    Thành viên mới hummer8x's Avatar
    Question AE xem giúp mình cái log 3110c
    như vậy liệu có ổn không a?
    Booting phone...
    CMT Boot Data:
    Asic ID: 000000010000022600010006010C192101001101
    Asic Mode ID: 00
    Asic EM ID: 00000353
    Asic Public ID: 1A800019A32F7C56F278597B475323BBACF7A316
    HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000
    ROM ID: 191EC665DFAAF68F
    CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg
    Loader version: 01.1E.00 -> Revision: 0000
    Patching CMT boot step1...
    Patching CMT boot step2...
    Patching CMT boot step3...
    CMT Boot Ready
    CMT Flash ID: 89810089 <=> INTEL -> Type not in database
    CMT Flash Data: 00000000000000000000000000000000
    CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg
    Loader version: 01.21.01 -> Revision: 0000
    Patching CMT loader step1...
    Patching CMT loader step3...
    CMT Loader Ready
    Done!
    Restarting phone...Done!
    FILES SET FOR FLASHING:
    MCU Flash file: NONE
    PPM Flash file: NONE
    CNT Flash file: NONE
    APE Variant file: NONE
    Switching to serial...
    Powering the phone...
    Reading...
    MCU SW version: V 07.21
    05-11-08
    RM-237
    (c) Nokia.
    HW version: 5008
    PCI version:
    RFIC version:  17211721
    DSP version:
    ICPR61_08w10
    PPM version: V 07.21
    05-11-08
    RM-237
    (c) Nokia.
    V
    BT MCM version: 06cc-P9.1
    Retu version: 32
    Tahvo version: 53
    Production serial number: MPG312990
    Product code: 0552795
    Module code: 0203291
    Basic production code: 0542523
    Flash code:
    Order number:
    Product specific data:
    Long production SN:
    ATO:
    Default SN type:
    IMEI plain: 356833024272258
    IMEI spare to net: 3A 65 38 03 42 72 22 05
    IMEI SV to net: 33 65 38 03 42 72 22 25 F5
    LOCK STATUS:
    CONFIG KEY: 0000000000000000
    PROVIDER KEY: 2440700000000000
    Provider: AT&T;U.S.A. (3650)
    Key Code count: 0, FBUS Code count: 0
    Block 1:
    Block 2:
    Block 3:
    Block 4:
    Block 5:
    Block 6:
    Block 7:
    Searching for saved ini...
    Checking for file C:\Program Files\ODEON\JAF\JAF_RM-237.ini
    Setting local mode...
    Reading product code...
    Product Code: 0552795
    Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-237\
    Checking path: \Products\RM-237\
    Scanning ini files...
    MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.mcusw
    PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.ppm_v
    CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-237\rm237__07.21.image_v
    Languages in ppm: English,Chinese T,Vietnamese
    Done!
    hiện tượng là nge nhạc khoảng 2' mất nguồn đấy a? Mong ae chỉ giáo?Mình thấy đủ rồi mà nhỉ?
    Thành viên chính thức hung81_mobile's Avatar
    bạn thay pin khac chưa
    yahoo:hoangtubuon19812009
    V.I.P Lão_Đại's Avatar
    hải phòng
    bình thường ko nhạc có mất nguồn ko ? máy đấu tiên làm sao , bạn cho thêm tí thông tin nữa đi
    dùng 2 lệnh xem có bị lệch IMEI ko?
    Thành viên tích cực chithang8xx's Avatar
    3110 và 6300 chuyên bị bệnh này,cho dù flash tới tết cũng vậy.giải pháp cuối cùng là mất 1 log.nhưng trước khi gởi log bạn nên test pin,thay loa,tháo loa ra rồi bật nghe nhạc xem có mất nguồn ko rồi tính tiếp.
    Dịch Vụ Hot :Nhận Update FW,TestPoin,Quét pinout,Unlock,Reset Code các pé từ 16t ==> 20t.bảo hành dài hạn,không tác dụng phụ:D:D:D
    mình thay pin khác, thẻ nhớ rồi mà vẫn vậy? MÁy lúc đầu là không vào được nghe nhạc thôi bạn àh!! không nghe nhạc thì dùng bình thường ( khi bỏ thẻ nhớ ra)!! Imei test vẫn ok thế mới khổ chứ hjx!!!mình chay ca trăm máy rồi đây là trường hợp đầu tiên đấy!!Log chuẩn mà vẫn phải gửi à bạn?
    không Ae nào có ý kiến giúp mình sao!!!mình đang bí quá
    Thành viên mới anh quoc's Avatar
    co len, va kien nhan
    Jan 2009
    Config 000000000000000 thì chạy đến tết cũng nghe nhạc tắt nguồn. Dùng tool repeair lại ko đuợc thì mất 1 log hoặc 1 cặp. Vangtrangtan_8b360
    Trích Được post bởi ctcomp09 Xem bài viết
    mình thấy máy nào cũng config 000 vậy mà bạn ( tét theo máy chuẩn đấy) Bạn có thể cho mình xin tool repair đấy được không? cả cách sd nữa!! Thân!!!
  1. xin giúp 3110c mất hết đèn
    By TÍNH-NGHI_MOBILE in forum BB5
    Bài viết cuối: 24-09-2012, 22:01
  2. ae giúp 3110c..........
    By huynhphongmobile1 in forum BB5
    Bài viết cuối: 26-10-2011, 21:44
  3. 3110c Liệt Phím Anh em xem giúp
    By bomnokia in forum BB5
    Bài viết cuối: 08-01-2011, 11:30
  4. 3110c bệnh lạ ae giúp mình với ?
    Bài viết cuối: 18-10-2010, 14:27
  5. xin giúp log 3110c
    By thai.nokia1 in forum BB5
    Bài viết cuối: 17-03-2010, 21:46
