    V.I.P nhatkha's Avatar
    Feb 2006
    Trung Tâm Kha Oanh .
    Arrow quick step, goest to MXKey expert
    * 1. Always select correct 'Generation' first before any operation.
    * 2. Always Use "Scan" if you're working with non dead phone, this will help mobileEx to use 'correct' spesific setting for any phones attached to box.
    * 3. "BUS Check" with setting safe flash ticked, will perform boot squence, display boot information (upp id, flash manufacture, flash address) and automatically safe phone's rpl.
    * 4. Make sure phone is in correct mode for any FBUS/NON flashing operation,
    - example: in Tuning & Testing page, phone should be in TEST MODE, else will be best if the phone is in LOCAL MODE.
    Do phone mode change manually if needed.
    * 5. When doing jobs on working phone, for any operation (add language, locks, etc), DCT4 and BB5, it is better to save its security data (RPL, certificate, pm, etc) first before you do anything else. Just in case...
    * 6. If you noticed, there was a differences of flashing speed between FlashID/Manufacturer the option 'Fast flash' should not be enabled for "INTEL" flash chip.
    * 7. If you need only to change the language, select file setting as NORMAL. then check 'Language Only"
    * 8. "Safe Flash" will save RPL backup from flash mode, and currently NOT supported for ASIC type 11 phone, so dont be checked. For this phone please do a PM backup since RPL backup from flash mode not yet supported. All other DCT4 asic is supported. Yes, even the dead one.
    * 9. Use "Restart" button every time you need to refresh the connection or restart the phone.
    * 10. Unlock "Security Code" on all DCT4,DCT4PLUS(Asic 2),WD2, TIKU without loosing any user data(phonebook, msg, etc) even counter already blocked? Yes, it is possible using mobileEx. Just do a "BUS Check" and you will see "Master Code" , use this code as the security code(this code readed from the phone and 100% will work both for CDMA or GSM phones).
    Customizing Your Suite
    Configure Nokia Tool
    Open Nokia Service Tool, and click on this corner
    * Enabled Imei changes -> if checked Imei/Esn changes will visible.
    Kindly check for your local law for this operation.
    * Auto backup ... -> Backup RPL on BUS check ( for DCT4)
    * Auto Create DP folder if not exist
    This is for directory creation specialy for .nfp extraction. Inside those directory, mcu, ppm, and cnt will be placed.
    * Default FBUS timeout
    This will set FBUS timeout (higher value = low speed but more accurate)
    * Highlight market item
    This will highlight the character you choosed. For example on picture, it highlighted on Indo, APAC, MD, and -X.
    You will see like this when you selecting files from product code
    Server : this is for your ask>rpl service. choose which one is fastest from your location.
    And this is the setting for your firmware directory
    Thành viên tích cực hoangthanhmobilee's Avatar
    mytho. tien giang
    MX KEY Bus check chậm như rùa vậy,đợi mỏi tay luôn, nhưng chạy thì ok nó chạy chậm hơn N-box va jaf mất nhiều thời gian quá.
    Thành viên mới CUBAHUE_NGAGE's Avatar
    nó dùng để sx4 thôi , còn chạy thì chết như rạ
    hãy cho nhau những gì mình đang có,lỡ mai này ko có để cho nhau
    Thành viên mới daklak's Avatar
    Jan 2006
    Trích Được post bởi hoangthanhmobilee Xem bài viết
    Bus check nó chậm là vì nó đọc ra đầy đủ hơn các box khác đó.nhìn rất dẽ hiểu
    mytho. tien giang
    Trích Được post bởi CUBAHUE_NGAGE Xem bài viết
    E mới lấy về 2 ngày chạy BB5 được 7 em sống nhăn răng đâu có chết a,mới mua đừng làm a,e nản chứ.Mới quá nghiên cứu từ từ thôi,chua dàm làm ẩu.
  1. Thảo luận MXKEY / MXBOX v3.4 revision 3.1 quick patch update
    By phúlộc_gsm in forum MX-KEY (by Alim Hape)
    Bài viết cuối: 09-05-2011, 18:56
  2. Jailbreak iPhone 4, 3GS on iOS 4.1 with Limera1n Step by step!!!
    By HoangThong_hotrokythuat7 in forum iPHONE 4 - 4S
    Bài viết cuối: 11-10-2010, 21:23
  3. Trả lời: 1
    Bài viết cuối: 19-05-2009, 12:53
  4. FREE Motorola UNLOCK by IMEI >> Step by Step here
    By TuongBinhThuan™ in forum MOTOROLA
    Bài viết cuối: 28-12-2007, 08:59
  5. Step by Step how to Unlock BB5 Phone Using BB5BOX
    By Hoang Thong Mobile in forum BB5Box
    Bài viết cuối: 21-09-2007, 01:12
