máy rơi bễ mh mất nguồn dã làm lại cpu va flash
dây là log cũa em nó ae xem dùm thanks
Getting MCU ID
MCU ID: 0x2292
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RH-99\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80aa
Languages in ppm: English,Dannish,Norwegian,Swedish
Changing flashing settings...
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mf
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mf
Languages in ppm: English,Sinhalese
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80mr
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80mr
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80ma
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80ma
Languages in ppm: English,Chinese S,Chinese T,Vietnamese,Filipino
Setting local mode...
Reading IMEI...
Reading IMEI data...
IMEI data corrupt...
Failed to backup imei...
MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.800
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Flash ID is 0x28882000
Loader size is 0x4B38; Loader chk: df
Loader is ready...
MSID: 8431E28D4CDE68073C8B59A489
MSID decoded: 3E4EBAE90086AA32A9000000
FAID: A735BC8EF1BFF1ABEE08D7ED
Erasing...
Found 5 interval(s) to erase
Operation took 1 minutes 13 seconds...
Writing...
Perm. Data Restore OK
Operation took 0 minutes 15 seconds...
Restarting MCU...
PPM: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.80ma
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
Erasing PPM...
Found 2 interval(s) to erase
Operation took 0 minutes 23 seconds...
Writing...
Restarting MCU...
CNT: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.80ma
Booting phone...
MCU ID: 0x2292
Boot size is 0x09A8
Boot is ready...
Loader is ready...
MSID: 84CFCF0E0B6B66B1438AA7376D
MSID decoded: 3E4EBAE90086AA32AA000000
FAID: 2D5A3F41272F96FD36704555
Erasing Content Pack...
Found 1 interval(s) to erase
Writing...
Restarting MCU...
Flashing Done!
Operation took 2 minutes 54 seconds...
After flash processing...
Waiting for phone to boot...
Reading...
Phone type: RH-99, Software version: 5.80
IMEI: 353209030402945
Product Code: 0546885
Resetting PPC...
Done!
