đây là log check và info,anh em xem dùm em nó bị lổi chổ nào với,màn hình lên sọc sọc và lúc bỏ sim vào khởi động xong tắt nguồn,không bỏ sim gọi 112 tắt nguồn
MCU ID: 0x3160
FLASH ID0: 88040020 <=> ST -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 11
Checking RAM for ALGO...
Algo is ready...
Checking FAID calculation...
Done!
Phone Restarted...
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
Switching to serial...
Powering the phone...
Reading...
MCU SW version: V 04.23
26-10-07
RM-166
(c) Nokia.
HW version: 4063
PCI version:
UEM version: 416
UPP version: 12640
RFIC version: 0205
DSP version: P05w06.v40
LCD version: SUEZ
PPM version: V 04.23
26-10-07
RM-166
(c) Nokia.
V
Production serial number: VBC226645
Product code: 0535809
Module code: 0203249
Basic production code: 0531001
Flash code:
Order number:
Product specific data:
Long production SN:
ATO: v????????????????????????????????????????????????
Default SN type: v????????????????????????????????????????????????
IMEI plain: 352940021606620
IMEI spare to net: 3A 25 49 00 12 06 66 02
IMEI SV to net: 33 25 49 00 12 06 66 02 F9
Master Code: 1361042514
Phone type: RM-166, Software version: 04.23, Language Pack: V
User code: 12345
Block 1:
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-166.ini
Setting local mode...
Reading product code...
Product Code: 0535809
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-166\
Checking path: \Products\RM-166\
No ini files found...
Done!
anh em dúp em với ạ
