mình nhận cây 1200 mất nguồn.chạy lại ko dc .giờ mình đã thay ic nguồn rùi va đã gửi file và writen vào rùi mà máy vẫn contacsevice...đây là log của no mong ae ngien cúu giúp đỡ..thank..
Getting MCU ID
MCU ID: 0x2292
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 5.53
07-08-08
RH-99
(c) NMP
HW version: 1600
PCI version:
UEM version: 1328
UPP version: 8850
RFIC version: 0700
DSP version: ICPR62_08w21_U
LCD version: WIN:MYKS:04
ST7507
PPM version: V 5.53
07-08-08
RH-99
(c) NMP
MR
ADSP SW version: V 5.53\n07-08-08\nRH-99\n(c) NMP\nmr
Production serial number: DBM578929
Product code: 0550577
Module code: 0203484
Basic production code: 0515534
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354868024141667
IMEI spare to net: 3A 45 68 08 42 41 61 06
IMEI SV to net: 33 45 68 08 42 41 61 66 F4
Master Code: 0473111466
Phone type: RH-99, Software version: 5.53, Language Pack: MR
User code: ÿ#
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RH-99.ini
Setting local mode...
Reading product code...
Product Code: 0550577
Checking path: \Products\RH-99\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.530
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.53aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.53aa
Languages in ppm: English,Dannish,Norwegian,Swedish
Done!
Reading...
Phone Type: RH-99
Ini file for this phone type don't exists. Please use manual mode!
Phone Type:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.530
Phone Type:
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.53mr
Phone Type:
Phone Type:
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.53mr
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.530
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 84FA50B8529C71F0D5236C3D7A
MSID decoded: 3E4EBAE9000539ACA9000000
FAID: BBEE4713F7E4CD835ABBFDFD
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 26 seconds...
Writing...
Perm. Data Restore OK
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.53mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 846D2EAA94A71464265F0F6769
MSID decoded: 3E4EBAE9000539ACAA000000
FAID: 59F1899D0800334969971DA1
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 27 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh990_nai5.53mr
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84396AF2D2D0FBB4FFB81CD681
MSID decoded: 3E4EBAE9000539ACA8000000
FAID: 94982D43AF98A89DA4E63FA1
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 3 minutes 3 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
IMEI: 354868024141667
Resetting PPC...
Done!
Unlocking...
ASIC: b
SW version: 5.53
Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-99\rh99_05.530
Decrypting flash...
Encrypting....
CHK Patch found - Unlock Patch found and are not in same block
Patch status: 02
MCU ID: 0x2292
Algo is ready...
Erasing area: 011E0000 - 011FFFFF...
Unlocking...
Checking locks...
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Done!
DCT4 unlock counter: 1
ai bit chỉ dum minh tý nhé...
