất thời ...đẳng cấp là mãi mãi
    Aug 2008
    thay cpu đi bạn cpu này nó die rồi
    yahoo : hoangtu_bongdem_1986
    phone : 0935 10 1986
    Thành viên mới jack's Avatar
    bạn lam chân chuẩu đóng vào có ấp phê là được
    Thành viên mới TUNG_LC's Avatar
    MCU ID: 0x1052
    V.I.P Mr_Diep's Avatar
    Vấp ngã chỗ nào thì đứng lên chổ đấy, nếu cảm thấy đóng lại cpu đã chuẩn rồi mà vẩn không được thì thay là ok.
  1. 6230 chạy chương trình báo lỗi
    By Chaunv.Mobile in forum DCT4 - WD2
    Bài viết cuối: 12-09-2009, 09:32
  2. Trả lời: 10
    Bài viết cuối: 11-09-2009, 20:31
  3. 6230 dấu chấm hỏi
    By acer in forum BB5
    Bài viết cuối: 05-06-2009, 20:20
  4. 6230 chập chờn
    By boyhot00 in forum DCT4 - WD2
    Bài viết cuối: 30-07-2007, 23:33
  5. Cách Sửa Và Chế Ic Mmc 6230
    By TVGSM in forum DCT4 - WD2
    Bài viết cuối: 04-06-2007, 23:57
