Kết quả 1 tới 10 của 18
    Thành viên chính thức TUANSY's Avatar
    Mặc định chạy chương trình bằng jap
    JAF version 1.98.62
    Detected PKEY: 9002DC3D
    Card life counter: 90.40%
    FBUS INTERFACE NOT CONNECTED!!!
    USB Cable Driver version: 6.84.4.0
    Changing mode...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-217\
    Checking path: \Products\RM-217\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.ppm_a
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.image_a
    Languages in ppm: English,German,Finish,Swedish,Danish,Norwegian,Ice landic
    Backing up CRT...
    Detected P-KEY: 9002DC3D
    Init usb communication...
    Reading IMEI...
    Failed! Aborting!
    Failed to backup CRT...
    PRESS POWER ON NOW!
    Searching for phone...Found
    Sending RAW loader...
    Using 06.02.002
    Elf2flash 02.33.000 RAW loader...
    Patching RAW boot step1...
    Patching RAW boot step3...
    Sending RAW Loader...
    ...................Loader Sent!
    Stage 2 starting.......................................... ....................Loader Sent!
    Stage 3 starting..................Phone prepared OK!
    Waiting for the phone to boot...
    Status byte: 0400
    Selecting CMT flash...
    Result: 0000
    Phone is in flash mode...
    CMT blocks: 1408, APE blocks: 0
    Erasing cmt...
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.mcusw...
    Erasing cmt zone 00000000 - 000006BF ... Erase result: 0000
    Erasing cmt zone 000006C0 - 0001FFFF ... Erase result: 0000
    Erasing cmt zone 00020000 - 0007FFFF ... Erase result: 0000
    Erasing cmt zone 00080000 - 000DFFFF ... Erase result: 0000
    Erasing cmt zone 00100000 - 001FFFFF ... Erase result: 0000
    Erasing cmt zone 00200000 - 0031FFFF ... Erase result: 0000
    Erasing cmt zone 00320000 - 0105FFFF ... Erase result: 0000
    Erasing cmt zone 01060000 - 01067FFF ... Erase result: 0000
    Erasing cmt zone 01068000 - 0107FFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.ppm_a...
    Erasing cmt zone 01080000 - 015FFFFF ... Erase result: 0000
    Processing C:\Program Files\Nokia\Phoenix\Products\RM-217\rm217__06.01.image_a...
    Erasing cmt zone 01600000 - 01FDFFFF ... Erase result: 0000
    Send CMT CFG...
    Writing cmt...
    Sending CMT HASH for NOLO
    Sending CMT HASH for KEYS
    Sending CMT HASH for PRIMAPP
    Sending CMT HASH for PASUBTOC
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
    cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
    Sending CMT HASH for UPDAPP
    Sending CMT HASH for DSP0
    Sending CMT HASH for MCUSW
    Sending CMT HASH for PMM_CONF
    Sending CMT HASH for SBIF_CONF
    Rebooting...
    Restarting CMT...
    Pooling phone...
    Phone not found...
    Second try...
    Phone not found...
    Done!.
    máy có nguồn chạy thử mất nguồn.xin anh em chi giúp với
  2. ( TUANSY ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    phuc_gsm07 (06-11-2009)
    mình chạy thử cây 3110c cung vậy luôn mới mua nên không rành lắm nhờ anh em chỉ giúp.chạy giống videolip hướng dẫn ma củng vậy luôn
    Thành viên chính thức Út_mobile's Avatar
    Code:
     JAF version 1.98.62
    Languages in ppm: English,German,Finish,Swedish,Danish,Norwegian,Icelandic
    Backing up CRT...
    Reading IMEI...
    Failed! Aborting!
    PRESS POWER ON NOW!
    Using 06.02.002
    Stage 2 starting..............................................................Loader Sent!
    Status byte: 0400
    Result: 0000
    Erasing cmt...
    Send CMT CFG...
    Writing cmt...
    Rebooting...
    Restarting CMT...
    Pooling phone...
    Phone not found...
    Second try...
    Phone not found...
    Done!.
    Nâng nó lên 7.21
    4shared.com - chia sẻ và lưu trữ - tải xuống tập tin trực tuyến 6300.rm217.ver.7.21.rar
    Chuyên dịch vụ " Thank's " mướn
  5. ( Út_mobile ) được 1 thành viên cảm ơn vì bài viết hữu ích!
    thonganh2 (13-11-2009)
    Trích Được post bởi TUANSY Xem bài viết
    bạn đưa cái log hẳn hồi lên cho anh em giúp đỡ nhé
    Thành viên tích cực thamngocphong's Avatar
    her her mới chạy lần đầu mà ..ko sao ..chết vài con là có kinh nghiên thui mà ..lần sau đỡ chết ..kiếm cái file chuẩn hơn đi anh ...máy mất nguồn thì chạy bỏ 308 đi là ok
  8. #6
    V.I.P Hoàng Thiên™'s Avatar
    http://gsmtaynguyen.com
    Bạn chạy lại đi, nếu không được down cái này về cài rồi buzz Y!M linhhon_thangngoc1988 mình chạy lại cho! Cẩn thận không khéo banh IMEI thì khổ!
    Trần Hoàng Thiên
    Tây Nguyên Mobile - Y!M: gsmtaynguyen
  9. ( Hoàng Thiên™ ) đã được 2 thành viên cám ơn vì bài viết hữu ích!
    coniu (06-11-2009), TUANSY (10-11-2009)
  10. #7
    Thành viên mới tinsonmobile24's Avatar
    Oct 2009
    tháo pin ra lắp vào mở lên lại là OK ah.không mất nguồn đâu.
    tinsonmobile24@yahoo.com.chuyên bán sĩ DTDD xách tay.
  11. #8
    Đất Hà Thành!
    bạn nâng ver lên 7.21 là ok!
  12. #9
    Thành viên kỳ cựu thanhcong mobile's Avatar
    xem lại cộng cáp đi bạn,mình nhìn thấy nguy hiểm lắm.lấy pin lắp vào mở nguồn đôi lúc còn nguồn đó bạn
  13. #10
    mình chạy thử ma không duoc tới phần backup là fied máy có nguôn chạy thử mất nguồn.bỏ vào hwk thì ok. xin chỉ mình vói
  1. Trả lời: 1
    Bài viết cuối: 02-06-2014, 11:07
  2. Trả lời: 5
    Bài viết cuối: 04-03-2010, 14:20
