Trang 1 của 19 1 2 3 4 5 6 7 8 9 10 11 ... CuốiCuối
Kết quả 1 tới 10 của 186
    Product Manager Hoang Thong Mobile's Avatar
    Dec 2006
    Mặc định Update mx-key anh em vui long post ở đây nhé
    April 19 2007
    mobileEx 1.8 released
    Whats NEW:
    - Added, BB5 Flashing support.
    With Selectable RAP and APE flash only for best flashing result.
    - Added, BB5 Read ASK(GT format) and Write RPL(NMP format)
    - Improved, Communication logic to fixes CPU and Mem usage on some PC.
    - Improved, Base band Self test to fix BB5 issues.
    - Added, DCT4+ Asic 2 and Asic 11 direct unlock.
    - Added, DCT4 'new' Asic 2 (1110,1600 new version) unlock.
    - Added, LCD contrast reset to fix 1110i LCD issues after unlock.
    - Improved, DCT4 Imei patch to fix ESN patch issues.
    - Fixed, CS patch only for 7250i or 6610i.
    - Fixed, BB5 SIMLock backup & restore.
    - Improved, Menu Editor (propuct profile) parser to support new *.ppu.
    - Improved, UFSx boot to fix NBOX 'cant boot' issues.
    - Added, ASIC_ID check when flashing so you wont kill the phone if you select incorrect file.
    - Many minor bugs fixed.
    Report Post Thanks
    CTY TNHH ĐIỆN THOẠI DI ĐỘNG HOÀNG THÔNG
    ĐT/FAX : 083.9572152 - 08.38575707 - 0903.303.717
    Skype : saigonmobile
    YM : saigonmobile_vn
    MSN : saigonmobile@hotmail.com
  2. ( Hoang Thong Mobile ) đã được 5 thành viên cám ơn vì bài viết hữu ích!
    anh tú_gsm (11-02-2012), hoangdaika (05-12-2012), hoangkimma (21-02-2010), Phúc_Cần Thơ (18-09-2012), thuanloitelecom (04-06-2009)
    Dec 2006
    April 19 2007
    mobileEx v1.9 ready
    Whats NEW:
    - Added, BB5 Standalone SW downgrade procedure
    credits to Dejan K.
    - Improved, DCT4/BB5 phone change mode.
  4. ( Hoang Thong Mobile ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
    anh tú_gsm (11-02-2012), hoangdaika (05-12-2012), thuanloitelecom (04-06-2009)
  5. #3
    Dec 2006
    May 05 2007
    mobileEx 2.0 is out
    Whats NEW:
    - Added, Self update button, software update made simple.
    - Added, DCT4 online logger/IMEI fix
    - Added, Direct USB connection for FBUS protocol.
    - Added, Integrated and online(under construction) help file
    - Re-enabled, DCT4 ADSP flashing function
    - Added, DCT4 ADL/APE flashing function
    - Added, DCT4 CNT128 auto conversion
    - Improved FBUS and MBUS connection.
    - Improved DCT3 flashing function.
    - Improved Multiflashing, flashing continuously is now possible.
    - Improved Format and Self test function.
    - Fixed, DCT4 relock bugs.
    - Fixed, BB5 booting problems on some phones.
    - Added, BB5 Certificate (NPC + SIMLOCK) backup
    - Added, BB5 custom erase.
    WARNING: Erasing flash could be dangerous for BB5 phones, use with good reason only !!!
    - Added, logs while reading PMM
    - Added, LED status to determine box state
    - Added, Progress on file info while flashing DCT4 phones
    - also so many changes that would be fill out this page if written )
  6. ( Hoang Thong Mobile ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
  7. #4
    Dec 2006
    May 26 2007
    mobileEx 2.1
    Whats NEW:
    - Added, BB5 USB Flashing.
    - Added, Direct BB5 SP unlocker using UFS/JAF/DKU2 USB/COM port
    - Improved, BB5 Certificate backup(read) and RPL write
    - Added, BB5 PMM (superdongle) auth (currently only working IF SX4 connected to the system, server solution under construction)
    - Fixed, DCT4 Watchdog test
    - Added, SP Unlock for some CDMA phone to fix 'Phone restricted'
    - Fixed, ESN patch not work when invalid ESN entered
    - Added, Patch software option for IMEI/ESN changer.
    - Some other bugs fixed.
  8. ( Hoang Thong Mobile ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
  9. #5
    Dec 2006
    June 30 2007
    mobileEx v2.2
    Whats NEW:
    - Added, Support Server for BB5 PMM(SX4) Auth
    - Fixed, BB5 RAP3Gv3 boot
    - Fixed, BB5 USB flashing for BB5 RAP3Gv3.
    - Fixed, DCT4 ADL flashing bugs
    - Fixed, VCOM changing mode result in 'busy'
    - Improved, BB5 RPL write
    PRODUTCODE,HWID and PSN now written. fixed SIMlock upload for BB5 RAP3Gv3.
    - Improved, BB5 SIMlock INFO(BB5 RAP3Gv3).
    - Improved, 'GetAddr' for BB5 custom erase
    - Improved, Phone Detection after restart.
