Kết quả 1 tới 10 của 18
    V.I.P Start307's Avatar
    Oct 2005
    Mặc định New JAF ver 1.97 beta1
    Hi
    Finaly new jaf version is ready, 1.97 beta1.
    - added LCK option in bb5 flashing. This will autosave, if checked, the lock data from pm. If something goes wrong in flashing and phone will lock itself you can restore the lock data by writing pm back
    - added 128k page flash chip support on usb flashing (6280, 6233 etc). Remember to use version 3.81 or higher to flash 6280 with AMD chips.
    - improved usb communication. This will affect all bb5 and ape usb flashing.
    - Improved File Sys detection. Now all should be ok. If still have problems please post.
    - corrected 7710 ape usb flashing. It was due too short timeout on usb.
    - added OMAP mcu check when flash phones with bad ape mcu. Flash will not start, saving the phone from erasing then error on write.
    - added more error messages to improve hw error detection more easy
    - and the SMALL SURPRISE: JAF NOW SUPPORTS UFS INTERFACE AS FLASHING INTERFACE. DCT4 and BB5 (5 or 7 pins cable) are fully supported for now. Soon more will follow. This is a beta stage. We are waiting for your feedback.
    http://files.odeon.cn/JAF_Main_Softw...eta1public.rar
    Regards
    ODEON TEAM
    Thành viên tích cực sromobile's Avatar
    May 2006
    Có dùng pkey ko anh?
    Thành viên chính thức Zulea's Avatar
    Mar 2006
    Mặc định Không dùng P-key chẳng lẽ dùng Setool???
    Trích Được post bởi sromobile
    Test thử chơi với 7610
    Getting MCU ID
    MCU ID: 0x1081
    FLASH ID0: EC00FEDD -> ST Addr0: 0x00000000 - 0x00FFFFFF, SectorSize0: 10
    FLASH ID1: EC00FEEE -> ST Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 10
    FLASH ID2: EC005022 -> ST Addr2: 0x04000000 - 0x04FFFFFF, SectorSize2: 10
    FLASH ID3: 00000100 -> NOT USED Addr3: 0x06000000 - 0x06FFFFFF, SectorSize3: 0
    First 16 bytes: C6 00 00 EA 75 01 00 EA 78 01 00 EA 7B 01 00 EA
    Checking RAM for ALGO...
    Algo is ready...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.01
    Languages in ppm: English, German, French (France)
    MCU: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51_52_67_68PE605220.C1
    Booting phone...
    MCU ID: 0x1081
    BOOT file: C:\Program Files\ODEON\JAF\Flash\w3_2nd.fia
    Loader version: 04.34.00 -> Revision: 0007
    Boot size is 0x1078
    Boot is ready...
    Flash ID is 0xDDFE00EC
    Flash loader is C:\Program Files\ODEON\JAF\Flash\w3_amd.fia
    Loader size is 0x7D48; Loader chk: 5b
    Loader is ready...
    P-key nokia module version 01.00
    MSID: 841C040F231C6CE82CECDC284C
    MSID decoded: 3E4EBAF7001CD842A9000000
    FAID: 44FB8350070F7C8E873637A9
    Operation took 0 minutes 26 seconds...
    Erasing...
    Found 4 interval(s) to erase
    Erasing area: 00000000 - 0000FFFF...
    Erasing area: 00010000 - 00FFFFFF...
    Erasing area: 02000000 - 0287FFFF...
    Erasing area: 02FC0000 - 02FEFFFF...
    Operation took 2 minutes 45 seconds...
    Writing...
    Perm. Data Restore OK
    Operation took 5 minutes 6 seconds...
    Restarting MCU...
    PPM: C:\Program Files\Nokia\Phoenix\Products\RH-51\RH51PE605220.01
    Booting phone...
    MCU ID: 0x1081
    Boot size is 0x1078
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Erasing area: 02A00000 - 02C9FFFF...
    Operation took 0 minutes 18 seconds...
    Writing...
    Operation took 0 minutes 33 seconds...
    Restarting MCU...
    Flashing Done!
    Operation took 9 minutes 48 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-51, Software version: 6.0522.0
    IMEI: 357070009616204
    Product Code: 0516453
    Resetting PPC...
    Powering the phone...
    Unlocking...
    ASIC: 5
    Done!
    DCT4 unlock counter: 1
    Done!
    Cảm giác khi chạy speed hơi chậm
    Download here Best song
    If u spam i will banned you
    May 2006
    Con nhà nghèo mà anh, đâu có tiền up pkey đâu..
    Oct 2005
    @ Zulea: connect với Sara flash cũng đã lắm à
    Mar 2006
    vấn đề không phải là giàu nghèo mà là vấn đề không hiểu rõ vấn đề
    Mar 2006
    Trích Được post bởi Start307
    Cảm giác không nhanh anh ơi!vẫn là beta,không có DTC3 và DTCL
    Chắc chắn sắp tới sẽ có P-key active full cho UFS giá tốt cho những ai chưa mua JAF
    Thành viên mới UST Pro II's Avatar
    Jan 2006
    That's just your feeling . I tested with 8210. The same speed
    Mar 2006
    Trích Được post bởi UST Pro II
    Không có DTC3 lấy gì test 8210 Pố????
    UST pro 2 mà cũng quan tâm JAF
    Jan 2006
    New JAF ver 1.97 beta1??? There is no for DCT3???
    Woo.o..I just buy it for flashing 8210, 8250. That's all. Thanks, i will check later . Do you buy my JAF??? I will discount
  1. Apple phát hành iOS 7.1 beta1 cho Developer
    By toilatoi142001 in forum TIN TỨC 24 GIỜ
    Bài viết cuối: 19-11-2013, 16:41
  2. Links download IOS 7 Beta1
    By 5ncnow.com in forum TỔNG HỢP FIRMWARE - JAILBREAK - UNLOCK
    Bài viết cuối: 18-06-2013, 21:51
  3. DBSS v3.27 beta1 - W395 TA problem fixed.
    By TuấnPhát_GSM in forum Dream Box
    Bài viết cuối: 29-06-2010, 21:03
  4. J.A.F. 1.98.65 beta1 released
    By hungphongmobile™ in forum J.A.F
    Bài viết cuối: 12-02-2010, 00:06
