    văn yên_yên bái
    Angry 2626 rơi nước mất nguồn xin giúp đỡ
    anh em sem giúp em cái log này với máy bị rơi nước mất nguồn em bỏ vô jaf check nó báo thế này
    MCU ID: 0x3040
    FLASH ID0: 00010000 <=> Flash -> not used Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 0
    First 16 bytes: 00 00 00 01 00 02 00 03 00 04 00 05 00 06 00 07
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw
    Phone Type:
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.ppm_v
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: C:\Program Files\Nokia\Phoenix\Products\RM-291\rm291__06.80.mcusw
    Booting phone...
    Phone didn't answer with TX line high after UEM reset!
    Causes:
    1. BSI line is not connected properly in connector -> Check cable, also for 3.3k resistor in serial with bsi line.
    2.UEM damaged -> replace UEM.
    MCU ID: 0xCCCC
    This MCU ID is not supported in chosen flash file...
    Error booting phone...
    Failed! Aborting!
    Booting phone...
    MCU ID: 0x3040
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x01000000
    Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia
    Loader size is 0x7528; Loader chk: b2
    Loader is ready...
    MSID: 84F3E16133471216DECFEA2736
    MSID decoded: 4F16BAE900C8BC76A8000000
    FAID: 27C096FE29BD83785DA13204
    Erasing...
    Found 3 interval(s) to erase
    Erasing area: 01020000 - 018DFFFF...
    Erasing area: 01EE0000 - 01FDFFFF...
    Writing...
    Error cmd: 14!
    Addr: 01000000
    anh em xem giup em xem nó bị gì . cảm ơn anh em . thanks all
    Đất Hà Thành!
    trước hết vệ sinh sách sẽ,sấy kỹ!làm lại upp!check cable,chạy ver cao hơn + chon 3 file!ok!
  3. ( silly ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    haiquynhmobile (14-01-2009)
    Thành viên chính thức hao_vp's Avatar
    Apr 2008
    e cũng có 1 con 2626 rớt nước...rỉ hết sạch lun. vẫn sống nhưng e luộc lại mein xong thi mất nguồn và chạm e đóng lại ic nguồn. nhưng k0 đc. e kiểm tra thấy chạm công suất nân nhấc bỏ lun. thì hết chạm. nhưng vẫn chưa lên. e mới ra nghề nên còn kém. Các Bác júp e với...Thanks Các Bác nhìu
    chưa vệ sinh kỷ mà chơi mềm rùi
    CHIÊU ANH ĐT:0933878095
    V.I.P thinhtam's Avatar
    xem lại con flash bạn.
    Thành viên tích cực tuongmobil@_1987's Avatar
    NAM ĐỊNH
    ko cần vệ sinh chơi vậy mới sốc!!!!!!!!!! vệ sinh kỹ lại rùi chạy lại quẳng cái log nên cho anh em coi đi!
    không tiền đố mi làm nên...........!!!!!!!!!!!
    Thành viên chính thức thanhhungcb's Avatar
    Mặc định Q MoBiLe F55 Cần Cấp Cứu
    Mình có kon Qmobile F55 cứ gọi đến là hiện tai nghe mọi người giúp mình với
  9. #8
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    Trích Được post bởi thanhhungcb Xem bài viết
    sao anh này lập topic rồi mà còn thích chen vào bài chủa người khác vậy nè.
  1. cần giúp 2626 ko lên được nguồn
    By kechien in forum DCT4 - WD2
    Bài viết cuối: 06-12-2010, 12:30
  2. nhờ các bác giúp 2626 đê qua đêm chap nguồn
    By ngonluanho03 in forum DCT4 - WD2
    Bài viết cuối: 05-09-2010, 20:23
  3. 2626 mất nguồn cần anh em giúp
    By thaomobilecntv in forum DCT4 - WD2
    Bài viết cuối: 21-08-2010, 14:28
  4. 2626 chập nguồn xin giúp
    By thanhmobille in forum DCT4 - WD2
    Bài viết cuối: 20-06-2010, 15:22
  5. nguồn 2626 cần anh em giúp đỡ
    By SyChien_Mobile in forum DCT4 - WD2
    Bài viết cuối: 03-06-2010, 12:04