    - Changed, COM port detection in device list, Only active ports are displayed
    - Improved, Self Update. Will download Only if version on server is newer.
    - Fixed, DCT4 RPL logger
    - Changed, internal code for WinXP X64 and Vista compatibilities
    Report Post Thanks
  10. ( Hoang Thong Mobile ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
  11. #6
    Dec 2006
    July 11 2007
    mobileEx v2.2.1
    Whats NEW:
    - Added, DCT4 IMEI logger client to support mx server
    - Improved, BB5 USB flashing
    - Improved, "PhoneSafe" function for BB5
    - Added, read BB5 RAP FLASH IMEI when BUS check
    - and some minor bug fix.
  12. ( Hoang Thong Mobile ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
  13. #7
    Dec 2006
    August 20 2007
    mobileEx v2.2.2 build 778 fresh installer released
    Whats NEW:
    - Fixed, all RAP3Gv3 BB5 boot (hopefully )
    - Improved, BB5 USB flashing ('new' APE phones)
    - Improved, BB5 certificate tool
    backup 'ALL section' will read NPC,VARIANT,CCC,HWC RAP and APE.
    write RPL function now able to write ALL section from backup or NMP.
    - Improved, SL INFO read
    - Added, HW & Part info during 'Phone Info'
    - Added, Master Code read during 'BUS check'
    The master code readed from phone could be used to unlock security code for attached phone even counter was already blocked, including 'new' TIKU CDMA phones
    - Added, Mass Memory Storage Device flash handle (6265,6230i, etc)
    - Changed, Format File System routine(tab maintenance->tabset FS).
    - Fixed, DCT4 ADSP flashing(NGAGE)
    - Fixed, DCT4 APE flashing
    - Fixed, some minor bugs and added new bugs(maybe)
  14. ( Hoang Thong Mobile ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
  15. #8
    Dec 2006
    August 31 2007
    mobileEx v2.3.0
    whats NEW:
    - Added, DATA1 backup confirmation before FLASH erase
    - Improved, BB5 certificate backup (certificate size displayed, will exit if certificate is corrupted !)
    - Improved, PMM auth routines (will exit if IMEI or SIMLOCK is bad!)
    - Improved, Master code read (remember: we're the first and the only one solution at the moment)
    - Improved, SL_INFO read (sometimes readed corrupted data at long size on CDMA phones)
    - Improved, EEP address allocation on 'GetAddr'
    - Improved, 'Get details' on selftest
    - Fixed, BT MCM auth bug
    - Fixed, PMM read bug (readed 0 bytes value)
    - Fixed, server password missing char
  16. ( Hoang Thong Mobile ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
  17. #9
    Dec 2006
    December 07 2007
    mobileEx v3.0 public-beta
    Whats NEW:
    - Almost all elements are new, the most important part of this βeta was that it was finally recoded from scratch.
    Not implemented yet:
    - JAF interface support
    - DCT3/L function
    - DCT4PLUS unlock patch
    - BB5 generic unlock
    - and some other.
    This brand new exe will supports MXKEY and MXKEY LiTE
    What is MXKEY LiTE?
    its new dongle for mobileEx, SmartCard based.
    What about future support about MXKEY?
    We released MXKEY LiTE for costumer satisfaction.
    MXKEY LiTE will be cheaper, and thats why we call it "Lite".
    MXKEY will be fully supported as MXKEY LiTE, note that there was no differences between MXKEY and the LiTE version.
    Unimplemented features will be added as soon as possible.
    while that, you could also request feature
  18. ( Hoang Thong Mobile ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
  19. #10
    Dec 2006
    December 11 2007
    v3.0 Beta3, Public-Release.
    Whats NEW:
    - re-constructed, CDMA Tuning.
    - re-constructed, Quick repair page (BT repair, LCD reset, etc).
    - improved, Online Updater.
    - added, CDMA NFP folder to model selection.
    - and other minor.
  20. ( Hoang Thong Mobile ) đã được 3 thành viên cám ơn vì bài viết hữu ích!
Hiện có 4 người đang xem bài này . Bao gồm : 0 thành viên và 4 khách
  1. DC unlocker Update anh em vui long post ở đây
    By hungphongmobile™ in forum DC-unlocker
    Trả lời: 87
    Bài viết cuối: 12-07-2022, 22:16
  2. zZKey Update New Update Center 0.0.307+ New Feature Hi, Long Time No See you Right??? Well... This time We Proudly prese
    Bài viết cuối: 07-07-2015, 11:14
  3. Update cyclonebox anh em vui long post ở đây nhé
    By HoangThong_hotrokythuat4 in forum Cyclonebox
    Trả lời: 75
    Bài viết cuối: 11-07-2013, 11:03
  4. NCK Dongle Android MTK Module Long Awaited Update Released
    By Lính Khang in forum THÔNG TIN CẬP NHẬT MỚI NHẤT CỦA THIẾT BỊ
    Bài viết cuối: 24-11-2012, 09:27
  5. Trả lời: 4
    Bài viết cuối: 14-08-2008, 11:25
