máy bị rơi nước em đã nhấc cả bộ nguồn ra đóng lại,chạy phần mềm thì báo lỗi thế này,tiếp theo phải làm gì đây,xin các bác chỉ giúp.
Getting MCU ID
MCU ID: 0x2292
First 16 bytes: A9 7E B2 1A 1B BE 0B E2 79 58 6B E4 DB EE 61 14
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh99_05.230
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh99_05.23el
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh990_nai5.23el
MCU: C:\Program Files\Nokia\Phoenix\Products\rh99_05.230
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84EA43427751FB8B4207AB9DB3
MSID decoded: 3E4EBAE9005FD3ABA8000000
FAID: 5FBD0CED4926517F605A378E
Operation took 0 minutes 9 seconds...
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 5 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 16 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\rh99_05.23el
Booting phone...
Phone didn't answer with TX line high after power on!
Causes:
1. Phone don't power on -> Check cable
2. TX pin from phone don't make contact -> Check cable
3. UPP damaged -> change UPP
MCU ID: 0xAAAA
This MCU ID is not supported in chosen flash file...
Error booting phone...
