    Thành viên chính thức ductungsl's Avatar
    Mặc định 1208 cấn giúp đỡ ngay
    em có con may 1208 chay phan mêm nó không đọc được ra i mây các bác chĩ em với
    Getting MCU ID
    MCU ID: 0x2292
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Checking RAM for ALGO...
    Algo is ready...
    Checking FAID calculation...
    Done!
    Phone Restarted...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Phone Type:
    MCU Flash file: D:\RH-105\rh105_05.710
    Phone Type:
    PPM Flash file: D:\RH-105\rh105_05.71mr
    Phone Type:
    CNT Flash file: D:\RH-105\rh1050_nai5.71mr
    Setting local mode...
    Failed! Aborting!
    Failed to backup imei...
    MCU: D:\RH-105\rh105_05.710
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 84B8CC9005CE5FD0E962D11792
    MSID decoded: 3E4EBAE9005697ADA8000000
    FAID: D049FC1F62CF66D44D90DD03
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 5 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: D:\RH-105\rh105_05.71mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 21 seconds...
    Writing...
    Restarting MCU...
    CNT: D:\RH-105\rh1050_nai5.71mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 43 seconds...
    After flash processing...
    Waiting for phone to boot...
    Reading...
    Phone type: RH-105, Software version: 5.71
    IMEI: ???????????????
    Product Code:
    Resetting PPC...
    Setting FULL FACTORY......Setting test mode...
    Done!
    Done!
    Done!
    V.I.P Hoàng Thiên™'s Avatar
    http://gsmtaynguyen.com
    Gửi log thôi, còn chờ gì nửa bạn!
    Trần Hoàng Thiên
    Tây Nguyên Mobile - Y!M: gsmtaynguyen
    Thành viên kỳ cựu thanhcong mobile's Avatar
    sen cho nó 1 log thôi bạn
    Thành viên tích cực hien_2222's Avatar
    1 log la xong
    Thành viên tích cực tmpmobile's Avatar
    Aug 2008
    có vậy mà cũng hỏi hả bác.kiếm cho nó 1 log là ok ngay thôi
    Thành viên kỳ cựu thanhfan_tf's Avatar
    ai có cho anh ý xin 1log đi hix
  1. 1280 connect cần giúp ngay
    By phuga27 in forum DCT4 - WD2
    Bài viết cuối: 12-11-2013, 09:42
  2. 2700 cần được giúp đỡ ngay
    By sangmobilehd in forum BB5
    Trả lời: 19
    Bài viết cuối: 01-01-2013, 17:05
  3. 2690 sạc máy không báo gì cần giúp ngay
    By tuyen_mobile1709 in forum BB5
    Bài viết cuối: 02-10-2012, 09:49
  4. cần giúp đỡ ngay n-box
    By wsxcde in forum UFSx - Nbox
    Bài viết cuối: 15-06-2009, 13:47
  5. cần giúp đỡ ngay
    By wsxcde in forum Phần mềm và các mã lệnh
    Bài viết cuối: 08-06-2009, 19:14
