Kết quả 1 tới 10 của 12
    V.I.P ThanhHai_GSM's Avatar
    Mặc định 3110c dùng nữa ngày mất nguồn nhờ anh em giúp
    mình có 1 máy 3110c dùng khoảng 8 tiếng mất nguồn để nguyên vậy bật không lên đc nguồn phải gỡ pin ra lắp lại bật mới lên nguồn đã chạy ver 7.21 vẫn vậy
    anh em xem giúp mình log thank.
    đây là log info
    MCU SW : V 07.21 05-11-08 RM-237 (c) Nokia.
    PPM SW : V 07.21 05-11-08 RM-237 (c) Nokia. V
    Prd.Code: 0552795
    Bpr.Code: 0542523
    Prod.Sn : MKK329557
    HW Vers : 5002
    EM RETU : 32
    EM TAHVO: 53
    RFIC Ver: 17211721
    DSP Vers: ICPR61_08w10
    IMEI : 353081-02-707950-1
    SL Serv : SIMLOCK SERVER VERSION 63
    SL Conf : 244-07-00000000000
    SL Prof : 0000000000000000
    SL Count: 00 00
    BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN
    Provider: Nokia Test;Finland
    đây là log write flash
    CMT 1ST Boot OK
    CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1
    CMT FLID0 : 0020881C-00006A21, St M58LR256KC
    CMT FLCNT : 00000000000000000000000000000000000000
    CMT MCID0 : FFFF0000-00000000
    CMT 2ND Boot OK
    CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0
    CMT KSIG0 : C0E691EA16A7593A9BB28832D7312A39F7ED668D
    CMT VPP : Internal
    DUAL LINE : True
    CMT ALG Boot OK
    IMAGE : rm237__07.21.mcusw
    CMT NOR Erase Area: 0x00000000-000006BF
    CMT NOR Erase Area: 0x000006C0-0001FFFF
    CMT NOR Erase Area: 0x00020000-0007FFFF
    CMT NOR Erase Area: 0x00080000-000DFFFF
    CMT NOR Erase Area: 0x00100000-001FFFFF
    CMT NOR Erase Area: 0x00200000-0031FFFF
    CMT NOR Erase Area: 0x00320000-0105FFFF
    CMT NOR Erase Area: 0x01060000-01067FFF
    CMT NOR Erase Area: 0x01068000-0107FFFF
    CMT FLASH ERASE OK, Time: 00:56
    Written: 10 Certificate(s)
    CMT FLASH WRITE OK, Time: 01:44
    Chip SECTOR_SIZE: 128k
    Warning, Must be Used 128Kb Sector_Size CNT File
    IMAGE : rm237__07.21.image_v_128
    CMT NOR Erase Area: 0x01520000-01FDFFFF
    CNT FLASH ERASE OK, Time: 00:47
    CNT FLASH WRITE OK, Time: 00:35
    IMAGE : rm237__07.21.ppm_v
    CMT NOR Erase Area: 0x01080000-0151FFFF
    PPM FLASH ERASE OK, Time: 00:17
    PPM FLASH WRITE OK, Time: 00:31
    Flashing Completed, Rebooting Mobile
    UI Defaults Ok, Time: 00:29
    Set UI Factory Defaults Ok, Time: 00:00
    Set Full Factory Defaults Ok, Time: 00:00
    Set Software Upgrade Defaults Ok, Time: 00:00
    Set Security Ok, Time: 00:00
    All Done, Time: 05:49
    Thành viên chính thức manhhai_au's Avatar
    thử nghe nhạc xem có mất nguồn ko bạn<khoảng chừng 1h>.nên thử pin #và ko được thì chịu tốn 1 log vậy
    Học hành là việc lớn.Yêu đương là việc nhỏ.Việc nhỏ không làm được sao làm được việc lớn
    minhquang_vũ thư thái lọ
    bạn làm như trên xem sao + từ hãy tốn một log nhé viết lại PM cho nó xem sao đã
    ngọc Hôì..citi_nhà của tôi
    [RA]mr_tankhung_kontum
    mình thử nghe nhạc rồi 5 > 6 bài gì đó vẫn bt nhưng để không đó khoảng 7>8 tiếng sau tự mất nguồn
    Thành viên tích cực tien1989's Avatar
    thay thử cục pin zin thử chưa nêud ko được bạn thử nạp pm cho nó đi
    ai chơi võ lâm 2 pmmmmmmm
    vậy thử sx4 cho nó cái<trường hợp của bạn thành công ko nhiều>nhớ backup đầy đủ nha!
    sx4 rồi vẫn không đc các bác ơi nó vẫn nguyên bệnh
    Thành viên kỳ cựu thanhnammobile07's Avatar
    dùng 8h mới mất nguồn thì kiểm tra phần cứng đi bạn.
    vệ sinh main kỹ thử xem !
    không ai quan tâm_nhưng tôi quan tâm
    thanks all
    Thành viên tích cực gsmqk2's Avatar
    Bạn gia cố lại chân 2 con IC nguồn đi nhé. mình gặp hiện tượng này ở con 3500c khách cứ đi đem lại mãi cuối cùng làm lại 2 con nguồn OK luôn. Nhưng đây chỉ là một nguyên nhân thôi chúc bạn thành công.
    thank anh em quan tâm
    để mình thử báo kết quả sau 5tiêng nữa
  1. Trả lời: 15
    Bài viết cuối: 18-11-2012, 07:24
  2. Trả lời: 12
    Bài viết cuối: 09-09-2012, 08:53
  3. Trả lời: 13
    Bài viết cuối: 14-03-2010, 20:31
  4. Trả lời: 35
    Bài viết cuối: 05-11-2009, 21:17
  5. Trả lời: 20
    Bài viết cuối: 01-10-2009, 12:31
