Hướng dẫn sử dụng S-Card, Smart-Clip + SmartMoto
S-Card, Smart-Clip + SmartMotoAs soon as S-Card dongle and Smart-Clip are connected to PC, SmartMoto is ready to operate.
Before starting SmartMoto, please set the compatibility for corresponding Operating System (right click on SM.exe file and choose Properties > Compatibility…)
To run SmartMoto under Win2000/XP and to update Smart-Clip, please launch SM, open bookmark "Smart –Clip" and tick the option "Disable OS parallel port polling (requires reboot)".
After that – PC requires to be restarted.
Flash file formats SmartMoto supports 5 flash file formats (4 of them are new to Smart-Clip): *.mfw, *.mbk, *.pcf, *.sbf and *.shx. No other formats will be compatible.
WARNING:
*.smf and *.smb files will be supported by SmartMoto version 1.23, Smart-Clip version 2.26 and lower versions only.
*.mfw - are meant to be used when the handset is connected to PC via Smart-Clip
Connect handset to PC via Smart-Clip (phone > USB cable > Smart-Clip > LPT cable > PC).
Connect S-Card to PC USB port.
Connect power supply to Smart-Clip and power on the handset.
Launch SmartMoto.
Choose "Smart-Clip USB port" in phone connection field.
Press "Search". Software should perform the following steps:
SmartMoto detects S-Card;
SmartMoto detects Smart-Clip;
SmartMoto detects the handset and reads phone information.
Log to bookmark "Flash".
Press "Browse" to select the flash file.
Press "Write flash".
Message "Flash completed" appears at the end of the process.
There are 3 types of *.mfw flash files
reflash.mfw - meant to be used for upgrade of software. No data will be lost from the phone. Other words, all downloaded pictures, ring tones, contacts won't be erased from the handset memory.
flash_flex.mfw - meant to be used for upgrade of software with change of flex (change of basic setting, e.g. working frequency band). Some data could be lost from the phone's memory after flashing.
full_flash.mfw - complete change of firmware including the EEPROM. All added data will be erased from the memory.
Flash optionsForce simple write mode (slower)
Sometimes during work with different types of flash memory chips, Block record method does not work.
In this case it's possible to work with slower but easier and more reliable flashing method - "word" flashing method. Such method takes up to 3-4 times longer to flash, but allows to work with wider variety of microchips. We recommend using this method in case of problems with block method.
Overwrite boot area
This option is required for flashing the handset with full_flash.mfw file while boot core has to be repaired or changed (downgraded).
Skip firmware mismatch confirmation
In some cases, the handset can be flashed with higher lang_pack version that differs from the original phone firmware. This option allows to avoid the firmware check. (Recommended for advanced users only!)
Turn phone off after flashing
This option allows the SmartMoto turning the handset off right after the flash process finished.
Full Flash backup*.mbk - flash backup created with Smart-Clip, S-Card together with SmartMoto.
Launch SmartMoto.
Log to bookmark "Backup".
Press "Backup phone flash".
Select the location for the file to be saved.
Message "file.mbk saved" appears when the process is completed.
The handset can be also flashed with a file backed up from another phone. In some models security zone will get backed up automatically with the flash file. In this case, after flashing the phone the original security area has to be restored:
Launch SmartMoto.
Press "Browse" to select the flash backup created from another handset.
Press "Restore phone flash".
Wait until the process completes.
Press "Browse" button again.
Select the original PDS backup (can be recognized by phone’s IMEI).
Press "Restore security area".
The handset is ready for operation.
In any case do not overwrite security area with the security file from another handset.
We strictly recommend not to flash the phones with backup flash files received from other phones in these models: C975, C980, V975, V980, E1000, A1000, V1050. We would urge everyone to use the latest version of SmartMoto and to flash the handsets only with files downloaded from our website. This does not apply to the backed up language packs.
Please, create a backup of the full flash before actual flashing. So, in case of the wrong flashing the handset can be restored to its original state.
Backup files (*.mbk) are created only for the Clip that they were made with.
It’s not possible to use "restore" feature with the backup file made by any other Clip.
In case of creating a backup of language pack, file will be saved in *.mfw format and won’t be bound to Smart-Clip hardware.
