    Thành viên chính thức dat0979467467's Avatar
    Mặc định 1200 chuyện lạ nè anh em
    MCU ID: 0x2292
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    Backup IMEI zone...
    Setting local mode...
    Reading IMEI...
    Reading IMEI data...
    IMEI data corrupt...
    Getting MCUID...
    MCU ID: 0x2292
    Reading flash chip detailes...
    MCU ID: 0x2292
    Boot is ready...
    Algo is ready...
    Loader is ready...
    Erasing area: 01000000 - 01FFFFFF...
    Done!
    MCU: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.230
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 8461AB9069570A817C1888DA99
    MSID decoded: 3E4EBAE900467FFBA8000000
    FAID: 4CAAD00D0B87BE91318260D2
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 10 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.23mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 848268AA7D27229DD2C242F129
    MSID decoded: 3E4EBAE900467FFBA9000000
    FAID: 1124AC6DB7BA27DCA00DFDA3
    Operation took 0 minutes 9 seconds...
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 22 seconds...
    Writing...
    Restarting MCU...
    CNT: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.23mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 36 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-99, Software version: 5.23
    IMEI: 353106024328245
    Product Code:
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Done!
    Powering the phone...
    Unlocking...
    ASIC: b
    SW version: 5.23
    Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.230
    Decrypting flash...
    Encrypting....
    CHK Patch found - Unlock Patch found and are not in same block
    Patch status: 02
    MCU ID: 0x2292
    Algo is ready...
    Erasing area: 011E0000 - 011FFFFF...
    Unlocking...
    Checking locks...
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Done!
    DCT4 unlock counter: 165
    chạy ọ hết mà ko len nguồn bác nao` đã gặp chưa
    http://thaibinhgsm.com/forum/index.php
    yahoo :thanhdat_mobile0979757298 mobile:0979467467
    V.I.P TAMTRUONGTELECOM's Avatar
    Jul 2006
    cái log lạ wá sau lên nguồn đây!
    NHẪN MỘT CHÚC SONG YÊN GIÓ LẶNG
    LÙI MỘT BƯỚC NHÌN BIỂN RỘNG TRỜI CAO
    Thành viên kỳ cựu chanhtin_2104's Avatar
    Đến Từ TP HCM
    bạn bỏ bớt file này đem hwk chạy 2 file thôi...file mcu ppm
    lạ chỗ nào bạn ơi
    hic chạy 2 fine làm sao dc hả bạn
    V.I.P tuanmb's Avatar
    Feb 2008
    bạn xem lại đường bsi nhe bạn, chạy báo vậy là ok rồi, con hợp nào nữa không đem qua hợp khác chỵ thử coi
    hehe câu 1 sợi dây từ con c2941 vào bsi là ok.anh em nào gặp thì làm nhé.nhớ thansk nhé
    V.I.P htv1810's Avatar
    Aug 2006
    Kham khảo hình này nhá
    Hình đính kèm
    Nhận unlock,sữa chữa DTDĐ và đào tạo học viên.
    AzSoft Mobile Service
    6F' Nguyễn Thị Tần P2.Q8.TPHCM
    Phone08.6124225
    Mobile-Phone0909.510312
  9. ( htv1810 ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    dat0979467467 (28-10-2008)
  10. #9
    Thành viên tích cực duong_doi's Avatar
    câu bsi=> thay vco ok
    HOANG_TIN international
    Hãy khò theo cách của bạn!
  1. chuyển 1208 về 1200
    By xqmobile in forum DCT4 - WD2
    Bài viết cuối: 06-12-2012, 18:29
  2. chuyển 1208 thành 1200
    By vietcut in forum DCT4 - WD2
    Trả lời: 14
    Bài viết cuối: 12-06-2012, 20:00
  3. câu chuyện N70 của mình nhiều chuyện lắm ae
    By tuankhangmobile2009 in forum BB5
    Trả lời: 14
    Bài viết cuối: 21-08-2011, 21:25
  4. 1200 nói chuyện ko ai nghe
    By baoth06 in forum DCT4 - WD2
    Bài viết cuối: 20-06-2009, 12:38
  5. 1200 cầ chuyển tiếng việt
    By ANHTEO in forum DCT4 - WD2
    Bài viết cuối: 19-05-2009, 14:44
