Kết quả 1 tới 4 của 4
    Thành viên chính thức tronggsm's Avatar
    Mặc định cần anh em giúp con 1200 of em với
    bị contacsever em đã làm upp rồi bây giờ nó như vậy này
    Getting MCUID...
    MCU ID: 0x2292
    Reading flash chip detailes...
    First 16 bytes: 2D 54 94 1A 13 0A 00 20 28 00 62 04 0B C4 24 00
    MCU ID: 0x2292
    Boot is ready...
    Algo is ready...
    Loader is ready...
    Erasing area: 01000000 - 01FFFFFF...
    Error erasing area: 013F0000 - 013FFFFF
    MCU ID: 0x2292
    Boot is ready...
    Algo is ready...
    Loader is ready...
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    ADSP Flash file: NONE
    APE Variant file: NONE
    APE User Flash file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\\
    Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\\
    No ini files found...
    Phone Type:
    MCU Flash file: D:\FLASH FILE\NOKIA\DCT4\1200 RH-99_5.91\1200 RH-99_5.91\rh99_05.910
    Phone Type:
    PPM Flash file: D:\FLASH FILE\NOKIA\DCT4\1200 RH-99_5.91\1200 RH-99_5.91\rh99_05.91mr
    Phone Type:
    CNT Flash file: D:\FLASH FILE\NOKIA\DCT4\1200 RH-99_5.91\1200 RH-99_5.91\rh990_nai5.91mr
    MCU: D:\FLASH FILE\NOKIA\DCT4\1200 RH-99_5.91\1200 RH-99_5.91\rh99_05.910
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    Flash ID is 0x28882000
    Loader size is 0x4B38; Loader chk: df
    Loader is ready...
    MSID: 84844309D30B143F9F9638142E
    MSID decoded: 3E4EBAE900132404A8000000
    FAID: 30ED4F450195345189007A3B
    Operation took 0 minutes 9 seconds...
    Erasing...
    Found 5 interval(s) to erase
    Operation took 1 minutes 10 seconds...
    Writing...
    Perm. Data Restore OK
    Restarting MCU...
    PPM: D:\FLASH FILE\NOKIA\DCT4\1200 RH-99_5.91\1200 RH-99_5.91\rh99_05.91mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    First 16 bytes: 89 34 12 08 0B 94 02 22 45 10 4A 24 18 88 40 14
    Loader is ready...
    Erasing PPM...
    Found 2 interval(s) to erase
    Operation took 0 minutes 22 seconds...
    Writing...
    Restarting MCU...
    CNT: D:\FLASH FILE\NOKIA\DCT4\1200 RH-99_5.91\1200 RH-99_5.91\rh990_nai5.91mr
    Booting phone...
    MCU ID: 0x2292
    Boot size is 0x09A8
    Boot is ready...
    Loader is ready...
    MSID: 845A886BC587C74770B5CB91DF
    MSID decoded: 3E4EBAE900132404AA000000
    FAID: 17C22649D4FF54B659AE3C0F
    Erasing Content Pack...
    Found 1 interval(s) to erase
    Writing...
    Restarting MCU...
    Flashing Done!
    Operation took 2 minutes 22 seconds...
    After flash processing...
    Waiting for phone to boot...
    Failed! Aborting!
    Phone: 0989402123
    Zalo :0989402123
    Đất Hà Thành!
    check cable>>lỗi con flash>>bịt chân vpp rùi chạy lại cho nó nha anh!
    HÀ GIANG GSM
    bịt chân vpp rùi chạy lại cho nó rồi chạy là ok +wite pm+unlock ...
    Moderator VŨ PRO's Avatar
    Duy Xuyên_Quảng Nam.
    anh xem lại nhé.vẫn chưa viết vào được.
    xoá full rồi chạy lại đi anh
    không được thì thay cpu luôn
  1. Trả lời: 3
    Bài viết cuối: 29-11-2012, 12:30
  2. 1200 Xin giúp
    By VinaFone in forum DCT4 - WD2
    Bài viết cuối: 29-11-2011, 18:56
  3. 1200 cần giúp
    By Trường_Mobile in forum DCT4 - WD2
    Bài viết cuối: 13-09-2011, 17:58
  4. giúp em con 1200 với
    By manhhungmobile in forum DCT3-DCTL
    Bài viết cuối: 22-06-2009, 09:37
