tình trạng máy đã ban đầu chết nguồn sau đó thay cặp nguồn và flash.sau đó flash lại bị CS mặc dù đã unlock và Factory full rồi
MCU ID: 0x2292
FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.80
14-11-08
RH-105
(c) NMP
HW version: 2601
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w31_UPP
LCD version: UNKWN: IDs:
00:ff:00
PPM version: V 5.80
14-11-08
RH-105
(c) NMP
MR
ADSP SW version: V 5.80\n14-11-08\nRH-105\n(c) NMP\nmr
Production serial number: IMA731568
Product code: 0549915
Module code: 0203484
Basic production code: 0515534
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 353541023703891
IMEI spare to net: 3A 35 45 01 32 07 83 09
IMEI SV to net: 33 35 45 01 32 07 83 69 F8
Master Code: 5313326463
Phone type: RH-105, Software version: 5.80, Language Pack: MR
User code: ے#
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-105.ini
Checking path: C:\Program Files\Nokia\Phoenix\Products\\
Checking path: \Products\\
No ini files found...
Done!
Unlocking...
IMEI: 353541023703891
ASIC: b
SW version: 5.80
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_05.800
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 02
MCU ID: 0x2292
Algo is ready...
Erasing area: 01200000 - 0121FFFF...
Erasing area: 011E0000 - 011FFFFF...
Unlocking...
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 1
Setting test mode...
Setting FULL FACTORY...
Done!
			 Anh Em xem dùm mình cái log 1208
